    Modlumi - Easy 3D modelling
    252 Posts 8 Posters 20.1k Views 6 Watching
      It has same function than the last 0.20 windows ? I can't test, i am not a mac fellow! πŸ™‚
      • pixelcruncherP
        pixelcruncher Extension Creator @pilou
        @pilou yes, it has the same features.
        ntxdaveN 1 Reply Last reply
        • ntxdaveN
          ntxdave @pixelcruncher
          @pixelcruncher I am having a problem trying to create an array. I want to copy/move an object and add multiple copies. I thought there was something in this thread before about how to do this but I cannot find il Can someone help me.
          Press F1...thank me later
          • ntxdaveN
            ntxdave
            I am trying to create an array of objects. I thought there was a post in this thread about how to do this but I cannot find it; Can someone give me the instructions about how to do it.
            • ntxdaveN
              ntxdave @ntxdave
              OK, I looked at the documentation and figured it out.
                Maybe it's me but seems there is a bug here ?
                We need a perpendicular snap 3D ! (for pick the external oposite side!
                • ntxdaveN
                  ntxdave
                  I did some testing of applying material images and am reporting some issues I had. However, it would be interesting if there was a way the sender could have a copy of the report. I think the report process is very interesting and that more products should have some type of a feature like it. I just would like to be able to see it/have a copy of it somewhere. Thanks for having this feature in your software. πŸ™‚
                  • pixelcruncherP
                    pixelcruncher Extension Creator @ntxdave
                    @ntxdave I'll see what I can do. Don't forget to leave your email address on the report πŸ˜‰ - There's a bunch I suspect came from you, but I can't really reply on them because there's no sender address.
                    Cheers,
                    Thomas
                    • ntxdaveN
                      Cheers,
                      Thomas
                      I did not see a place on the report to enter my email address. I will go try again just to see it.
                      Yes, I have submitted several posts. πŸ™‚
                      OK, I just did a really silly test screen and included my email address. Sorry I did not see that before. 😞
                        As you can see there is no precise first click Snap 3D of the Gizmo for any reason!
                        I make Shift for Block the Plane then Ctrl for Copy...
                        Same trapeze volume than above!
                        • ntxdaveN
                          ntxdave
                          Cana someone give me some instructions about how to do the following things in Modlumi:
                          • Change the name of a color. I was able to change the name of a material image, but I have used several colors in a model but cannot edit the name of the color. It always set the name of the color Paint and will not allow me to set the name I want to use.
                          • Set the size of a text object (not the 3D text, just a plain old text object).
                            for the moment seems a text object not 3D is a Label!
                            • ntxdaveN
                              ntxdave @pilou
                              Yes, I understand that I just want to have some control of the β€œLabel”. IMO, it is kind of useless as is.
                              • majidM
                                majid
                                Any chance of adding "curevd" guides? Nubrs curves? As a guide for the follow-me or copy-along path tool etc....
                                • 11
                                • 12
                                • 13
                                • 13 / 13
