    [Plugin Library] LibFredo6 - v16.3a - 20 Oct 26
    2.3k Posts 587 Posters 11.9m Views 589 Watching
      If you look at your error message it references SUClock 2.0
      1 Reply Last reply πŸ‘
      • pep75P
        pep75
        Thanks, but it also refers to Libfredo6. πŸ˜•
        • fredo6F
          NEW RELEASE: LibFredo6 v16.1a - 31 Aug 26
          LibFredo6 16.1a is a maintenance release. It includes changes related to:
          • Future compatibility (SU2027)
          • Bug Fixing, possibly for Mac
          RienkR 1 Reply Last reply
          • RienkR
            Rienk @fredo6
            @fredo6
            Hi Fredo since today 2 september I updated version LibFredo6 V16.0a 8 aug 2026 to the latest LibFredo6 V16.1a but all your plugins dont work anymore. Where can I find the prior version. I would love to get this old one. Because this version workes for me fine. I was working with curviloft and since the latest version it don't work.
            I am working on the PC with SketchUp 2026. There is no error message but it does nothing. I tried several times to start SkectUp but it still doesn't do nothing.
            I tried several of your plugins but they doesnt start
            With regars,
            Rienk
            M 1 Reply Last reply
            • fredo6F
              When you start Sketchup, do you see the menus for the plugins. Do you see the menu Window > LibFredo6 settings.....?
              RienkR 2 Replies Last reply
              • RienkR
                Rienk
                Yes you mean the window check Fredo6 Plugins for Update?
                • RienkR
                  Rienk @fredo6
                  • RienkR
                    Rienk @fredo6
                    @fredo6
                    You mean the dialog window "check Fredo6 Plugins for Update?
                    I started SketchUp again and It seems to work fine with your plugins.
                    Thanks for your reply.
                    Rienk
                      MDVolle @Rienk
                      @Rienk My plugins also stopped working correctly with the latest tools update - curviloft is not generating mesh and it appears that edge picker has a typo in it but I can't edit the code
                      TIGT 1 Reply Last reply
                        TIG Moderator @MDVolle
                        @MDVolle
                        Please explain what's not working, any errors, any Ruby Console errors etc.
                        What is this 'typo' - tell us [ @fredo6 ] so he can fix it...
                        • K
                          kashintsev
                          Hi @fredo6 and all,
                          After two hours of trying to fix the Fredo update-check crash (spoiler β€” fixed it), here's what I found. Might be useful for pep75/Rienk/MDVolle above too, since it looks like the same class of issue.
                          Setup: macOS 26.6, tested side-by-side across three SketchUp installs on the same Mac β€” SketchUp 2025, SketchUp 2026 and SketchUp 2027, each with its own LibFredo6 16.1a (+ FredoTools + JointPushPull) installed via Sketchucation Tools.
                          Symptom (SketchUp 2025 and SketchUp 2026 β€” identical on both): the "Check Fredo6 Plugins for Update" dialog opens completely blank (no version table, no icon, nothing), and the Ruby Console shows:
                          !LibFredo6: Error when requiring Binary .../Fredo6_!LibFredo6/Binaries/Mac_32/bin_body_Lib6G6.bundle - dlopen(...) tried: '.../bin_body_Lib6G6.bundle' (code signature invalid in <...> '.../bin_body_Lib6G6.bundle' (errno=1) sliceOffset=0x00054000, codeBlobOffset=0x000500B0, codeBlobSize=0x00004CE0), ... - .../bin_body_Lib6G6.bundle
                          #<NoMethodError: undefined method register_from_key' for Traductor::ChromiumWdlg:Class> .../body_lib6chromiumwdlg.rbe:1498:in show'
                          .../body_lib6upgrade.rbe:864:in initialize__' .../lib6upgrade.rbe:161:in initialize'
                          .../lib6upgrade.rbe:154:in new' .../lib6upgrade.rbe:154:in show'
                          .../lib6upgrade.rbe:66:in time_for_check?' .../top_libfredo6.rbe:514:in block in after_startup'
                          So the update dialog can't fully init because the ChromiumWdlg engine's native module (bin_body_Lib6G6.bundle) fails to dlopen β€” macOS rejects its code signature at runtime.
                          Important: SketchUp 2027, with the literal same LibFredo6 16.1a files, has no problem at all β€” dialog renders fine, no console errors. So this doesn't look like a corrupted download or a bad LibFredo6 build; it looks like SketchUp 2025/2026 vs. 2027 differ in how they enforce code-signing/library validation for third-party native bundles at dlopen time.
                          What did NOT fix it (ruling out a leftover-config issue on my end):
                          1. Fully quit SketchUp.
                          2. Removed every Fredo6 folder + .rb loader from Plugins (LibFredo6, FredoTools, JointPushPull).
                          3. Deleted every orphaned Fredo6 key from the SketchUp prefs plist (ALToolPalette_Fredo6_, Fredo6_CheckForUpdateWarning.) β€” leftovers from older Fredo tools removed previously.
                          4. Reinstalled LibFredo6 16.1a completely fresh via Sketchucation Tools.
                            Exact same blank dialog / same console error on the totally clean install.
                          What DID fix it (local workaround): re-signing every .bundle under Fredo6_!LibFredo6/Binaries with a local ad-hoc signature:
                          find ".../Fredo6_!LibFredo6/Binaries" -name "*.bundle" -exec codesign --force --deep --sign - {} ;
                          After this, the dialog renders completely and the console is clean. codesign -dv on the original file actually reported the signature as valid (TeamIdentifier 66M89AU23J, properly signed 31 Aug 2026) β€” it's specifically the runtime dlopen/library-validation check inside SketchUp 2025/2026 that rejects it, not a malformed file.
                          This is obviously just a workaround I have to redo after every LibFredo6 update/reinstall, not a real fix β€” posting in case it helps track down why 2025/2026 reject it while 2027 doesn't.
                          • fredo6F
                            @kashintsev
                            Thanks for the description.
                            For whatever reason, the .bundle binary files fail to load for a question of signing and this only concerns SU2026. Note that in SU2027, the .bundle has the same name but is different, as it is for Ruby 3.4, versus Ruby 3.2 for SU2026).
                            Could you try with LibFredo6 v16.1g, just published and advise if this gets better.
                            D 1 Reply Last reply
                            • fredo6F
                              NEW RELEASE: LibFredo6 v16.1g - 11 Sep 26
                              LibFredo6 16.1g is a maintenance release. It includes changes related to:
                              • Bug Fixing for Mac in SU2026
                              • fredo6F
                                NEW RELEASE: LibFredo6 v162a - 22 Sep 26
                                LibFredo6 162a is a maintenance release. It includes changes related to:
                                • Adjustments for compatibility SU2027
                                • Bug Fixing
                                If you use LordOfTheToolbars, please upgrade it to v4.0a. Otherwise, LOTT will not be activated
                                • fredo6F
                                  NEW RELEASE: LibFredo6 v16.2b - 22 Sep 26
                                  LibFredo6 16.2b is a maintenance release. It includes changes related to:
                                  • Bug Fixing
                                  If you use LordOfTheToolbars, please upgrade it to LordOfTheToolbars v4.0a. Otherwise, LOTT will not be activated
                                  • E
                                    epetit91
                                    Help,
                                    none of the plugins I purchased licenses for are working anymore !!!
                                    Last LibFredo6 installed : LibFredo6 - v16.2b
                                      TIG Moderator @epetit91
                                      @epetit91
                                      Do you have the latest SketchUcation toolset installed, it manages the licenses.
                                      Which extensions are the problem ?
                                      What happens when you try to run them ?
                                      What error messages or dialogs /
                                      Is the extension's licensing report OK ?
                                      • E
                                        epetit91
                                        SketchUcationTools V5.0.8 installed
                                        Fredo6_Curviloft, Fredo6_JointPushPull, Fredo6_RoundCorner, Fredo6_FredoTools : nothing appends when I choice one of this tools.
                                        The extension's licensing report is OK
                                        • E
                                          epetit91
                                          All was OK before the last Fredo6_!LibFredo6 update !!!
                                          • E
                                            epetit91
                                            When I run "Check for Updates" for LibFredo6-Configuration, nothing happens.
                                            • 110
                                            • 111
                                            • 112
                                            • 113
                                            • 114
                                            • 112 / 114
