    Kerkythea Users Unite!
    extensions
    39 Posts 16 Posters 21.2k Views 16 Watching
    • W Offline
      Will03
      Hey guys,
      I by no means am a KT expert, but I think that I am starting to get to know my way around the program. I have noticed a couple of KT pros here, I think I saw Frederik, and maybe Tomasz, and perhaps Fletch...
      Anyways, hope we can all grow and learn more about this fabulous program here!
      PS: First Posties!
      • N Offline
        not registered yet
        I am pretty new to Kerkythea and I have used it to make renders of a fantasy city I made. I'm definately not an expert either. I guess we have a lot to learn about it. πŸ˜„
        (Peter)
        • ToboboT Offline
          Tobobo
          I'm still getting to grips with it. Having the faces the right way still gets me everytime.
          Toby
          Philippians 4:13
          • jenujacobJ Offline
            jenujacob
            tobobo,
            it seems that when the next version of KT and Su2KT release u wouldnt have to worry too much bout the reversed faces!!! πŸ˜‰
              Well, that would be really nice!
              I'm always quite consistent with face orientation but when for example it comes to windows, you need not create "double faces" however thin they are for instance. Or sails for ships...
              • W Offline
                Will03
                orient faces is great, for simple objects, but as soon as you're working with a little more complex mesh, I find, it starts screwing up pretty badly! more randomizing your faces than anything...
                  RegH
                  I downloaded KT, but I find my free SU excludes exporting the proper file types. I'm an old hobbiest restricted to freeware so I can't justify investing in the "Plus" versions of anything. (Of course, there's always the lottery!) So- if there is something out there like a workaround, I'd appreciate hearing about it.
                  I had an older homebrew computer that could run Blender and Yafray, but this "nicer PC" can't handle it.
                  It's all fun, either way- keeps me out of the pubs.
                  Okay- back to the barley pop.. πŸ˜•
                  (RegH)
                    Reg,
                    The su2kt exporter should work with the free version of SU as well as the pro. There must be something else...
                      Bill Wilson
                      Yes, it does I'm using both and having one hell of a lot of fun while I'm at it πŸ˜† SU and KT are both mavelous programs for us peasants who cannot afford the pro versions. At the rate I'm learning both programs, with the help of you wonderful Guys and Gals, I may be able to hang out my shingle one day and get employment with a builder or architect and then I'll be able to afford the 'real thing' and update the computers as well.
                      Luv you all,
                      Bill
                      • ToboboT Offline
                        Tobobo
                        Reversing the face isn't the problem, its remembering to do it before exporting to KT.
                        I can have some real Malteser Moments sometimes
                        Toby
                        Philippians 4:13
                        • KrisidiousK Offline
                          Krisidious
                          Tobobo, you in Birmingham, Al. USA or Birmingham, UK?
                          just curious...
                          By: Kristoff Rand
                          • ToboboT Offline
                            Tobobo
                            I'm in the uk. Maybe i should change my profile to say UK?
                            Toby
                            Philippians 4:13
                            • W Offline
                              Will03
                              For a weird and unknown reason, (not sure if this is true still, but it was for V5) the Free SU actually works better with TomasZ's SU2KT exporter, it goes a little faster!
                              • ToboboT Offline
                                Tobobo
                                Where can i find this exporter, coz i've only got the generic exporter
                                Toby
                                Philippians 4:13
                                  Here you go Toby:
                                  http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=select&id=7
                                  also, don't forget the tuts - especially the "getting started" kit right here:
                                  http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=select&id=6
                                  • ToboboT Offline
                                    Tobobo
                                    Thanks very much i'll try and post some images in the gallery
                                    Toby
                                    Philippians 4:13
                                      tomasz
                                      Hello All,
                                      It is my first post in this section of the Forum, although I am not a novice πŸ˜„
                                      Tomasz
                                      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                                        jenujacob
                                        T.. so nice to see u here... πŸ˜„
                                          dylan
                                          I have not used Kerk for several months now 😳
                                          What is the latest version so I can download it for my new laptop?
                                          http://dmdarchitecture.co.uk/
                                            jenujacob
                                            Dylan!
                                            u can find them here! πŸ˜„
                                            http://www.sketchucation.com/scf/viewtopic.php?f=142&t=2200&hilit=
