    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Version 4.6.0b - 06.06.2026
      • Added handrails to curved stairs.
      • Fixed a bug with labels for railing labels with metric templates.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 4.6.1 - 06.06.2026
        • Added tread covers, carpet and stair runners for all curved stair assemblies.
        • Enabled a “code” clearance envelope for curved (elliptical and circular) stairs.
        design.medeek.com
        • medeekM
          medeek
          Balusters on curved staircases is a bit challenging, I'm not going to lie. My algorithm(s) are mostly working, and I think, as I suggested in my previous postings, I will need to add in some additional (curved stair specific) parameters. At this point I really hate to add more parameters to these already substantially bloated menus. Too many settings and options tend to overwhelm the casual or new user, but at the same time we need enough controls or knobs to fully adjust these assemblies, its a bit of a trade off I guess. As the Japanese say "Shikata ga nai" (仕方がない).
          This screenshot is of a "circular" curved staircase with 1/2" square balusters and baluster shoes. As you can see the baluster spacing is not quite right for either side (inner and outer handrails). To get exactly 2, 3 or 4 balusters per tread one will need to carefully and probably iteratively adjust the spacing. Since these arc lengths won't be nice even numbers the exact spacing number will be some fractional value. I've got some ideas on this to make things a bit easier for the user to compute these exact spacings but I need to experiment with it further.
          Its funny how when I start down one of these rabbit holes I don't usually don't know the full solution to the problem or even fully understand the problem itself. But as I slowly unravel and work my way through one of these problems it ultimately becomes clear and then along the way I seem to always find better ways to address the problems that I encounter.
          design.medeek.com
          • medeekM
            medeek
            Version 4.6.2 - 06.10.2026
            • Added balusters and baluster shoes for all curved stair assemblies.
            • Added separate baluster spacing, offsets and quantities for inner and outer handrails of curved stair assemblies.
            With circular stairs it is possible to carefully control the spacing of the balusters so that a specific number of balusters lands on each tread (two on the inner and three on the outer). However with elliptical stairs the tread arc length may vary significantly so this may or may not be as controllable. I may need to come up with a different way to space balusters on elliptical stairs.
            Note that in the second screenshot where the balusters are attached to the closed stringer this is not an issue.
            Each side can be adjusted separately with the addition of the six new parameters within the Curved Stair Options sub-menu. This level of granularity is required for curved stairs at the expense of making the menus a bit longer.
            design.medeek.com
            • medeekM
              medeek
              It appears that I have handrail fittings mostly working now for both circular and elliptical curved stairs. However just as with the balusters we will need a separate handrail ext. for top and bottom and a rail drop for each side (inner and outer handrails). This means another six parameters in the curved stair menu. Due to the asymmetry or nature of these curved staircases there is really no way around it.
              design.medeek.com
              • medeekM
                medeek
                I've been also thinking about the framing that goes under these stairs and it seems to me that the methods are as varied as there are carpenters. I could provide a basic curved wall framing as shown in the screenshots below but I don't know how much use this would be to anyone as they will probably frame it differently, thoughts?
                Here are a couple additional screenshots of slightly different framing methods applied to a curved staircases:
                design.medeek.com
                • medeekM
                  medeek
                  Version 4.6.3 - 06.14.2026
                  • Enabled open treads for curved stair assemblies.
                  • Enabled handrail fittings for curved stair assemblies.
                  • Added six additional parameters into the curved stair sub-menu for handrail extensions and upper fitting rail drops.
                  • Enabled handrail posts for curved stair assemblies.
                  • Enabled OTP, CUT, and VERTICAL (PTP) handrail options.
                  • Added a vertical offset parameter for top posts.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 4.6.4 - 06.15.2026
                    • Added a "deck" option to the railing module.
                    Note that when Railing Type is set to "Deck" there will typically be a cap rail along with an upper and lower rail. The upper and lower rail provide the support for the balusters or pickets.
                    I will probably need to enable an option to disable or turn off the cap rail.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 4.6.4b - 06.16.2026
                      • Added preview thumbnails into the stair draw and edit menus for posts, balusters and baluster shoes.
                      • Added a "None" handrail profile for deck railings that effectively disables the cap rail.
                      design.medeek.com
                      • medeekM
                        medeek
                        Currently there is no "curved" railing option yet however with a little bit of adjustment of the parameters and simply following any given set of points you can do this sort of thing:
                        design.medeek.com
                          @medeek just a heads up that a recent forum software update has caused loss of uploaded image files. You may notice your posts from May 15th on are missing images 😞
                          Sorry about that....
                          • medeekM
                            medeek
                            Version 4.6.5 - 06.18.2026
                            • Added a "GLASS" baluster option for curved stair assemblies (circular and elliptical).
                            wall_su1239_800.jpg wall_su1240_800.jpg wall_su1243_800.jpg wall_su1244_800.jpg
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 4.6.5b - 06.19.2026
                              • Added a “CABLE” baluster option for curved stair assemblies (circular and elliptical).
                              design.medeek.com
                              • medeekM
                                medeek
                                Currently the railing tool operates similar to the polyline stemwall tool. You select a bunch of points which then create the segments that form the polyline. In order to add the possibility of “curved” segments into this algorithm I could add in a tool which allows the user to select internal segments within the polyline. In order for the segment to be switched to “curved” it would need to meet the following criteria:
                                1.) It cannot be a start or end segment.
                                2.) It cannot be colinear with either of its adjacent segments or neighbors.
                                3.) (Optional) Both adjacent segments must not be curved.
                                The upside with this type of algorithm is that the user does not need to enter in any radii, the curved segment would always be tangent to the two adjacent segments. Also the question as to which way to orient the arc coming off the two end points is deterministic (there are four possible arc placements otherwise for a given radius).
                                My only problem with this type of system is that it may be too limiting and even confusing to some, thoughts?
                                You end up with geometry like this (either a single arc or an S-shaped double arc [biarc]).
                                The other issue is how to handle start and end segments that the user might want to set as curved.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Turns out there are many possible solutions to the problem when you go from a single arc to a Hermite biarc solution. Of course not all these solutions are useful, especially where they intersect or collide with other segments of the polyline. Quite the education on this topic between Wikipedia and ChatGPT yesterday. Here as some solutions to the biarc and single arc problem:
                                  wall_su1255_800.jpg wall_su1258_800.jpg wall_su1259_800.jpg wall_su1261_800.jpg wall_su1262_800.jpg wall_su1263_800.jpg wall_su1264_800.jpg wall_su1265_800.jpg
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 4.6.6 - 06.23.2026
                                    • Added a Curved Segment option/tool for railing assemblies.
                                    • Added a Spline Railing tool into the Stair Toolbar.
                                    • Spline Railings enabled using a Centripetal Catmull-Rom spline algorithm with user selected start and end tangency points.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        On a related note as I’ve stated in the recent tutorial the regen time of this spline railings can suffer because of the large poly handrails and/or shoerails. In the next update I will be introducing and option where the user can toggle a “split” option for both the handrail and shoerail. This will split those two curved solids into separate segments (at the intermediate posts). For larger spline railing assemblies my internal testing has shown an almost 100% performance (draw, edit, regen).
                                        These two parameters will be found in the intermediate post sub-menu, see image below:wall_su1278_800.jpg
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 4.6.7 - 06.25.2026
                                          • Added a “GLASS” baluster option for curved and straight rail assemblies.
                                          • Added a “CABLE” baluster option for curved and straight rail assemblies.
                                          wall_su1278_800.jpg wall_su1279_800.jpg wall_su1282_800.jpg wall_su1288_800.jpg wall_su1289_800.jpg
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 4.6.7b - 06.26.2026
                                            • Enabled deck railing for spline railing assemblies.
                                            • Added a "GLASS" baluster option for spline railing assemblies.
                                            • Added a "CABLE" baluster option for spline railing assemblies.
                                            wall_su1290_800.jpg wall_su1291_800.jpg wall_su1292_800.jpg wall_su1293_800.jpg wall_su1294_800.jpg
                                            design.medeek.com
                                            • 77
                                            • 78
                                            • 79
                                            • 80
                                            • 81
                                            • 79 / 81
