    Modlumi - Easy 3D modelling
    382 Posts 9 Posters 51.9k Views 9 Watching
    • ntxdaveN
      ntxdave @pixelcruncher
      @pixelcruncher I am having a problem trying to create an array. I want to copy/move an object and add multiple copies. I thought there was something in this thread before about how to do this but I cannot find il Can someone help me.
      Press F1...thank me later
      • ntxdaveN
        ntxdave
        I am trying to create an array of objects. I thought there was a post in this thread about how to do this but I cannot find it; Can someone give me the instructions about how to do it.
        ntxdaveN 1 Reply Last reply
        • ntxdaveN
          ntxdave @ntxdave
          OK, I looked at the documentation and figured it out.
            Maybe it's me but seems there is a bug here ?
            We need a perpendicular snap 3D ! (for pick the external oposite side!
            • ntxdaveN
              ntxdave
              I did some testing of applying material images and am reporting some issues I had. However, it would be interesting if there was a way the sender could have a copy of the report. I think the report process is very interesting and that more products should have some type of a feature like it. I just would like to be able to see it/have a copy of it somewhere. Thanks for having this feature in your software. πŸ™‚
              • pixelcruncherP
                pixelcruncher Extension Creator @ntxdave
                @ntxdave I'll see what I can do. Don't forget to leave your email address on the report πŸ˜‰ - There's a bunch I suspect came from you, but I can't really reply on them because there's no sender address.
                Cheers,
                Thomas
                • ntxdaveN
                  Cheers,
                  Thomas
                  I did not see a place on the report to enter my email address. I will go try again just to see it.
                  Yes, I have submitted several posts. πŸ™‚
                  OK, I just did a really silly test screen and included my email address. Sorry I did not see that before. 😞
                    As you can see there is no precise first click Snap 3D of the Gizmo for any reason!
                    I make Shift for Block the Plane then Ctrl for Copy...
                    Same trapeze volume than above!
                    • ntxdaveN
                      ntxdave
                      Cana someone give me some instructions about how to do the following things in Modlumi:
                      • Change the name of a color. I was able to change the name of a material image, but I have used several colors in a model but cannot edit the name of the color. It always set the name of the color Paint and will not allow me to set the name I want to use.
                      • Set the size of a text object (not the 3D text, just a plain old text object).
                        for the moment seems a text object not 3D is a Label!
                        • ntxdaveN
                          ntxdave @pilou
                          Yes, I understand that I just want to have some control of the β€œLabel”. IMO, it is kind of useless as is.
                          • majidM
                            majid
                            Any chance of adding "curevd" guides? Nubrs curves? As a guide for the follow-me or copy-along path tool etc....
                            • pixelcruncherP
                              pixelcruncher Extension Creator @majid
                              Iwill add it to the list! I've been in Rayscaper mode the last couple of days but will continue with modlumi after the weekend.
                              majidM 1 Reply Last reply
                                @pixelcruncher
                                Don't know and don't find how to send you an email or a private message here!
                                This STL don't works in ModLumi !
                                So here the file! https://moiscript.weebly.com/uploads/3/9/3/8/3938813/fauteuil.zip
                                I success inside the new cool free Layerling πŸ™‚ https://layerling.com/
                                but not in the Desktop version of ModLumi ! 😞
                                Have happy coding!
                                Pilou!
                                This STL was created from the free Krea 3D https://www.krea.ai/3d
                                it was very small but...
                                • majidM
                                  majid @pixelcruncher
                                  @pixelcruncher Great. Just saw what is new in the latest sketchup release; a similar tool is there: Procedural Follow Me, procedural copy along path...etc Your card might be "NURBS guides added to traditional SU tools...
                                  • chonC
                                    chon
                                    Hello all,
                                    Working on several sites on several PC, if possible, it would be nice to have a portable version for Windows of Modlumi on USB for tests.
                                    Many thanks
                                    SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
                                    • pixelcruncherP
                                      pixelcruncher Extension Creator @chon
                                      @chon The installed modlumi.exe is a single file. I haven't tried it yet, but I think you can copy it to a USB disk, and it will just work.
                                      Cheers,
                                      Thomas
                                      chonC 1 Reply Last reply
                                      • pixelcruncherP
                                        Modlumi 0.21 is out
                                        Download it for Windows from https://modlumi.com/download/latest/windows, or open the browser version at https://modlumi.com/app/. If you already run 0.20 on Windows, it will offer you the update. The Mac build of 0.21 will follow later.
                                        New features
                                        • Import STL, OBJ, PLY, 3DS, glTF, FBX and COLLADA models. Choose File β†’ Import... or drop a file on the window. STL, OBJ, PLY and 3DS files don't say which units they use, so Modlumi asks first. The model arrives as one component with a group for each object in the file, and materials keep their names and colors. Large meshes import quickly: @pilou's armchair of over a million triangles takes seconds now. Thanks for the file! https://modlumi.com/docs/user-guide/files/#other-3d-formats
                                        • Reorder scenes, glide between them and play them in turn. Drag a scene up or down the Scenes panel to move it. Clicking a scene glides the camera to it, and Play (also View β†’ Play Scenes) glides through every scene until you stop it. Thanks @pilou and @ntxdave for asking! https://modlumi.com/docs/user-guide/navigating/#scenes
                                        Improvements
                                        • Perpendicular snap. Once you've clicked a first point, hover an edge or guide line to find Perpendicular, the magenta dot where a line from your first point meets it at a right angle. It works in 3D too. Thanks @pilou! https://modlumi.com/docs/user-guide/drawing/#snapping-and-axis-locks
                                        • Right-click a row in the Outliner for the same menu as in the viewport, with Erase, Hide, Explode, Make Component and the rest. Thanks @pilou for the idea!
                                        • Combine Solids tells you why a selection isn't a solid. The commands are now disabled for a group or component that isn't a solid, and their tooltip says why. Here's @pilou's sphere and pyramid: the sphere's group only wraps another group, so it needs exploding first.
                                        • Models with many nested component copies stay responsive. Copies of a component now share their geometry for snapping and selection. @pilou's four levels of ten rotated copies used to freeze Modlumi for minutes; now the view updates in a few seconds and drawing over them stays smooth.
                                        • Rename materials in the Materials panel. Select a material, type a new name in its Name field and press Enter. Thanks to whoever asked through the feedback form!
                                        • The feedback form asks for your email first and remembers it, so we can actually answer your reports. Thanks @ntxdave for pointing out it was easy to miss!
                                        • For script and plugin writers: addEdges and addCurve no longer make faces when they close a loop, as in SketchUp's Ruby API. Use addFace, or the new entities.findFaces on one of the edges. entities.addInstance places another copy of a component, and JSON.stringify now prints points, vectors, entities and selections. https://modlumi.com/docs/guides/geometry/#drawing-edges
                                        Fixes
                                        • A plugin that needs a newer Modlumi now says so and tells you where to update, instead of listing internal feature names and stopping mid-sentence. Thanks @Krass!
                                        • Edges draw in the edge color inside painted groups and components. Edges inside a group painted with an image showed as white lines. Thanks to the user who reported it from the app!
                                        • Edges just behind curved surfaces no longer show through on Windows. @Krass, this should help with the edge artifacts you saw on the desktop app; let me know if you still see them.
                                        Full release notes: https://modlumi.com/docs/release-notes/
                                        Thanks for all the reports. Keep them coming!
                                        Cheers,
                                        Thomas
                                        • ntxdaveN
                                          ntxdave
                                          Tried the version 0.21 and several of the items I reported have been fixed.
                                          • Being able to move items in the scenes list
                                          • Fixed the white line/edges when applying material images
                                          • Being able to edit the name of materials (in particular colors)
                                          I have reported a couple other problems though
                                          • Can not delete materials from the material list (in my case I accidentally added a material image that I wanted to delete)
                                          • Can not move text objects (could not edit them either nor can I control the size or color of a text object)
                                          I think the improvements in 0.21 are good. Looking forward to the next set of changes.
                                            What a reactivity!
                                            The copy rotation of an inclined face Offsseted is always problematic!
                                            Request : Extrude segments!
                                            Make a face from selected segments (sure i can draw a segment and erase it but...)
                                            Edit Points
                                            Subdivision of a volume πŸ™‚
                                            Follow when you click a snap point as you see the cross green is not on it! 😞
                                            And the Axe blocked don't work as expected!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 19
                                            • 20
                                            • 13 / 20
