    Modlumi - Easy 3D modelling
    382 Posts 9 Posters 51.8k Views 9 Watching
      BUG! πŸ™‚ File linked! Of course each are solids or components!
      Boolean don't work with these Shapes!
      bug6.zip
      • pixelcruncherP
        @Krass could you check whether the edge artifacts from your Mercedes videos still show up in Modlumi 0.20? I tried your C63 model with both 0.13 and 0.20 on my machine and can't reproduce them, so it may depend on the graphics card. If you still see them, could you tell me which GPU and driver version you have? Task Manager β€Ί Performance β€Ί GPU shows both. Thanks!
        • pixelcruncherP
          pixelcruncher Extension Creator @pilou
          @pilou It's there! While scaling, tap Ctrl (Option on Mac) to switch to scaling about the center. Then a side's middle grip moves both sides symmetrically. Tap Ctrl again to go back to the opposite grip. You can tap it before you grab a grip or in the middle of the drag, and the status bar shows "βœ“ Center" while it's on. A typed value like 2 + Enter keeps it centered.
          More in the docs: https://modlumi.com/docs/user-guide/transforming/
          • pixelcruncherP
            @ntxdave Sorry the update keeps giving you trouble. On my end the update link serves modlumi-0.20-Setup-x64.exe correctly. My guess is that the browser holds the file back because the installer isn't code-signed yet, and in that state it can show up as an unnamed or "Unconfirmed" download instead of an .exe.
            Could you post a screenshot of the browser's download list (Ctrl+J) right after downloading, and tell me which browser you use? If you see a "Keep" or "…" option there, try Keep β†’ Keep anyway. Does that give you the .exe?
            Meanwhile you can always get the installer straight from https://modlumi.com/download/latest/windows. Thanks for sticking with it!
            ntxdaveN 1 Reply Last reply
              @pixelcruncher
              About Scale : yep that was that ; very cool the number as multiply length!
              In general we have properties say a box WIdth, Depth,height
              Not yet possibilitie to edit numericaly something ?
              • ntxdaveN
                ntxdave
                @pixelcruncher Is there any way that we could use these items in ModLum:
                • SketchUp materials with the ability to adjust the roughness, shin, and other settings to make more realistic materials.
                • Fonts installed on our Windows or Mac computer
                I am sure that others will come up with other ideas like this, but I think ModLumi is coming along fine. I am trying to learn how to use various features and thing you are making good progress. At some point, it also be neat if there was a way to use the Rayscaper features with ModLumi.
                One last question: As some point, do you expect to make ModLumi a "paid" product?
                OK, one more dumb question: Is it ModLUmi or Modlumi?
                Press F1...thank me later
                  @ntxdave
                  On the first post it's Modlumi but i write ModLumi because it's more easy to remember it! πŸ™‚
                  And better visual impact! πŸ™‚
                  About the Paid product https://community.sketchucation.com/post/1622917
                  • ntxdaveN
                    ntxdave @pixelcruncher
                    I have been getting things updated OK. On my laptop, sometimes Norton makes me OK things several times but I am not running version 0.20 on both my laptop and the browser (I am using the MS Edge browser).
                    Thanks for the post though. Since I can no longer afford SketchUp, I am looking at ModLumi a lot and trying to learn how to use the various options. I hope I am not bugging you with all of the posts I have been sending you.
                      Prompts were:
                      Erase axes and make a futurist city
                      At the beach
                      At the snow mountain
                      • pixelcruncherP
                        pixelcruncher Extension Creator @ntxdave
                        @ntxdave That's what we're here for, to figure it all out together.
                        • pixelcruncherP
                          Modlumi for Mac is out 🍏
                          Hi all,
                          Modlumi now runs on the Mac too. You can get it from the download button on modlumi.com, or directly here: modlumi.com/download/latest/macos. It's free.
                          It's the same desktop app as on Windows: save models straight to disk, File β†’ Save to Image…, plugins and scripting with the script console and editor, and all the built-in plugins.
                          Getting started
                          • Unzip the download and move Modlumi to your Applications folder.
                          • The app is signed and notarized by Apple, so it opens without security warnings.
                          • Shortcuts use Cmd where Windows uses Ctrl, so Cmd+N, Cmd+A and so on.
                          What you need
                          A Mac with Apple silicon (M1 or newer) running macOS 15 Sequoia or later. Intel Macs aren't supported yet.
                          This is the first Mac build, so expect a few rough edges. If something looks or feels off, please use Help β†’ Report a Bug or Send Feedback… or post it here as usual.
                          Cheers,
                          Thomas
                            It has same function than the last 0.20 windows ? I can't test, i am not a mac fellow! πŸ™‚
                            • pixelcruncherP
                              @pilou yes, it has the same features.
                              • ntxdaveN
                                @pixelcruncher I am having a problem trying to create an array. I want to copy/move an object and add multiple copies. I thought there was something in this thread before about how to do this but I cannot find il Can someone help me.
                                • ntxdaveN
                                  ntxdave
                                  I am trying to create an array of objects. I thought there was a post in this thread about how to do this but I cannot find it; Can someone give me the instructions about how to do it.
                                  • ntxdaveN
                                    ntxdave @ntxdave
                                    OK, I looked at the documentation and figured it out.
                                      Maybe it's me but seems there is a bug here ?
                                      We need a perpendicular snap 3D ! (for pick the external oposite side!
                                      • ntxdaveN
                                        ntxdave
                                        I did some testing of applying material images and am reporting some issues I had. However, it would be interesting if there was a way the sender could have a copy of the report. I think the report process is very interesting and that more products should have some type of a feature like it. I just would like to be able to see it/have a copy of it somewhere. Thanks for having this feature in your software. πŸ™‚
                                        • pixelcruncherP
                                          @ntxdave I'll see what I can do. Don't forget to leave your email address on the report πŸ˜‰ - There's a bunch I suspect came from you, but I can't really reply on them because there's no sender address.
                                          Cheers,
                                          Thomas
                                          • ntxdaveN
                                            Cheers,
                                            Thomas
                                            I did not see a place on the report to enter my email address. I will go try again just to see it.
                                            Yes, I have submitted several posts. πŸ™‚
                                            OK, I just did a really silly test screen and included my email address. Sorry I did not see that before. 😞
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 19
                                            • 20
                                            • 12 / 20
