    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 587 Posters 12.0m Views 589 Watching
      MDVolle @Rienk
      @Rienk My plugins also stopped working correctly with the latest tools update - curviloft is not generating mesh and it appears that edge picker has a typo in it but I can't edit the code
      TIGT 1 Reply Last reply
        TIG Moderator @MDVolle
        @MDVolle
        Please explain what's not working, any errors, any Ruby Console errors etc.
        What is this 'typo' - tell us [ @fredo6 ] so he can fix it...
        • K
          kashintsev
          Hi @fredo6 and all,
          After two hours of trying to fix the Fredo update-check crash (spoiler — fixed it), here's what I found. Might be useful for pep75/Rienk/MDVolle above too, since it looks like the same class of issue.
          Setup: macOS 26.6, tested side-by-side across three SketchUp installs on the same Mac — SketchUp 2025, SketchUp 2026 and SketchUp 2027, each with its own LibFredo6 16.1a (+ FredoTools + JointPushPull) installed via Sketchucation Tools.
          Symptom (SketchUp 2025 and SketchUp 2026 — identical on both): the "Check Fredo6 Plugins for Update" dialog opens completely blank (no version table, no icon, nothing), and the Ruby Console shows:
          !LibFredo6: Error when requiring Binary .../Fredo6_!LibFredo6/Binaries/Mac_32/bin_body_Lib6G6.bundle - dlopen(...) tried: '.../bin_body_Lib6G6.bundle' (code signature invalid in <...> '.../bin_body_Lib6G6.bundle' (errno=1) sliceOffset=0x00054000, codeBlobOffset=0x000500B0, codeBlobSize=0x00004CE0), ... - .../bin_body_Lib6G6.bundle
          #<NoMethodError: undefined method register_from_key' for Traductor::ChromiumWdlg:Class> .../body_lib6chromiumwdlg.rbe:1498:in show'
          .../body_lib6upgrade.rbe:864:in initialize__' .../lib6upgrade.rbe:161:in initialize'
          .../lib6upgrade.rbe:154:in new' .../lib6upgrade.rbe:154:in show'
          .../lib6upgrade.rbe:66:in time_for_check?' .../top_libfredo6.rbe:514:in block in after_startup'
          So the update dialog can't fully init because the ChromiumWdlg engine's native module (bin_body_Lib6G6.bundle) fails to dlopen — macOS rejects its code signature at runtime.
          Important: SketchUp 2027, with the literal same LibFredo6 16.1a files, has no problem at all — dialog renders fine, no console errors. So this doesn't look like a corrupted download or a bad LibFredo6 build; it looks like SketchUp 2025/2026 vs. 2027 differ in how they enforce code-signing/library validation for third-party native bundles at dlopen time.
          What did NOT fix it (ruling out a leftover-config issue on my end):
          1. Fully quit SketchUp.
          2. Removed every Fredo6 folder + .rb loader from Plugins (LibFredo6, FredoTools, JointPushPull).
          3. Deleted every orphaned Fredo6 key from the SketchUp prefs plist (ALToolPalette_Fredo6_, Fredo6_CheckForUpdateWarning.) — leftovers from older Fredo tools removed previously.
          4. Reinstalled LibFredo6 16.1a completely fresh via Sketchucation Tools.
            Exact same blank dialog / same console error on the totally clean install.
          What DID fix it (local workaround): re-signing every .bundle under Fredo6_!LibFredo6/Binaries with a local ad-hoc signature:
          find ".../Fredo6_!LibFredo6/Binaries" -name "*.bundle" -exec codesign --force --deep --sign - {} ;
          After this, the dialog renders completely and the console is clean. codesign -dv on the original file actually reported the signature as valid (TeamIdentifier 66M89AU23J, properly signed 31 Aug 2026) — it's specifically the runtime dlopen/library-validation check inside SketchUp 2025/2026 that rejects it, not a malformed file.
          This is obviously just a workaround I have to redo after every LibFredo6 update/reinstall, not a real fix — posting in case it helps track down why 2025/2026 reject it while 2027 doesn't.
          • fredo6F
            @kashintsev
            Thanks for the description.
            For whatever reason, the .bundle binary files fail to load for a question of signing and this only concerns SU2026. Note that in SU2027, the .bundle has the same name but is different, as it is for Ruby 3.4, versus Ruby 3.2 for SU2026).
            Could you try with LibFredo6 v16.1g, just published and advise if this gets better.
            D 1 Reply Last reply
            • fredo6F
              NEW RELEASE: LibFredo6 v16.1g - 11 Sep 26
              LibFredo6 16.1g is a maintenance release. It includes changes related to:
              • Future compatibility (SU2027)
              • Bug Fixing for Mac in SU2026
              • fredo6F
                NEW RELEASE: LibFredo6 v162a - 22 Sep 26
                LibFredo6 162a is a maintenance release. It includes changes related to:
                • Adjustments for compatibility SU2027
                • Bug Fixing
                If you use LordOfTheToolbars, please upgrade it to v4.0a. Otherwise, LOTT will not be activated
                • fredo6F
                  NEW RELEASE: LibFredo6 v16.2b - 22 Sep 26
                  LibFredo6 16.2b is a maintenance release. It includes changes related to:
                  • Bug Fixing
                  If you use LordOfTheToolbars, please upgrade it to LordOfTheToolbars v4.0a. Otherwise, LOTT will not be activated
                  • E
                    epetit91
                    Help,
                    none of the plugins I purchased licenses for are working anymore !!!
                    Last LibFredo6 installed : LibFredo6 - v16.2b
                      TIG Moderator @epetit91
                      @epetit91
                      Do you have the latest SketchUcation toolset installed, it manages the licenses.
                      Which extensions are the problem ?
                      What happens when you try to run them ?
                      What error messages or dialogs /
                      Is the extension's licensing report OK ?
                      • E
                        epetit91
                        SketchUcationTools V5.0.8 installed
                        Fredo6_Curviloft, Fredo6_JointPushPull, Fredo6_RoundCorner, Fredo6_FredoTools : nothing appends when I choice one of this tools.
                        The extension's licensing report is OK
                        • E
                          epetit91
                          All was OK before the last Fredo6_!LibFredo6 update !!!
                          • E
                            epetit91
                            When I run "Check for Updates" for LibFredo6-Configuration, nothing happens.
                            • E
                              epetit91
                              SketchUcation toolset installed : 5.0.8
                              Extensions : Fredo6_Curviloft, Fredo6_FredoTools, Fredo6_JointPushPull, Fredo6_RoundCorner
                              When I run, nothing happens (no dialogs errors).
                              All license are OK
                              When I run the Ruby Console and execute the Corner plugin, for example, this is what I get :
                              Error: #<NoMethodError: undefined method plugin_list' for Traductor::Scanning:Class> /var/folders/wr/cl77xmh96bbdjh00dl5shws00000gn/T/com.sketchup.SketchUp.2017.eric/Fredo6_LibFredo6_TemporaryFiles/data6.rb:20:in launch_action'
                              /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:244:in launch_action' /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_roundcorner/bootstrap_roundcorner.rbe:81:in launch_action'
                              /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_roundcorner/bootstrap_roundcorner.rbe:96:in block in startup' /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1463:in call'
                              /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1463:in command_invoke' /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1443:in block (2 levels) in build_config_commands'
                              /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1573:in call' /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1573:in block in add_command'
                              SketchUp:1:in `call'
                              • B
                                Bublifuk21
                                Hi, I have a problem. I would like to add Fredoscale plugin, which works with LibFredo6 15.9 or higher. My latest LibFredo6 is 15.8 and all your plugins works perfectly. After installation the newest 16.2 version, no one plugins works. I see icons, they have a color, but do not works. What should I do to fix it? Thank you very much.
                                  @epetit91
                                  You are on a MAC ?
                                  Does the error msg's folder exist:
                                  If so what are its contents ?
                                  E 2 Replies Last reply
                                  • B
                                    Bublifuk21
                                    No, I have standard Windows 7 Ultimate. All Fredo plugins works well with LibFredo 15.8. But Fredo Scale works only with LibFredo 15.9 or higher. So I downloaded the newest LibFredo 16.2 and everything stop to work. I see icons, but they are inactive. One picture is with installed libFredo 15.8 and function plugins, another one is with LiFredo 16.2 I can see also FredoScale icons, but no plugin is working
                                      @bublifuk21
                                      That OS question wasn't directed to you.
                                      But your super-old Windows version installation is likely to cause issues - I'm surprised it's worked well up to now...
                                      @fredo6 will undoubtedly have some to add...
                                      • fredo6F
                                        When you have issues with the installation of LibFredo6, can you report the utput of the command menu: Window > LibFredo6 Settings > Fredo6 Plugin Information for Sketchucation Support
                                        This just tells what is your configuration in terms of version installed, Sketchup version, platform, etc...
                                        Otherwise, it is very difficult to help.
                                        • E
                                          epetit91 @TIG
                                          Yes, I am on Mac (MacOS 10.12.6)
                                          I have been using Fredo plugins since 2022 and have never encountered a single problem. This issue only appeared after the latest update to FredoLib.
                                          TThe contents of the /var/folders/wr/cl77xmh96bbdjh00dl5shws00000gn/T/com.sketchup.SketchUp.2017.eric/Fredo6_LibFredo6_TemporaryFiles: folder is as follow :
                                          drwxr-xr-x 6 eric staff 204 30 sep 08:07 .
                                          drwxr-xr-x 10 eric staff 340 30 sep 09:01 ..
                                          drwxr-xr-x 2 eric staff 68 29 sep 21:11 Images
                                          drwxr-xr-x 2 eric staff 68 29 sep 21:11 LibFredo6_Textures
                                          drwxr-xr-x 27 eric staff 918 30 sep 08:57 Traces
                                          -rw-r--r-- 1 eric staff 3988 30 sep 08:57 data6.rb
                                            @fredo ?
                                            • 111
                                            • 112
                                            • 113
                                            • 114
                                            • 115
                                            • 113 / 115
