    Modlumi - Easy 3D modelling
    392 Posts 9 Posters 60.2k Views 9 Watching
      Some little regressions in Sweep! (or my little mine 🙂
      Little asks 🙂
      Functions Copy, Rotate + " *, / " oK... but...Scale + " * / " ?
      "Sweep" OK but... Sweep + Scale ?
        We can't name a curve ? If I make a group it can't be selected for make a sweep! (?)
        So the best solution is put the path out of the future structure for an easy selection! 🙂
        ntxdaveN 1 Reply Last reply
        • pixelcruncherP
          Merci pilou de faire connaître ModLumi et de partager tes créations ! Continue à me signaler les bugs que tu rencontres, ça m’aide beaucoup à améliorer l’application 🙂
          AI translated.
          Cheers,
          Thomas
          • pixelcruncherP
            Modlumi 0.3 is now live at https://modlumi.com/app/, with a ton of fixes and improvements, many of them based on your feedback in this thread. Thanks for all the reports and suggestions!
            Full release notes: https://modlumi.com/docs/release-notes/
            If you run into anything, use Report a Bug or Send Feedback in the app or reply here.
            • ntxdaveN
              ntxdave @pilou
              Couple of questions:
              • How did you draw this model?
              • How did you render this model?
              I do not see the ability render with the type of materials in your model. As an example, how did you make something look like it is metalic. The only thing I am seeing in the materials is colors and no ability to add any shin or roughtness.
              Press F1...thank me later
              • ntxdaveN
                ntxdave @pixelcruncher
                @pixelcruncher said:
                IN the release notes, I saw this:
                See a readable release number in the browser’s menu bar. Makes it easier to check whether the latest release is loaded. Original forum report
                When I look in the upper right part of the browser's menu bar, I keep am seeing 0.4 🙂
                • pixelcruncherP
                  @ntxdave Life's fast on the bleeding edge, I just released a new version 😉
                  • ntxdaveN
                    But I thought it was 0.3, not 0.4!
                    Pilou has been showing some really neat stuff in his posts but I do not understand how it is accomplishing some of it. In particular, how is he applying the textures he has been showing?
                    • pixelcruncherP
                      @ntxdave Those renders were not made by modlumi. He created the model in modlumi, and then used other software to render it.
                      • pixelcruncherP
                        Just released a new version (v0.6). This one has fillet/chamfer/bevel support. This feature is still experimental and may change. Feedback welcome!
                        • ntxdaveN
                          ntxdave
                          OK,
                          1. How do I update to the latest version or is it automatic when you run the app?
                          2. How do you control/enter the infor for the bevel options?
                          Never mind, you can delete this message. I just went back to the app and now see that it updated automatically.
                            @ntxdave How did you draw this model?
                            Draw any closed section
                            Draw an Arc CIrcle
                            Use the Sweep Section
                            (put the arc circle out of the Structure resultant like this you can reuse it for following!
                            Draw an internal Offset on one of face extremity
                            Use again the Sweep Function with this Offset!
                            (same the furniture above)
                            ""How did you render this model?"
                            I make a screen Snapshot (but you can use the Save Image Function of ModLumi ! ;°
                            Then send it to free Gemini where you can make any thing you want! https://gemini.google.com/app
                            Very simple prompts! (en français ! 😉
                            • effacer les axes, et mettre des personnages dans ces couloirs
                            • mettre de la couleurs sur la structure .
                            So In English! 🙂 the 2 Prompts were..
                            • erase the axes and place figures in these corridors
                            • add color to the structure
                              What do want more simple ? 🙂
                            If you have some problem I can make another gif animation! 😉
                            In fact modeling is quasi the same than inside SKetchUp !
                            E 1 Reply Last reply ♥
                              @pixelcruncher
                              Excellent seems you have resolved the Bug of 3D Snap Arc Circle ! Bravo!
                              Your Bevel, Fillet, Chamfer functions are a killer one!
                              Working from the first time! 🙂
                                Searching defaults 🙂
                                Reply Quote 2
                                  Seems when there are numerous elements, display changes ?
                                  Can we have a special display ? Here seems semi transparent!
                                  After an move or rotate element, (M) + Ctrl we can write * 3 or 3* 🙂
                                  • pixelcruncherP
                                    pixelcruncher Extension Creator @pilou
                                    Viewport is fixed in v7. Tracking the other one as a suggestion, it's more work.
                                    Cheers!
                                    Thomas
                                      Bug or not ?
                                      When Scale with CTRL ... no Copy of the original!
                                      • ntxdaveN
                                        ntxdave
                                        How do you create an array in Modlumi?
                                        • pixelcruncherP
                                          pixelcruncher Extension Creator @ntxdave
                                          @ntxdave
                                          • ntxdaveN
                                            ntxdave
                                            Thanks for the quick response. I think there must be a bunch of stuff like this that I am not understanding how to do in Modlumi.
                                            As an example, If I want to create a polygon with 8 sides instead of 6 (which is the default), how do I do it? I also sent you some other silly questions.
                                            • 19
                                            • 20
                                            • 3 / 20
