    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 725.8k Views 99 Watching
      jfish101
      Hello @fredo6
      I am using SU 2026 26.2.243 64-bit on Windows 10 Pro with LOTT 3.0c
      I am trying to create a Personal Command for a Menu item, but when I start this process, no choices display in the Menu section of the window. Even when I try to search for a menu item, no choices display. The Menu portion of the window is blank.
      Is this a known bug?
      • fredo6F
        Menus Commands are no longer available on Windows since SU2023. This is due to a change of UI framewrok (Qt) in Sketchup.
        Dave RD 1 Reply Last reply
          Dave R @fredo6
          @fredo6 you have had to repeat this numerous times in this thread but since new responders don't seem to read it, perhaps they would see it if you put it in the first few lines of the original post? 😉
            Dalle Newcomers
            FOLLOWING PROBLEM IS NOW SOLVED
            Hello @fredo6,
            I'm using your plugin for several months and It is useful tool. Thank you.
            Unfortunately, there seems to be a problem as of today. It doesn't load as it used to.
            There is no Vignette Stripe and instead I have this:
            According to the Extension Manager, it seems good:
            But there's a new !LordOfTheToolbars_seed that seems to have appeared and appears to have a problem:
            I use Sketchup 2024, with LordOfTheToolbars_v2.9c and LibFredo6_v15.2a.
            Since, I tried to fix the problem, uninstalling the plugins and replacing them by the last versions, LordOfTheToolbars_v3.0c and LibFredo6_v16.0b.
            And my Loading Policy is set on Unrestricted since forever.
            The problem remains.
            May I ask for your help, please?
            EDIT: I installed SketchUp 2026 with all plugins and the problem remains 😞
            EDIT #2: I updated LibFredo6 with version: 16.1a. Problem is now solved. Thank you 🙂
            • fredo6F
              NEW RELEASE: LordOfTheToolbars v4.0a - 22 Sep 26
              Requirements
              • LibFredo6: v16.2a or above
              LordOfTheToolbars 4.0a is a maintenance release including:
              • Compatibility SU2027
              • Bug fixing
              Home Page of LordOfTheToolbars for information and Download.
              Main post of this LordOfTheToolbars thread.
              • H
                Horizon41
                Hi, I am having an issue with the toolbars not adjusting to the content. When I adjust it, it goes back to missing the last tab. The version before adjusted automatically if you were partially over the last tab. I cannot find any related settings. I did try removing the sticky to sketchup window options. Thanks
                • H
                  Horizon41
                  Hi, thought I had solved the auto adjusting of palettes, but I have re-checked auto adjust on all toolbars and they are not adjusting to show last tab. I am also not able to move palettes even though I have user defined checked in prefs
                  • fredo6F
                    Could you check the effective version of LibFredo6, as there has been some issues on the Sketchucation server side.
                    Use menu Window > LibFredo6 Settings... > About LibFredo6... You should see v6.2a or 6.2b.
                    H 1 Reply Last reply
                    • H
                      Horizon41
                      Hi, the Library is 6.2b. I am not sure about how to use the Ruby Console to check for errors. I tried leaving it on and restarting sketchup. I am using sketchup pro 21. Everything was ok with the previous version of the Toolbar. Thanks
                      • H
                        Horizon41 @fredo6
                        @fredo6 Hi, I checked the Fredo library and it is correct. I am not sure about how the Ruby + Console works. I tried leaving it open and there are warnings, but I cannot see any mention of LOTT. See below, for 1st console page which contains links that go to a lot of code in the console
                        "Add help menu!"
                        "create new"
                        "created"
                        #Sketchup::Menu:0x000001f0e18eddd8
                        (eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                        internal:warning:43:in warn' <internal:warning>:43:in warn'
                        …/rubygems/core_ext/kernel_warn.rb:52:in call' …/rubygems/core_ext/kernel_warn.rb:52:in block in module:Kernel'
                        …/open-uri.rb:18:in open' (eval):23:in pull'
                        (eval):203:in `block in module:Notification'
                          @horizon41
                          The current version is 16.2b - perhaps you made a typo ? You need to restart SketchUp after installing any extension so it is properly synced.
                          Please post the whole error message - part is not sufficient - in the Ruby Console -Ctrl+A to Select All then Ctrl+V to Paste that into your message here...
                          • H
                            Horizon41
                            Thanks I have restarted each time, after several reinstalls. There is definitely an issue. I was trying to do a clean install. Maybe I need to track down some sort of cache or config file that might be corrupt, it appears to revert to the last backup. Here is the full console message.
                            Editor Clear
                            Console
                            Help Select Menu
                            "Add help menu!"
                            "create new"
                            "created"
                            #Sketchup::Menu:0x0000020f29900cb0
                            • H
                              Horizon41
                              I can confirm Library is 16.2b
                                The open v. URI.open deprecation issue has been around for quite along time.
                                Any developer using it will have rewritten their code to sidestep that issue and use the current 'safe' methods...
                                I can't believe that Fredo has left this 'hanging' - so have you perhaps got some now incorrect older legacy Fredo files loading, which could confuse the situation ?
                                Fredo might have some ideas as to what files to look for ??
                                @fredo6 do6 ?
                                • fredo6F
                                  Did you upgrade Sketchucation tools to 5.0.8 ?
                                    @fredo6
                                    Question: why is there an open v. UI.open error message at all ?
                                    I sure you will have trapped for that long ago after the versions' Ruby changes ?
                                    Could he have a rogue file hanging around in one of your subfolders which is somehow loading a spurious old deprecated method ?
                                    • fredo6F
                                      LibFredo6 does not use URI.open anyway.
                                      • fredo6F
                                        @horizon41
                                        Do you still have the problem of height adjustment with LOTT?
                                        • H
                                          Horizon41
                                          Yes. I have checked all my drivers. Updated 3d Connex and Nvidia RTX. I also did a repair/install on sketchup. I uninstalled and reinstalled LOTT. NB it did reinstate the last toolbar configuration. The same problems are there. I suspect the auto adjust palletes may be the issue. I am using the default hover mode and if I hover and click the tab that pallete moves to below the Sketchup Top Toolbar about 20mm below the main LOTT. 1 pallette moves directly beneath the LOTT. I cannot move the order of the tabs in the LOTT and I cannot move any of the palletes. Some of the toolbars are not showing all the tabs and I can adjust (not move) to show but it forgets this regardless of whether auto adjust is selected.
                                          Is it possible for me to try reinstalling the previous version? I did not save it. Thanks
                                            So a weird message - a rogue older Lib6Traductor ot similar that might load and add a spurious old method ?
                                            I assume that you you checked the expected code with a 'find' by line to see if a raw 'open' ever gets called - by mistake [e.g. a typo] - and there by the error can mistakenly assume that UI.open was the intention ?
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 26 / 28
