[Plugin Library] LibFredo6 - v16.3a - 20 Oct 26
Help,
none of the plugins I purchased licenses for are working anymore !!!
Last LibFredo6 installed : LibFredo6 - v16.2b -
Do you have the latest SketchUcation toolset installed, it manages the licenses.
Which extensions are the problem ?
What happens when you try to run them ?
What error messages or dialogs /
Is the extension's licensing report OK ? -
SketchUcationTools V5.0.8 installed
Fredo6_Curviloft, Fredo6_JointPushPull, Fredo6_RoundCorner, Fredo6_FredoTools : nothing appends when I choice one of this tools.
The extension's licensing report is OK -
All was OK before the last Fredo6_!LibFredo6 update !!!
When I run "Check for Updates" for LibFredo6-Configuration, nothing happens.
SketchUcation toolset installed : 5.0.8
Extensions : Fredo6_Curviloft, Fredo6_FredoTools, Fredo6_JointPushPull, Fredo6_RoundCorner
When I run, nothing happens (no dialogs errors).
All license are OKWhen I run the Ruby Console and execute the Corner plugin, for example, this is what I get :
Error: #<NoMethodError: undefined methodplugin_list' for Traductor::Scanning:Class> /var/folders/wr/cl77xmh96bbdjh00dl5shws00000gn/T/com.sketchup.SketchUp.2017.eric/Fredo6_LibFredo6_TemporaryFiles/data6.rb:20:inlaunch_action'
/users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:244:inlaunch_action' /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_roundcorner/bootstrap_roundcorner.rbe:81:inlaunch_action'
/users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_roundcorner/bootstrap_roundcorner.rbe:96:inblock in startup' /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1463:incall'
/users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1463:incommand_invoke' /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1443:inblock (2 levels) in build_config_commands'
/users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1573:incall' /users/eric/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1573:inblock in add_command'
SketchUp:1:in `call' -
Hi, I have a problem. I would like to add Fredoscale plugin, which works with LibFredo6 15.9 or higher. My latest LibFredo6 is 15.8 and all your plugins works perfectly. After installation the newest 16.2 version, no one plugins works. I see icons, they have a color, but do not works. What should I do to fix it? Thank you very much.
@epetit91
You are on a MAC ?
Does the error msg's folder exist:
If so what are its contents ? -
No, I have standard Windows 7 Ultimate. All Fredo plugins works well with LibFredo 15.8. But Fredo Scale works only with LibFredo 15.9 or higher. So I downloaded the newest LibFredo 16.2 and everything stop to work. I see icons, but they are inactive. One picture is with installed libFredo 15.8 and function plugins, another one is with LiFredo 16.2 I can see also FredoScale icons, but no plugin is working
@bublifuk21
That OS question wasn't directed to you.
But your super-old Windows version installation is likely to cause issues - I'm surprised it's worked well up to now...
@fredo6 will undoubtedly have some to add... -
When you have issues with the installation of LibFredo6, can you report the utput of the command menu: Window > LibFredo6 Settings > Fredo6 Plugin Information for Sketchucation Support
This just tells what is your configuration in terms of version installed, Sketchup version, platform, etc...
Otherwise, it is very difficult to help.
Yes, I am on Mac (MacOS 10.12.6)
I have been using Fredo plugins since 2022 and have never encountered a single problem. This issue only appeared after the latest update to FredoLib.
TThe contents of the /var/folders/wr/cl77xmh96bbdjh00dl5shws00000gn/T/com.sketchup.SketchUp.2017.eric/Fredo6_LibFredo6_TemporaryFiles: folder is as follow :drwxr-xr-x 6 eric staff 204 30 sep 08:07 .
drwxr-xr-x 10 eric staff 340 30 sep 09:01 ..
drwxr-xr-x 2 eric staff 68 29 sep 21:11 Images
drwxr-xr-x 2 eric staff 68 29 sep 21:11 LibFredo6_Textures
drwxr-xr-x 27 eric staff 918 30 sep 08:57 Traces
-rw-r--r-- 1 eric staff 3988 30 sep 08:57 data6.rb -
@fredo ?
@TIG I restored LibFredo 15.8e, and everything is working perfectly again. The problem definitely stems from the latest version, 16.
@TIG To summarize: everything works perfectly up to version 16.1a.
With version 16.1g, SketchUp crashes.
With version 16.2a/b, no plugins work. -
@fredo6 ??
@epetit91 it might be that since you are still using SketchUp 2017 you'll need to stop updating.
Again, please report the output of the command menu: Window > LibFredo6 Settings > Fredo6 Plugin Information for Sketchucation Support. Otherwise, there is no way to make any diagnostics.
It also does not work with 16.1. version. Here is my report:
Fredo6 Plugins Information on 2026-10-01 14:52:46 +0200
- Platform: x64-mingw32 - Ruby: 2.2.4
- Sketchup: 17.2.2555
- LibFredo6: v16.1g
- LibFredo6 G6 Binary loaded
- LibFredo6 E6 Binary NOT loaded
- Sketchucation Tools: 5.0.8
- SCFLicense: v7.5a - 80
- Fredo6 Plugins
Curviloft v2.0a - licensed FULL: 262837 - HE1772082497.0K
FredoScale v3.7c
JointPushPull v4.9a - licensed FULL: 263124 - HE1772082497.0K
RoundCorner v3.3a - licensed FULL: 263401 - HE1772082497.0K - SCFLicense directory present
Signature File: 2026-02-26 06:08:17 +0100
Curviloft: 2026-02-26 06:08:26 +0100
JointPushPull: 2026-02-26 10:15:01 +0100
RoundCorner: 2026-03-02 12:08:45 +0100
