    Curviloft not working on Mac with SU2026g
    16 Posts 4 Posters 762 Views 4 Watching
      mbennett2022 Newcomers
      I have been trying to use Curvioloft on a Mac OS26.5.2 with SU2026 without success. I have tried reinstalling LibFredo and Curviloft directly from the Sketchucation extension store. The ruby console error that I receive is as follows:
      #<NameError: undefined local variable or method `accept_current_selection' for #<Traductor::EdgePicker:0x00000001372955d0>>
      /users/mattbennett/library/application support/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:555:in `notify_action'
      /users/mattbennett/library/application support/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:586:in `terminate_current_selection'
      /users/mattbennett/library/application support/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:747:in `notify_from_vbox'
      /users/mattbennett/library/application support/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:3996:in `call'
      /users/mattbennett/library/application support/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:3996:in `onLButtonUp'
      /users/mattbennett/library/application support/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:2491:in `onLButtonUp'
      /users/mattbennett/library/application support/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:1154:in `onLButtonUp'
      /users/mattbennett/library/application support/sketchup 2026/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:510:in `onLButtonUp'
      Any ideas on how to resolve this?
      TIGT 1 Reply Last reply
      • fredo6F
        Could you first report the summary of your installation, using menu Window > LibFredo6 Settings... > Fredo6 Plugins Information for Sketchucation Support.
        It looks like there is a wrong installation of LibFredo6.
          TIG Moderator @mbennett2022
          @mbennett2022 As Fredo says, please supply the detailed report.
          However, you could just try installing the newest version of LibFredo6, and then restarting SketchUp to see if that error recurs...
            ALLOUIS Newcomers
            I’ve got the same problem with all my Fredo6 plugins
              ALLOUIS Newcomers
              This post is deleted!
                ALLOUIS Newcomers
                J'ai installé le dernier LibFredo6. Mes plugins Fredo6 ne marchent plus depuis hier... J'ai désinstallé et réinstallé trois fois la totalité des plugins plus LibFredo6 et rien.... voici le rapport que j'obtiens:
                Fredo6 Plugins Information on 2026-08-29 03:28:56 +0200
                • Platform: arm64-darwin - Ruby: 3.2.2
                • Sketchup: 26.1.188
                • LibFredo6: v16.0b
                • LibFredo6 Binary NOT loaded
                • Sketchucation Tools: 5.0.7
                • SCFLicense: v7.3b - 72
                • Fredo6 Plugins
                  Curviloft v2.0a - licensed FULL: 279907 - OX1787922096.0N
                  Curvizard v2.5a - licensed FULL: 279910 - OX1787922096.0N
                  FredoScale v3.7c - licensed FULL: 279908 - OX1787922096.0N
                  FredoSpline v2.6a - licensed FULL: 279920 - OX1787922096.0N
                  JointPushPull v4.9a - licensed FULL: 279906 - OX1787922096.0N
                  RoundCorner v3.4a - licensed FULL: 279905 - OX1787922096.0N
                  ToolsOnSurface v2.6a - licensed FULL: 279912 - OX1787922096.0N
                  TopoShaper v2.7b - licensed FULL: 279909 - OX1787922096.0N
                  VisuHole v1.5a - licensed FULL: 279911 - OX1787922096.0N
                  #<NoMethodError: undefined method get_system_dir' for LibFredo6:Module> /users/al/library/application support/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:875:in info'
                  /users/al/library/application support/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:372:in block in populate_support_menu' /users/al/library/application support/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1573:in block in add_command'
                  LibFredo6: v16.0b
                  LibFredo6 Binary NOT loaded...
                  I'm sure that @fredo6 will comment in much more detail - however, from a cursory glance at the data the LibFredo6 is current, BUT its binary is NOT loading on your MAC ??
                  How did you install that Lib ?
                  • fredo6F
                    I need to understand why the binary file does not LOAD. No need to reinstall my plugins apart from LibFredo6.
                    Did you download and install the LibFredo6 rbz on Mac, or is it replicated from another computer?
                    • fredo6F
                      Actually, I do not know how you install plugins. But could you first delete the folder Fredo6_!LibFredo6 before reinstalling LibFredo6. It may contain some invalid files, we never know.
                        ALLOUIS Newcomers
                        To begin with, I used your plugins for two or three days and they worked very well. But suddenly they stopped working. I should point out that I haven’t installed anything else… apart from other extensions. Perhaps one of them is causing a conflict with yours?… To try and fix it, I first tried uninstalling the plugins and LibFredo6 via the extension manager and reinstalling them via the manager… Didn’t work… I uninstalled and redownloaded the plugins and the Lib, then reinstalled everything… Didn’t work… I uninstalled them again, went into the library’s support app to delete everything in the “Fredo6” folder. And I started reinstalling everything all over again… nothing. I should point out that I downloaded the library from your page on Sketchucation… so that’s not the problem…. I’m wondering if, as I said, it might be another plugin I got from the Warehouse that’s causing the trouble…
                        Translated with DeepL.com (free version)
                          ALLOUIS Newcomers
                          No matter how many times I re-download LibFredo6_v16.0b from Sketchucation, it doesn’t work. What’s more, the windows I open in SketchUp via Window/LibFredo6 are blank…
                            Did you close SketchUp completely and go into your Plugins folder and then delete the subfolder Fredo6_!LibFredo6 before reinstalling LibFredo6 ?
                              ALLOUIS Newcomers
                              Yes! I think I’ll try reinstalling SketchUp..... Maybe.....
                                ALLOUIS Newcomers
                                  ALLOUIS Newcomers
                                  Yes, I did. And I’ve just reinstalled SketchUp and it still isn’t working…
                                    Let's wait for Fredo - Monday 31st is a holiday in the UK, but I don't think it is is France....
