    Rayscaper New Releases
    rayscaperrender
    791 Posts 14 Posters 369.2k Views 15 Watching
      Alattab @Alattab
      Sorry, I found several materials that have the same texture but go by different names.
        Alattab @Alattab
        The problem persists, as the palm trees cast their shadow onto the surface representing the fountain's water.
        • pixelcruncherP
          pixelcruncher Extension Creator @Alattab
          @Alattab said:
          It is a good idea to find settings that prevent elements from casting or receiving shadow
          Thanks for the suggestion! Fine-grained shadow settings come up occasionally. For now, I'm keeping Rayscaper's settings simple, but I've noted it.
          What would you use this for? If there's a common case behind it, there might be a simpler way to solve that.
          Cheers,
          Thomas
          • KrassK
            Krass
            It’s fantastic and makes my mouth water.
            Krass
            • pixelcruncherP
              Hey, Rayscaper users!
              Rayscaper 1.0.0 is available. You can get it via:
              • The SketchUcation store.
              • Direct download: Rayscaper_Win_1.0.0.rbz.
              I recommend upgrading to the latest version.
              Rayscaper 1.0: Out of Beta
              After many releases of Beta, Rayscaper is now 1.0. A big thank you to everyone who tried the betas, reported bugs and shared renders here: it shaped Rayscaper more than you think.
              Fur Material
              Paint a face with the new Fur material and Rayscaper grows real strands on it in the render: shag and short pile rugs, sheepskin, faux fur throws, plush cushions, even the coat of an animal. Start from a preset and tune the length, density and curl. An image texture colors every strand where it grows, so a patterned rug keeps its pattern. See Fur Material.
              Rayscaper rug in Fur
              Close-up of the rug
              SketchUcation runner in Fur
              Sheepskin
              Wind for Grass
              The Grass material gets Wind and Wind Direction, which lay the grass over one way, and stronger mowing stripes. The online material library now has thirty Grass materials: lawns, sports turf, meadows, wild grass and artificial turf. See Grass Material.
              A New Look
              The render window has a calmer, darker look with clearer selections.
              What Changed?
              • Add the Fur material: paint a face with it and Rayscaper grows real strands on it in the render, for shag and short pile rugs, sheepskin, faux fur throws, plush cushions, long hair and the coat of an animal. Fur hangs down under gravity on walls and over rounded shapes, and an image texture colors every strand where it grows.
              • Add Wind and Wind Direction to the Grass material, and lean whole clumps for stronger mowing stripes.
              • Add thirty Grass materials to the online material library.
              • Give the render window a new look: calm dark surfaces, clearer selections and a new UI font.
              • Take Rayscaper out of Beta.
              • Fix dark soft edges and fades in PNG and TGA textures with transparency, and transparent images that were saved too bright.
              • Fix a crash of CPU renders when the model changed while the render ran.
              • Wrap buttons that ran past the edge of a narrow scene editor panel, and translate the Browse button.
              Full release notes: rayscaper.com/manual/release-notes
              Help Me Build the Community 👍
              If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
              Follow me on X.
              Happy Rendering!
              Thomas
                Alattab
                pixelcruncherP A 2 Replies Last reply
                • pixelcruncherP
                  @Alattab Okay, thanks for the image. That makes it very clear 🙂
                  A 1 Reply Last reply
                  • KrassK
                    Krass
                    that's why I think this type of effect should be done in post production.
                    Did you use 3D fontain water? There are several on the 3d warehouse
                    Krass
                    A pixelcruncherP 2 Replies Last reply
                      Alattab
                      I believe it is essential to include a material type or tab that mimics "billboard" elements—specifically for materials that the user does not wish to fully render, but rather wants to configure for properties like alpha, masking, casting shadows, and receiving shadows. Adding this would significantly enhance the value of RayScaper. Currently, the absence of this feature—which is available in software like SketchUp—sometimes forces me to use other applications instead. I strongly recommend this addition; you can see similar implementations in programs such as Thea Render, SimLab Composer, and others.
                        Alattab @Krass
                        @Krass Suppose you have dozens of nozzles; imagine how many water droplets will have their light-related properties manipulated.
                          Alattab @pixelcruncher
                          @pixelcruncher I believe it's essential to include a material or tab that simulates billboard elements and materials for which the user doesn't want to render; they only want to define alpha, mask, cast shadow, and receive shadow. This would enhance the value of Rayscaper. Sometimes, this feature is unavailable here, even though it's available in SketchUp, so I recommend it. You can see this in several programs like TheaRender, SimLab Composer, etc.
                          • pixelcruncherP
                            @Krass here's the fur example scene to try out: https://scenes.rayscaper.com/rayscaper-fur-example.skp
                            • KrassK
                              Krass
                              Thanks a lot!!!! Tonight I missed your post about the V1.0...
                              So exited to test the fur, tomorrow morning! Champagne!
                              Krass
                              Reply Quote 2
                                Alattab @Alattab
                                A "fake emission" texture type can be used to prevent shadows from being cast onto a surface.
                                  Alattab
                                  It would be great if you could add presets for the sun for different times of the day and night.
                                    Alattab
                                    what about decal
                                    Decal Renderer Feature | Universal RP | 14.0.12
                                    (docs.unity3d.com)
                                      Alattab
                                      • KrassK
                                        Krass
                                        Rayscaper
                                        This is truly excellent—thanks for adding this option so quickly!
                                        I’ve just posted a new message in the Rayscaper section of the French forum Biblio 3D to mark the release of version 1.0.0, including a summary of all the available features:
                                        [ RAYSCAPER ] Rayscaper 1.0.0
                                        Rayscaper pour Sketchup version finale vient de sortir, fini les beta. Disponible aussi pour Mac https://sketchucation.com/plugin/2677-rayscaper Le programme es
                                        www.biblio3d.com (www.biblio3d.com)
                                        I’ve created this initial render; please forgive me for not being able to resist the kitschiness of this sofa...
                                        Krass
                                        • KrassK
                                          Krass
                                          However, this first render is slightly blurry; I hadn’t touched any of the settings... Could it be related to the heavy demands that the "Fur" places on my graphics card? I’m not sure—perhaps I accidentally moved a slider somewhere...
                                          Krass
                                          • pixelcruncherP
                                            @krass Very cool render, I forgive you for the kitsch 🙂
                                            I changed the denoising; it kicks in a bit earlier, so maybe that's why the render looks blurry? Do you prefer a noisy first render over a blurry one?
                                            Cheers,
                                            Thomas
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 35 / 40
