    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.0m Views 28 Watching
    • medeekM
      medeek
      Version 4.5.6b - 05.25.2026
      • Enabled presets for stairs.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 4.5.7 - 05.26.2026
        • Enabled presets for posts.
        • Added the following L.J. Smith handrail profiles: 684, LJ6011, LJ6A10.
        For those interested I am pulling all of my handrail geometry from LJ Smith's webpage at the following link:
        Handrails — L.J. Smith Stair Systems
        Our 33 wooden stair handrails provide plenty of options from which to choose. Many profiles are also available in bending rail for applications requiring curved hand railing.
        L.J. Smith Stair Systems (www.ljsmith.com)
        design.medeek.com
        • medeekM
          medeek
          Version 4.5.8 - 05.30.2026
          • Added a curved stair option into the stair module.
          • Added two new parameters for curved stairs into the draw and edit menus: Inside Radius, Curve Direction.
          • Enabled treads, risers and framing (primitive) for curved stairs.
          design.medeek.com
          • medeekM
            medeek
            Version 4.5.9 - 05.31.2026
            • Added two new parameters for elliptical curved stairs into the draw and edit menus: Eccentricity, Clocking.
            • Enabled treads, risers and framing (primitive) for curved (elliptical) stairs.
            design.medeek.com
            • medeekM
              medeek
              Version 4.5.9b - 05.31.2026
              • Fixed a bug with curved stairs.
              • Added the curved stair parameters into the Stairs tab of the Global Settings.
              • Enabled landing treads for circular and elliptical stairs.
              • Enabled thrust blocks for circular and elliptical stairs.
              design.medeek.com
              • medeekM
                medeek
                Tutorial 87 - Curved Stairs (9:20 min.)
                design.medeek.com
                • medeekM
                  medeek
                  I've been working on close stringers for curved stair cases. The circular variety is pretty much figured out but the elliptical variety still needs an instantaneous adjustment to the stringer depth since the pitch angle of the stairs (slope) is constantly changing. The geometry of a 0.9 eccentric ellipse shows off this distortion quite well. I will hit it again tomorrow and see if I can't figure out a more accurate algorithm for these stringers. Sometimes I enjoy a good challenge, but this one has certainly had me scratching my head a few times already.
                  design.medeek.com
                    Impressive results. Huge timesaver too for users.
                    • medeekM
                      medeek
                      Medeek Wall: Version 4.6.0 - 06.03.2026
                      • Added a curved “closed” stair option into the stair module.
                      • Enabled closed stringers for curved (elliptical and circular) stairs.
                      • Added a separate layer for stair stringers.
                      design.medeek.com
                      • medeekM
                        medeek
                        Tutorial 88 - Curved Closed Stairs (5:55 min.)
                        design.medeek.com
                        • medeekM
                          medeek
                          After mucking around with the follow me API call and a few other algorithms I decided to strike out on my own yesterday, and with a little help from ChatGPT and quite a few iterations I was able to finally generate the closed helical stringers. Using the same principle and by rotating the profile I am now able to generate a similar mesh for the handrails. These are high poly but it does look great and we now have eliminated the twisting issue that I had never resolved using other methods. So a major step forward.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 4.6.0b - 06.06.2026
                            • Added handrails to curved stairs.
                            • Fixed a bug with labels for railing labels with metric templates.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 4.6.1 - 06.06.2026
                              • Added tread covers, carpet and stair runners for all curved stair assemblies.
                              • Enabled a “code” clearance envelope for curved (elliptical and circular) stairs.
                              design.medeek.com
                              • medeekM
                                medeek
                                Balusters on curved staircases is a bit challenging, I'm not going to lie. My algorithm(s) are mostly working, and I think, as I suggested in my previous postings, I will need to add in some additional (curved stair specific) parameters. At this point I really hate to add more parameters to these already substantially bloated menus. Too many settings and options tend to overwhelm the casual or new user, but at the same time we need enough controls or knobs to fully adjust these assemblies, its a bit of a trade off I guess. As the Japanese say "Shikata ga nai" (仕方がない).
                                This screenshot is of a "circular" curved staircase with 1/2" square balusters and baluster shoes. As you can see the baluster spacing is not quite right for either side (inner and outer handrails). To get exactly 2, 3 or 4 balusters per tread one will need to carefully and probably iteratively adjust the spacing. Since these arc lengths won't be nice even numbers the exact spacing number will be some fractional value. I've got some ideas on this to make things a bit easier for the user to compute these exact spacings but I need to experiment with it further.
                                Its funny how when I start down one of these rabbit holes I don't usually don't know the full solution to the problem or even fully understand the problem itself. But as I slowly unravel and work my way through one of these problems it ultimately becomes clear and then along the way I seem to always find better ways to address the problems that I encounter.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 4.6.2 - 06.10.2026
                                  • Added balusters and baluster shoes for all curved stair assemblies.
                                  • Added separate baluster spacing, offsets and quantities for inner and outer handrails of curved stair assemblies.
                                  With circular stairs it is possible to carefully control the spacing of the balusters so that a specific number of balusters lands on each tread (two on the inner and three on the outer). However with elliptical stairs the tread arc length may vary significantly so this may or may not be as controllable. I may need to come up with a different way to space balusters on elliptical stairs.
                                  Note that in the second screenshot where the balusters are attached to the closed stringer this is not an issue.
                                  Each side can be adjusted separately with the addition of the six new parameters within the Curved Stair Options sub-menu. This level of granularity is required for curved stairs at the expense of making the menus a bit longer.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    It appears that I have handrail fittings mostly working now for both circular and elliptical curved stairs. However just as with the balusters we will need a separate handrail ext. for top and bottom and a rail drop for each side (inner and outer handrails). This means another six parameters in the curved stair menu. Due to the asymmetry or nature of these curved staircases there is really no way around it.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      I've been also thinking about the framing that goes under these stairs and it seems to me that the methods are as varied as there are carpenters. I could provide a basic curved wall framing as shown in the screenshots below but I don't know how much use this would be to anyone as they will probably frame it differently, thoughts?
                                      Here are a couple additional screenshots of slightly different framing methods applied to a curved staircases:
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 4.6.3 - 06.14.2026
                                        • Enabled open treads for curved stair assemblies.
                                        • Enabled handrail fittings for curved stair assemblies.
                                        • Added six additional parameters into the curved stair sub-menu for handrail extensions and upper fitting rail drops.
                                        • Enabled handrail posts for curved stair assemblies.
                                        • Enabled OTP, CUT, and VERTICAL (PTP) handrail options.
                                        • Added a vertical offset parameter for top posts.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 4.6.4 - 06.15.2026
                                          • Added a "deck" option to the railing module.
                                          Note that when Railing Type is set to "Deck" there will typically be a cap rail along with an upper and lower rail. The upper and lower rail provide the support for the balusters or pickets.
                                          I will probably need to enable an option to disable or turn off the cap rail.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 4.6.4b - 06.16.2026
                                            • Added preview thumbnails into the stair draw and edit menus for posts, balusters and baluster shoes.
                                            • Added a "None" handrail profile for deck railings that effectively disables the cap rail.
                                            design.medeek.com
                                            • 77
                                            • 78
                                            • 79
                                            • 80
                                            • 81
                                            • 79 / 81
