    [Plugin][Code]SKMtools,Material/ImageTools
    178 Posts 37 Posters 296.7k Views 37 Watching
    • E Offline
      Efik_CZme Newcomers
      Just reinstalled SketchUp... As and administrator. Still the same story.
        amckeag
        I'm experiencing similar issues - I can get ImageTrimmer to run. The extension creates a temporary "TrimmedImage" folder and all of the .jar files are in the correct folder. However, it never proceeds to "Make Component Stand Up" and beyond. Any ideas how to fix?
          Hard to say with no more information. Share the .skp file with us so we can see what you are working with. What do you see if you run the extension with the Ruby Console open?
          Are you still using SketchUp 2019 on Mac? Which operating system?
            amckeag
            I'm using SU 2022. I'll update my profile. Here's what the Ruby Console returns:
            Error: #<Errno::ENOENT: No such file or directory @ rb_sysopen - C:\Users\amXXXX\OneDrive\Desktop\TrimmedImages\2[Edges].dat>
            C:/Users/amckeag/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:277:in readlines' C:/Users/amckeag/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:277:in make_edges'
            C:/Users/amckeag/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:201:in process_image' C:/Users/amckeag/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:170:in initialize'
            C:/Users/amckeag/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:834:in new' C:/Users/amckeag/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:834:in block in <top (required)>'
            "Add help menu!"
            "create new"
            "created"
            #Sketchup::Menu:0x0000025595434c60
            (eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
              The 'edges' .dat file in the subfolder is made by the .jar applets.
              If the file doesn't exist then something is preventing this...
              Possibilities include -
              The .jar files are not properly associated to be run by Java - e.g. that file-type is hijacked by your compression-software settings
              You/SketchUp do not having permission to make the subfolder and files in the location of the model's SKP.
              I notice the path in the error has 'OneDrive' in it - do you have some nonstandard network set up ?
              Does the 'TrimmedImages' subfolder get made ?
              Have you tried it in a simpler folder structure on your PC ?
              Also the PNG file image placed/selected in the model must have some transparent and some fully opaque pixels [solid].
              If all pixels have some transparency then the 'edges' file will be blank because there are no solid areas to trim out. If some pixels have even the slightest transparency then the code reads them as non-solid !
              A image editor can quickly flatten the image, add back a transparent layer and then delete selected pixels to leave a transparent background and a solid object within it.
              All of these issues are covered in earlier posts in this thread...
              If you attach the PNG file to a reply I can look at it for you...
                amckeag
                Thanks, TIG. I redirected the file to save directly in my \Documents folder, not connected via OneDrive. I ran into the same issue. Here's the Ruby Console Report:
                Error: #<Errno::ENOENT: No such file or directory @ rb_sysopen - C:\Users\amXXXXXX\Documents\TrimmedImages\2[Edges].dat>
                I've also attached one of the .pngs I've tested. I've read through all of the other comments and have Java installed as well as all of the correct files, I believe (see second attachment). Any help is appreciated.
                  I don't get your error message [or any errors at all].
                  Your PNG is OK.
                  I can trim other PNGs too.
                  The subfolder and its files get made and a trimmed result is made in a few seconds.
                  See the attached image...
                  But I have found that in the newer SketchUp versions, if I import the PNG as an Image it always works, but if I drag-n-drop the PNG into the model it sometimes hangs [with no errors] - the status bar says at making the 'Edges file', although the subfolder and all files get made, the processing fails to complete properly ! Weird !
                    amckeag
                    Thanks so much for troubleshooting, TIG. I still cannot get ImageTrimmer to work on my PC. However, it works on my Mac in SU 2023. My assumption now is that is has something to do with the version of Java installed on my PC. I'll still with Mac for this task. Thanks again!
                    • N Offline
                      nathaliasketch Newcomers @TIG
                      @TIG
                      I installed but nothing happened . I cannot find the toolbar or the tools itself.
                      Can you guide me how to find them ?
                      Nathalia
                        SKMtools is a suite of 'tools' and short code methods to add some missing methods in the Ruby API. It is not a stand alone 'extension'.
                        For example - for material, color, and image inspection and manipulation of their info etc...
                        BUT it does contain some 'tools' - like ImageAnimator and ImageTrimmer - these appear in the View and Tools menus respectively, and the ImageAnimator also has a toolbar that can be activated like any other. ImageTrimmer works from the menu item[s] and has some dialogs which pop up for settings etc...
                        After you install the toolset you probably need to restart SketchUp to see the menu additions etc...
                        Also note that ImageTrimmer uses '.jar' files to execute some methods, so you need Java installed [probably is by default] and .jar files must 'open' [execute] in Java - NOT open in a compression app - some ZIP and RAR apps might hijack the .jar filetype, so you need to ensure that it's excluded from their influence !
                        • 9 / 9
