    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.0m Views 585 Watching
    • fredo6F
      NEW RELEASE: LibFredo6 v15.9b - 21 Apr 26
      LibFredo6 15.9b is a major release. It includes changes related to:
      • Future compatibility
      • Bug Fixing
      • T
        Tpdart
        Hi- I've been using Libfredo tools for a while but recently had a hardware issue with one of my drives unrelated to the SU install or the additional folders location. Basically SU graaaaduaalllyy froze along with my PC and I had to force a hardware shut down. On replacing the hardware and starting up SU again, I'm getting errors pop up- "You must install Libfredo6 or above"; I have manually reinstalled this via SU from the additional folders location but it didn't work on reopening of SU with the same message. This is the followed by load errors of the extensions including libfredo etc.
        Weirdly, in SU extension manager I tried disabling the libfredo extensions, saving changes, closing SU, reopening and the extensions are still enabled!!! Any thoughts on a resolution please? Thanks
        • fredo6F
          It would be helpful that you indicate which version of SU you reinstalled, and which of my plugin you were also trying to install.
          Also, please quote the error message correctly.
          Are you also saying that you use AdditionalPluginFolders plugin to install plugins in an alternative directory?
          • T
            Tpdart
            Hi- manged to delete the original post so restated with additional info requested (!) I've been using Libfredo tools for a while but recently had a hardware issue with one of my drives unrelated to the SU 2023 (on win 11) install or the additional folders location. Basically SU graaaaduaalllyy froze along with my PC and I had to force a hardware shut down. On replacing the hardware and starting up SU again, I'm getting errors pop up- "You must install Libfredo6 or above"; I have manually reinstalled libfredo 6v_15.9 via SU from the additional folders location but it didn't work on reopening of SU with the same message. This is the followed by load errors of the extensions including libfredo, curviloft, fredoscale, fredospline, fredotools, fredocorner etc. Not getting licencing reports (presumably as they haven't loaded).
            Dave RD T 2 Replies Last reply
              Dave R @Tpdart
              First update to SketchUp 2026. You must have an up to date SketchUp subscription since you are using SketchUp 2023 so you can update to 2026 at no additional charge.
              Next, make sure SketchUp is installed correctly so that Windows 11 grants the required permissions to allow SketchUp to write the files it needs. Correct installation involves right clicking on the downloaded installer and selecting Run as administrator.
              Make sure you have the latest version of the Sketchucation ExtensionStore installed and use it to install LibFredo6 and the other extensions.
              • T
                Tpdart @Tpdart
                All working now- thanks
                TIGT 1 Reply Last reply
                  TIG Moderator @Tpdart
                  @Tpdart
                  Explaining how you fixed things helps others reading this, and gives useful feedback to moderators and experienced users who might be 'advising'...
                    Augusteijn @fredo6
                    I want to get curviloft, but when I push the paybutton for paypall nothing happens
                    • fredo6F
                      NEW RELEASE: LibFredo6 v15.9d - 09 Jul 26
                      LibFredo6 15.9d is a maintenance release. It includes changes related to:
                      • Bug Fixing for FredoScale
                      1 Reply Last reply πŸ‘
                      • K
                        Kat27
                        excelent
                        • fredo6F
                          NEW RELEASE: LibFredo6 v16.0a - 08 Aug 26
                          LibFredo6 16.0a is a maintenance release. It includes changes related to:
                          • Bug Fixing for ThruPaint (visibility of palette)
                          • fredo6F
                            NEW RELEASE: LibFredo6 v16.0b - 19 Aug 26
                            LibFredo6 16.0b is a maintenance release. It includes changes related to:
                            • Bug Fixing for dialogs when V-Ray is present
                            • pep75P
                              pep75
                              After the update I got this error...Sketchup also won't boot! When I uninstall all Fredo-plugins Sketchup start-up again. Does anyone else has this problem?
                                Rich O Brien Moderator @pep75
                                No, did you try uodating SUClock to 3.1?
                                SketchUp Plugins | PluginStore | SketchUcation
                                SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                (sketchucation.com)
                                • pep75P
                                  pep75
                                  No! I don't even know what SUclock is...:( But when I remove all the FREDO-plugins Sketchup start normal again.
                                    If you look at your error message it references SUClock 2.0
                                    • pep75P
                                      pep75
                                      Thanks, but it also refers to Libfredo6. πŸ˜•
                                      • fredo6F
                                        NEW RELEASE: LibFredo6 v16.1a - 31 Aug 26
                                        LibFredo6 16.1a is a maintenance release. It includes changes related to:
                                        • Future compatibility (SU2027)
                                        • Bug Fixing, possibly for Mac
                                        RienkR 1 Reply Last reply
                                        • RienkR
                                          Rienk @fredo6
                                          @fredo6
                                          Hi Fredo since today 2 september I updated version LibFredo6 V16.0a 8 aug 2026 to the latest LibFredo6 V16.1a but all your plugins dont work anymore. Where can I find the prior version. I would love to get this old one. Because this version workes for me fine. I was working with curviloft and since the latest version it don't work.
                                          I am working on the PC with SketchUp 2026. There is no error message but it does nothing. I tried several times to start SkectUp but it still doesn't do nothing.
                                          I tried several of your plugins but they doesnt start
                                          With regars,
                                          Rienk
                                          M 1 Reply Last reply
                                          • fredo6F
                                            When you start Sketchup, do you see the menus for the plugins. Do you see the menu Window > LibFredo6 settings.....?
                                            RienkR 2 Replies Last reply
                                            • 109
                                            • 110
                                            • 111
                                            • 112
                                            • 113
                                            • 112 / 113
