    Rayscaper New Releases
    rayscaperrender
    791 Posts 14 Posters 369.3k Views 15 Watching
    • KrassK
      Krass
      C'est extra, bravo!
      Right now, I'm learning how to work with Scatter. You have to remember to restart SketchUp sometimes after moving the hierarchy, groups, and so on. However, I can't get RS to recognize my texture changes when I edit them using the "edit in graphic editor" tool—it's as if a cached version is taking precedence...
      • KrassK
        Krass
        I can trim my lawn down to the last blade of grass.
        Now I need color variations.
        • KrassK
          Krass
          I've reached the limits of my graphics card, but I have a more powerful laptop—I'm going to test it out.
          • KrassK
            Krass
            no, it's not my graphic card. On the RTX laptop 4090? issue is still there
            • KrassK
              Krass
              if i hide the last scatter It's returning to normal.
              • KrassK
                Krass
                It's really good. It would be interesting to see how many polygons a project can handle. D5 Render stops rendering scattered objects at a certain distance to ease the load on the graphics card; I wonder how it works here?
                I struggled a bit with the green saturation of my lawn—I hadn't actually touched the texture itself. I just applied some desaturation and sharpening in Photoshop. Still, I’m blown away and really impressed.
                Aside from having an endless array of mind-blowing features, V-Ray feels clunky by comparison...
                A used ACES Filmic tonemap
                A tip (I don't think there's a batch render function yet): to render my two scenes and go to bed, I set up an animation render with the minimum frame rate and minimum duration. I ended up with just my two images—it was perfect.
                • pixelcruncherP
                  @Krass Thanks for the feedback! The final render looks very impressive.
                  Scatter renders huge dark flat shapes over the terrain.
                  Can you send me the scene so I can have a proper look?
                  Texture edits made with "Edit in graphic editor" aren't picked up. I filed this as a bug.
                  Will have a look, the other caching bug you reported should have been fixed.
                  Scatter needs a SketchUp restart after moving groups or changing the hierarchy.
                  Do you have something to reproduce this or a screen capture?
                  Save and load presets of the settings.
                  Planned
                  Color variation for scattered instances.
                  On the list.
                  Polygon limits and distant instances.
                  Rayscaper keeps every instance in the render and lets the GPU handle it, there's no distance cutoff or other tricks like in D5. Instances share their geometry, so the memory goes mostly to the components themselves, not the instance count. I'd like to hear where it breaks for you.
                  Cheers,
                  Thomas
                  • KrassK
                    Krass
                    Hello,
                    I am not certain that the bug—with the artifacts that appeared consistently—stems from the graphics card memory, because I was subsequently able to add a large, fairly resource-intensive grassy area without any issues. I am going to try to recreate the flowerbed that caused the problem.
                    • KrassK
                      Krass
                      this time, in he morning opening fresh model, it worked!. Mystery.
                      • KrassK
                        Krass
                        do you want the file anyway?
                        • KrassK
                          Krass
                          Hello,
                          There’s something that bothers me: the material rotation setting: you can no longer simply enter a value in degrees (unless I’m mistaken)—the slider is active. I find it hard to enter a precise value, especially 180...
                          • KrassK
                            Krass
                            SketchUp_4qMPyRU000.mp4
                            • KrassK
                              Krass
                              This post is deleted!
                              • KrassK
                                Krass
                                here, a strange behaviour : these trees are not scattered. Thir pivot point and they appear 10 meters further on.
                                • KrassK
                                  Krass
                                  Thomas,
                                  Rayscaper material presets library, glass, and metal are great, quality and time changer
                                  • pixelcruncherP
                                    @Krass Yup, that's a bug!
                                    • pixelcruncherP
                                      @Krass Can you send me the scene?
                                      • KrassK
                                        Krass
                                        Sorry for the delay. I sent you the project via the Rayscaper site's messaging system.
                                        • KrassK
                                          Krass
                                          I'm sending you the two projects, including the one where the trees are offset.
                                          • KrassK
                                            Krass
                                            I really need some help understanding the "mix material" feature; I'm completely lost. I've been reading the manual, but I've messed up my original texture... and I don't know how to undo it.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 39
                                            • 40
                                            • 26 / 40
