    Modlumi - Easy 3D modelling
    110 Posts 7 Posters 3.3k Views 6 Watching
      Request: Perpendicular Snap from Lines, Points Guides...
      Also in 3D space!
          • pixelcruncherP
            Modlumi 0.11 is out: more solid tools, typed points and smoother rendering
            Modlumi 0.11 is live at https://modlumi.com/app. Thanks to @Krass and @pilou for the bug reports in this thread. Both are fixed in this release.
            More solid tools
            Combine Solids now also has Trim, Split and Outer Shell:
            • Trim cuts the second selected solid out of the first and keeps the second.
            • Split separates two solids into what each holds alone and what they share.
            • Outer Shell keeps only the outside of one or more solids.
            Union and Intersect now take more than two solids at once. Cutting large solids is also much faster. A detailed part of almost 6,000 faces now takes about a second instead of half a minute.
            Type points in the Line tool
            While drawing a line, type [x, y, z] to go to an exact position on the drawing axes, or <dx, dy, dz> to move relative to the start point. A component left blank keeps the start point's value, so [, , 2] goes straight up to a height of 2.
            Typed lengths that end right on an existing corner now land exactly on it, so a chain of typed lengths closes its face. The chain also keeps going when a segment touches existing edges, and only stops when you return to the first point.
            Typed points in the Line tool
            Smoother rendering
            Curved surfaces with smoothed edges, such as imported car bodies, now render smooth instead of showing their facets. Translucent materials painted on both sides of a face, like window glass, stay see-through when you look at them from the inside.
            Smooth shading and glass, 0.10 vs 0.11
            Fixes
            • Erasing a line drawn across a face rejoins the sides it split, so a rectangle is back to four edges.
            • Intersect Faces works on a loose box set on a slab, instead of failing with "overlapping interiors".
            • Union no longer fails for two boxes standing on the same floor, shifted against each other.
            • Extruding through a wall works where the far side is made of several faces, such as at a corner or where a partition meets the wall. A typed depth equal to the wall thickness now cuts cleanly through instead of leaving a thin skin.
            • Partitions in a floor plan can be extruded after the outer walls have been raised.
            • In a parallel-projection plan view, zooming in no longer hides the upper storeys.
            • When an extrusion or cut can't be made, the reason now shows in red in the status bar.
            Erasing a line drawn across a face, before and after
            Intersect Faces with a box set on a slab, before and after
            Extruding through a wall where a partition meets it, before and after
            Full release notes: https://modlumi.com/docs/release-notes/
            As always, bug reports and ideas are welcome here or through the feedback button in the app.
              What a reactivity! ๐Ÿ™‚
              But sorry this one is always a bug for me ! V 0.11
              • pixelcruncherP
                pixelcruncher Extension Creator @pilou
                @pilou Yikes, I thought I fixed this. Will have another look at this one. I'm already cooking up v0.12, so this will be fixed in v0.13 or later. Desktop release is also coming soon.
                Cheers,
                Thomas
                • pixelcruncherP
                  Fuck time to go to bed now ๐Ÿ™‚
                  Modlumi 0.12 is out: standard views, better image export, Make Unique and dimensions
                  Modlumi 0.12 is live at https://modlumi.com/app. A quick follow-up to 0.11 with a few things that make it easier to work from drawings and present a model.
                  Standard views and parallel projection
                  View > Standard Views turns the camera to Iso, Top, Bottom, Front, Back, Left or Right, keeping your zoom. View > Perspective and Parallel Projection switch the projection, and the choice is saved with the model. Handy for tracing a floor plan or checking a faรงade against an elevation drawing.
                  Save to Image with a size you choose
                  File > Save to Image now opens a dialog with size presets and a locked aspect ratio, so the picture no longer depends on your window size. The export leaves out selection highlights, tool previews and the axes. You can include guides and use a transparent background.
                  Make Unique
                  Select one or more component instances and choose Make Unique from the Edit or context menu. They get their own copy of the definition, named like Chair#2, so you can change them without touching the other instances.
                  Dimensions in Properties
                  Properties now shows the width, depth and height of the selected group or component, measured along its own axes in your model's units. With several objects selected it shows the size of all of them together.
                  Also
                  Undo now keeps the last 500 steps (fewer when they are very large), so memory stays bounded in long sessions.
                    Request : a "guide Line" by 2 any Snap Points in 3D Space or by "2 Guide points" or "By a Snap Point & a Guide Point" !
                    A "Perpendicular Snap" ๐Ÿ™‚
                    When you ask: Top View, Front etc... yes but with Zoom fit (Zoom extend) ! ๐Ÿ™‚
                      Very cool we can Group / Component the Guides lines! (Lines & Points)
                      but we can't add here for example a new created Point inside a Group or Component yet existing!
                      Like Select a Point drawn : Right Click Properties yes but no possibility to input in a Group / Component!
                      General : no possibility to explode a group / Component in the Outliner!
                        Seems we can't Delete guides lines saved & re loaded! (file linked)
                        And here the Triple Click don't select the 2 volumes! There are not Group or component !
                        Only a rectangle Lasso can all select! same file linked...
                        2pp.zip
                        • 6 / 6
