    Modlumi - Easy 3D modelling
    337 Posts 9 Posters 36.9k Views 8 Watching
      Very cool we can Group / Component the Guides lines! (Lines & Points)
      but we can't add here for example a new created Point inside a Group or Component yet existing!
      Like Select a Point drawn : Right Click Properties yes but no possibility to input in a Group / Component!
      General : no possibility to explode a group / Component in the Outliner!
        Seems we can't Delete guides lines saved & re loaded! (file linked)
        And here the Triple Click don't select the 2 volumes! There are not Group or component !
        Only a rectangle Lasso can all select! same file linked...
        2pp.zip
          Any Booleans work! ๐Ÿ˜ž File linked!
          Curious! Surely bug! ๐Ÿ™‚
          2volumes.zip
            • KrassK
              Krass
              hello
              bravo !
              iMporting soften edges skp model is ok, but no soften edges for geometry made in the software?
              It's great to already ahave de desktop version. But when importing the same model in the web version and desktop version, desktop version displays strange edges artefacts that are not visible. especially when navigating the model
              modlumi_53pJANOnUv.mp4
              chrome_cGmxSsPcAk.mp4
              Krass
              • pixelcruncherP
                @krass you are fast man, you already found the download ๐Ÿ™‚ - Will announce it shortly.
                Will have a look at these bugs. Softening edges is not done yet; will do that soon. Thanks for the bugs; I will make things a bit better again.
                Cheers,
                Thomas
                  How big is or will the Desktop version ? (i have no very big place free on my old Latop ! ๐Ÿ˜‰
                  Request : does it possible to hide:Show the axes in the screen ? I know this function is existing when you save image! But..
                  Does it possible to have also the JPG format inside the Save to Image ?
                    can we load .rbz in the Desktop version ?
                    Can we yet scripting in the desktop version ?
                    • pixelcruncherP
                      Modlumi for Windows is out ๐ŸŽ‰
                      Hi all,
                      The desktop version of Modlumi is now available for Windows. You can get it from the big button on modlumi.com, or directly here: modlumi.com/download/latest/windows. It's free.
                      What the desktop app adds over the browser preview
                      • Save models straight to disk (the browser only downloads a .modl file, and you lose your session when you reload)
                      • File โ†’ Save to Imageโ€ฆ
                      • Plugins and scripting, with a script console and an editor
                      • Touch controls
                      Plugins
                      The desktop app comes with ten built-in plugins: Shapes, Clean Up, Solid Inspector, True Bend, Modify Solids, Select Similar, Levels, Face Area, and OBJ and STL export. You can turn each one on or off in Extensions โ†’ Manage Extensions. To write your own, use JavaScript or TypeScript. The plugin guide explains how, and the source of the built-in plugins is there to learn from.
                      @pilou, to answer your questions: the installer is about 5 MB. SketchUp .rbz extensions won't run because Modlumi plugins are written in JS/TS rather than Ruby.
                      Not on Windows? The browser preview at modlumi.com still has the same modeling tools. There's no Linux download yet, and macOS will come later.
                      If you find bugs, please use Help โ†’ Report a Bug or Send Feedbackโ€ฆ and attach modlumi.log, or post them here as usual. @Krass, I'm looking at the edge artifacts you saw on desktop.
                      Cheers,
                      Thomas
                      • pixelcruncherP
                        I also put the plugin examples on github: https://github.com/thomasloockx/modlumi-plugins
                        1 Reply Last reply โ™ฅ
                          Many thanks for the infos ! ๐Ÿ™‚
                            You said 5 Megas for the Installer yes but the complete program installed is how Big ( 500 Meg ...? )
                              Request
                              In the Move, Rotate, Size + CTRL + * / % ...+ a "randomize" for give some fun variations in the result?
                              Not yet on the volume itself... but... ๐Ÿ™‚
                              • pixelcruncherP
                                pixelcruncher Extension Creator @pilou
                                @pilou still about 5 meg, itโ€™s a small program. It doesnโ€™t download a ton of stuff from the web.
                                • pixelcruncherP
                                  Well it doesnโ€™t download anything for the installation. Its just one exe.
                                  • ntxdaveN
                                    ntxdave
                                    Another of my silly questions: How do you draw/show/hide guides?
                                    Still another one: I want to draw a rectangle with each of the 4 corners rounded (same size). What is the best way to do that. In SketchUp, when you do that, you can double click in each of the other corners and it will repeat the first corner.
                                    Press F1...thank me later
                                    • pixelcruncherP
                                      Modlumi 0.13 is out: fixes for your latest reports
                                      Modlumi 0.13 is live at https://modlumi.com/app. Thanks @pilou for the reports and the files, they made these easy to track down.
                                      Combine Solids through curves
                                      Union, Subtract, Intersect, Trim, Split and Outer Shell now work when the cut goes through an arc or a curve, like the two half-round volumes in your 2volumes file. Before, they all failed with "the result would not be a closed solid".
                                      Combine Solids through a curve, before and after
                                      Redrawn sides stay whole
                                      Erasing a line drawn across a rectangle together with the side it touched, then drawing that side again, now gives one edge. The rectangle is back to four sides.
                                      Redrawn side, before and after
                                      Eraser on groups and components
                                      Pointing the Eraser at an edge or guide inside a closed group or component now erases the whole object. To erase a single guide or edge, open the group first. That's why the guides in your 2pp file looked impossible to delete: they were inside groups.
                                      Eraser on a group, before and after
                                      @Krass, I'm still looking at the edge artifacts you saw on the desktop version.
                                      Full release notes, now also listing 0.11 and 0.12: https://modlumi.com/docs/release-notes/
                                      As always, bug reports and ideas are welcome here or through the feedback button in the app.
                                        @ntxdave
                                        Just 2 things to know for draw Help Lines guide (for the moment!
                                        You must click (select) a segment yet existing for a line .
                                        So Draw a line
                                        Select it Press T , Click the midle of the line for exemple, and drag , type 5 as 5 units you must ha a line drawn at 5 units!
                                        For Point guide it's the same but your first click must at a corrner of 2 segments!
                                        • pixelcruncherP
                                          @Krass, could you send me the Mercedes model from your videos? Attaching the .skp here is fine, or send it through Help โ€บ Send Feedbackโ€ฆ in the app.
                                          I can't reproduce the edge artifacts on Linux with our own car model, and the desktop app on Windows draws through Direct3D, which handles one edge depth offset differently. With your model I can test a fix before the next desktop build. If you can, also mention your graphics card.
                                          KrassK 1 Reply Last reply
                                            @pixelcruncher
                                            Combine 2 curvated solid perfect! Ok
                                            Right Click on them / Erase ! OK perfect ! But why we can't do that also directly inside the OutLiner ???
                                            If the exe on desktop version is only 5 megas i wiil download it! ๐Ÿ™‚
                                            Like this i will can test some script by a friend, alas not by me because scripting is out from me now! ๐Ÿ™‚
                                            (except if i use Ai ... but that will be another story! ๐Ÿ™‚
                                            modeling bugs first! ๐Ÿ™‚
                                            • 16
                                            • 17
                                            • 6 / 17
