    Movie Software Suggestion/Recommendation
    28 Posts 3 Posters 818 Views 3 Watching
      Rich O Brien Moderator @ntxdave
      @ntxdave said:
      Can someone verify that my link is now public?
      Its public
      • ntxdaveN Offline
        ntxdave @Rich O Brien
        @Rich-O-Brien said:
        Its public
        Thanks for the verification @rich-o-brien.
        I will have to move on with trying to learn more about learning CapCut. It seems like a pretty strong and versatile tool.
        Press F1...thank me later
        • HornOxxH Offline
          HornOxx
          ...I'm back from a little trip.
          Congratulations on this successful test video edit. You've really incorporated quite a lot of CapCut tricks into it πŸ‘
          never trust a skinny cook
          • ntxdaveN Offline
            ntxdave
            If anyone is using CapCut (in particular the free version). I need some help.
            I created a very small video and was able to upload it to YouTube. I then created a more important video that I want to share with certain individuals, but when I try to export/create the video I am getting messages trying to force me to the Pro version. Can anyone give me any advice or suggest other software to explore?
            • ntxdaveN Offline
              ntxdave
              I think I solved the problem. It appears that I was using some features that are only available in the Pro version. For others, I had been using some animation of text. When I eliminated that, I can now generate a video.
              • HornOxxH Offline
                HornOxx
                ...I figured as much, since I couldn't reproduce your error message from the previous post.
                Less is more, but don't worryβ€”even the free features are still way too extensive 🀣
                (By the way, if you want animated text, you don't have to use any pre-made text-templates β€” just use a simple standard text and animate it with keyframes instead.)
                • ntxdaveN Offline
                  ntxdave
                  For those who are interested in CapCut, here is the link to a great guide for those who are just getting started.
                  CapCut User Guide
                  Hope you find it an interesting guide. It has a lot of information about the toolbars in the application.
                  • ntxdaveN Offline
                    ntxdave
                    Hope someone can help me. I am trying to learn more about some of the "effects" in CapCut. I have added an image to my trial project and have been able to animate it. I have it moving across the screen, rotating and scaling. Now I want to get it to fade in. I have watched some videos of how to do it, but it does not seem to be working. I have set 3 keyframes. The first one sets the fade to 0, the second one to 45% and the third one to 100% so I should be seeing it start at not showing and fade it as it moves across the screen. However, I am seeing it all through the video.
                    Can someone give me some advice?
                      I've zero knowledge of CapCut but are Effects only exposed to paid versions?
                      • ntxdaveN Offline
                        ntxdave
                        OK, I think I learned how to do some more things.
                        Here is a short video that demonstrates how to:
                        • Animate an object that moves across the screen
                        • Fades in as it moves across the screen
                        • Scales as it moves near the right side
                        • Rotates as it moves near the right side
                        CapCut sample test video
                        On the right of the screen, you will see a bunch of videos that are not mine. I need to learn how to manage that now.
                        • 2 / 2
