    Modlumi - Easy 3D modelling
    341 Posts 9 Posters 41.4k Views 8 Watching
      Request
      Multiple Push Pull
      A random selection after a True Bend for example! πŸ™‚
          Funny the file .modl above is just 55 Kb! πŸ˜‰
          neige.zip
          • pixelcruncherP
            @Krass said:
            I'm reading the instructions carefully, but I can't manage to install the plugin.
            @Krass said:
            for th image import issue, it works now.
            For hte kitchen maker plugin. Do we only have to download plugin.json and and pic it from the plugin manger?
            What did you do different for the image import that it works now?
            I assume you only downloaded the plugin.json file, and picked that? Modlumi assumes a plugin lives in its own folder so it will pick all files surrounding that plugin.json file. You need to download the full github repo as a zip file. Sorry about that, the instructions on the GitHub repo were vague. I'm fixing that!
            I've put detailed instructions here: https://modlumi.com/docs/user-guide/plugins/#install-a-plugin-from-github - Can you let me know if that works?
            Cheers,
            Thomas
            • KrassK
              Krass
              Hello Thomas,
              I'm not familiar with Gihub, so I still can't find any "ZIP" or "Download ZIP" button on the Github page
              Krass
              • KrassK
                Krass
                ok, I found it following your installing manual, Sorry. My impatience...
                Krass
                • pixelcruncherP
                  No worries! GitHub is a website where you can host program source code for free. It'll become even more important in the future because more and more non-programmers are using AI to create code. GitHub is the perfect place to share that code.
                  • KrassK
                    Krass
                    Krass
                    • KrassK
                      Krass
                      I downloaded the zip file and first placed it on my desktop, then went to modlumi/extensions/install a plugin/; I selected the zip file and got an error.
                      So, I moved the zip file to the user/local/modlumi/plugins folder and tried again, but got another error message.
                      Krass
                      • KrassK
                        Krass
                        Krass
                        • pixelcruncherP
                          @krass You need to upgrade to v0.15. Your build is out of date.
                          • KrassK
                            Krass
                            thanks Thomas,
                            The plugin is nice. Being able to place a piece of furniture aligned to the right or left with a single click is great. However, the fact that it generates groups instead of components is an issue... being able to change all the handles or the color of the cabinet bodies with a single click would be preferable.
                            Krass
                              If you want some ideas! πŸ™‚ TopMod is a free Killer! My TopMod little page : https://moiscript.weebly.com/topmod.html
                              (and as you can import OBJ inside ModLumi) πŸ™‚ But...
                              Bridge inside Vectary
                              Bridge inside TopMod and transform !
                              Render inside the regretted free Alpaca (after the TopMod transform of each segments! )
                              The cool function of transform each segments!
                              700746936_orig.gif!
                              • KrassK
                                Krass
                                Will you add DAE collada format for exporting? A format that could keep basic hierarchy?
                                Krass
                                  Cool we can Drag & Drop files! πŸ™‚
                                  In TopMod for ModLumi you must make "Save As" OBJ and not Export OBJ!
                                  Import OBJ from TopMod Inside ModLumi works fine! πŸ™‚ (faces are triangulated but less than Stl)
                                  soccerball.zip the TopMod obj file!
                                    From TopMod to Modlumi you can Export STL (no other choise) πŸ™‚
                                    STL also ... but faces are more triangulated!
                                    soccerballst.zip the STL TopMod File!
                                      TopMod --> ModLumi --> free Gemini
                                        Bug ? when a big work is launched we can't Stop the process!
                                        Only Alt + Ctll + Del! πŸ™‚
                                        • pixelcruncherP
                                          @pilou What do you mean by big work? Also, the browser isn't very effective at handling big projects; you should prefer the desktop for that.
                                            No I was in Desktop ! :Β°
                                            Something like a Complex object = Component / Rotation *10 / = Component / Rotation * 10 = Component / Rotation *10 = Component πŸ™‚
                                            So I want stop during the last process!
                                            • 11
                                            • 17
                                            • 18
                                            • 9 / 18
