    A Pencil Style for ya...
    36 Posts 15 Posters 12.9k Views 15 Watching
    • B
      bellwells
      Thanks for your contrubution Ross. I also use different styles to "test" my design. I think this is an effective and fun way to experiment. In my opinion, this is one of the best uses for the styles options.
      Ron
        rhankc
        Ross,
        I tried out your style on a sketchy I sent out this morning. It looked pretty good. You have better success getting all the lines to show in your drawings when you use sketchy style. I tend to loose the lines in shadowed corners, like under eaves where they attach to a wall...mostly inside corner stuff, any tips?
        thanks for the style, and nice French Quarter front!
        Hank
          Ross Macintosh
          rhankc -- Here's a tip: I find with most styles I need to tweak the shadow light/dark sliders to optimize appearance. Generally I have the 'light' slider over full right so for me its really just adjusting the 'dark' slider.
          Further to that tip, it sounds like your problem relates to resolution...
          The most important thing to understand about styles is they are resolution dependant. It is complicated by the fact that what you see on-screen is dependant upon how your graphics card is set. When you export a jpg, png or tiff the graphics card is completely uninvolved. Export resolution is set in the export dialogue and completely software dependant. Most SketchUp users export at different resolutions than what they were seeing on screen. When sketchy edges aren't involved that isn't a problem but when they are it can really change the appearance.
          So when we work with styles we need to think differently about making exports. Getting a export to appear similar to what you saw on-screen can take some trial and error. The first thing to try is forgetting that old SketchUp technique of exporting at high resolution and then resizing it down using photoshop etc. --- that technique originated with trying to eliminate jaggies. It is less relevant with styles and can actually be quite counter productive. Instead try just exporting using the screen resolution option. If you then need to resize the image, down or up, try using a program like PhotoZoomPro. (It is an excellent tool for anyone (all of us!) who works with digital images. Well worth the price and it is for macs and windows).
          I hope this advice helps.
          Regards, Ross
          • boofredlayB
            boofredlay
            Ross those are great images and thanks for the style.
            Also thanks for the brief tut on using them properly ๐Ÿ˜‰
            • N
              not registered yet
              Love to your style but got stuck with it. I am on a Mac. I can add .zip to a style and see what they look like inside but I have no idea how to get my Mac to make it into a .Style file again.
              There must be a trick to it everybody nows but me. Can anyone help me out?
              [frv]
              • KrisidiousK
                Krisidious
                .zip is a folder, a compressed folder... you need winzip to open it. or winrar or something similar.
                the files you need are inside it.
                By: Kristoff Rand
                • N
                  not registered yet
                  on a mac it works like this.
                  I can see the styles in the styles folders within the sketchupfolder. Then you remove the .style and automatically OSX turns it into a .zip folder you can uncompress by clicking it. Then you can see the content of a style. Now the problem is there. If you just have the uncompressed folder with the content how to make it one .style file that is readable by Sketchup on my Mac?
                  Thanks for trying to help me but I am still stuck. I don't think many on Macs are using homemade styles otherwise this problem would have surfaced long before.
                  I have also searched the Google groups but although Google might be great I couldn't find anything there.
                  [frv]
                  • EdsonE
                    Edson
                    frv,
                    i have been on mac forever and that never happened to me.
                    edson mahfuz, architect| porto alegre โ€ข brasil
                    http://www.mahfuz.arq.br
                    • C
                      cheffey
                      I'm on a MacBook Pro and using Safari, when i click on the ".style" files it downloads a "download.php.zip" file then when i double-click on that it extracts a folder...
                      Is there a way to get this to work on Safari without it defauting to a "download.php" file i will have to rename, etc.?
                      works fine on firefox though...
                      Thank you Ross, very slick style
                      BROS RลŒMAN BRร„UN
                      • N
                        not registered yet
                        thanks so much for looking into my problem, I think I should be more clear. When I download the pencil style all goes well. I get however the zipped version and so I only have the extracted folder. Sketchup does not regocnize this folder since it needs to be a .style file.
                        So, how can I make all the extrated files into a by Skethup readable .style file. I have tried all sort of things, I can easliy extract a .style file to see whats inside. To get the file back to a .style file so it can be put in the styles library is the problem. When I zip it again the file reads .style.zip. Sketchup does not recognize such a style and neither does SU recognize extrated sets of files. What program doe you people on Macs use to make a .Style file?
                        [frv]
                        • N
                          not registered yet
                          I downloaded the file again and it came on my dektop as i .stye file now and I tried it. Great style, thanks.
                          Just hope to find out one day how to make a .style file on my mac. I can make .zip files and extract them, thats all really.
                          By rightlclicking a file in OSX you can archive/compress it in zip format. Still, thats not a .style format.
                          [frv]
                          • tinanneT
                            tinanne
                            Ross, absolutely awesome. I am always on the lookout for good sketchy styles. I LOVE this one. I can't wait to try it out. {and great tips! I do have that problem}
                            Now if we could just export an animation with sketchy styles, I would be one happy woman ๐Ÿ˜„
                            Executive Director : American Society of Architectural Illustrators
                            AIP 30 Competition opens soon. ASAI.org
                            Architectural Rendering
                            • P
                              pmiller
                              tinanne, You can export animations with sketchy edges. Maybe some of the more elaborate styles like Ross does on Formfonts may be a problem (haven't tested them all), but sketchy edges in SU work just fine. You can also export multiple single frames (animation options) and assemble them....
                              • tinanneT
                                tinanne
                                P... don't stop there! tell me more! โžก Can I PM you and get a little more info, so we don't get off topic of how great Ross's style is? ๐Ÿ˜„
                                  Ross Macintosh
                                  Thanks for all the nice comments on the style. So warm & fuzzy.
                                  Regarding styles and macs...
                                  I don't use a mac but I think I'm correct with this information as it really relates to both macs and pc's. Styles are indeed just zip archives renamed with the .style extension in place of the .zip extension. The files are not meant to be clicked on and opened. (You can do it a pc too if you direct the computer to open the .style extension with a unzipping application).
                                  To use downloaded styles in SketchUp you need only to have it in a folder and then use SU's 'add' feature direct SU to include that folder's content in the available styles. I made this instruction sheet for FormFonts. What I do and recommend is organizing your styles in different folders. For instance I have a folder where I put styles downloaded from the forums -- that way I can keep track of the source.
                                  Regards, Ross
                                  • N
                                    not registered yet
                                    thanks, very clear.
                                    Still, I just wanted to make some changes to a style and zip the folder again (by right clicking an choosing "create archive") after my photoshop work. When I zip the files into one I can no longer make it an .style file. When I type .style instead of .zip my OSX changes the file name in .style.zip and such a file is unreadable by SU.
                                    Strange but maybe I am totally not making a zipped files in the way SU can read it.
                                    [frv]
                                      Ross Macintosh
                                      Hi frv
                                      Maybe you could try emailing the file .style.zip file to yourself and then rename it to just .style when you save it with the download manager (assuming macs still have the download manager the os used to have). If that does work remember avoid 'opening' the style as it seems that action will reassociate the particular file with archiving.
                                      Regards, Ross
                                      • N
                                        not registered yet
                                        thanks for the workaround, will try it later but can't help thinking there must be a better way to convert .zip to a .style. I did not find anything using google.
                                        [frv]
                                        • tinanneT
                                          tinanne
                                          Ross, I put your pencil style to a test... Thanks!! I love it!!
                                          • boofredlayB
                                            boofredlay
                                            Wow, that looks great. โ—
