    Movie Software Suggestion/Recommendation
    31 Posts 3 Posters 2.6k Views 3 Watching
    • ntxdaveN Offline
      ntxdave
      Well, I am making some progress. Here is a link to a video I just created and posted on YouTube. BSW Test 1
      Yes, I still have a long way to go but at least this is a start. My plan is to expand this video a good bit. I have several more "slide" I want to add but it will take some time. The problem I had with the background seems to be solved (at least so far). I know I also need to add some keyframes and some other features. Let me know what you think of where I currently am.
      I do not know where all of those other videos come from and I have not figured out how to all the viewer to replay the video I added.
      Press F1...thank me later
      HornOxxH 1 Reply Last reply Reply Quote 0
      • HornOxxH Offline
        HornOxx @ntxdave
        @ntxdave
        Too bad—your video is private, so I can't view it. But I'm glad to hear you're making progress.
        never trust a skinny cook
        • ntxdaveN Offline
          ntxdave @HornOxx
          @HornOxx said:
          @ntxdave
          [link text](Before you publish, check the following:
          Do kids appear in this video?
          Make sure you follow our policies to protect minors from harm, exploitation, bullying, and violations of labor law. Learn more
          Looking for overall content guidance?
          Our Community Guidelines can help you avoid trouble and ensure that YouTube remains a safe and vibrant community. Learn more
          Can you try it again. I think I made it public but I need for you to give it a try so we can see.
          Just in case, here is a new link to it. `lUpdated Link (just in case)``
          • ntxdaveN Offline
            ntxdave
            Can someone verify that my link is now public?
              Rich O Brien Moderator @ntxdave
              Its public
              • ntxdaveN Offline
                ntxdave @Rich O Brien
                @Rich-O-Brien said:
                Its public
                Thanks for the verification @rich-o-brien.
                I will have to move on with trying to learn more about learning CapCut. It seems like a pretty strong and versatile tool.
                • HornOxxH Offline
                  HornOxx
                  ...I'm back from a little trip.
                  Congratulations on this successful test video edit. You've really incorporated quite a lot of CapCut tricks into it 👍
                  • ntxdaveN Offline
                    ntxdave
                    If anyone is using CapCut (in particular the free version). I need some help.
                    I created a very small video and was able to upload it to YouTube. I then created a more important video that I want to share with certain individuals, but when I try to export/create the video I am getting messages trying to force me to the Pro version. Can anyone give me any advice or suggest other software to explore?
                    • ntxdaveN Offline
                      ntxdave
                      I think I solved the problem. It appears that I was using some features that are only available in the Pro version. For others, I had been using some animation of text. When I eliminated that, I can now generate a video.
                      • HornOxxH Offline
                        HornOxx
                        ...I figured as much, since I couldn't reproduce your error message from the previous post.
                        Less is more, but don't worry—even the free features are still way too extensive 🤣
                        (By the way, if you want animated text, you don't have to use any pre-made text-templates — just use a simple standard text and animate it with keyframes instead.)
                        • ntxdaveN Offline
                          ntxdave
                          For those who are interested in CapCut, here is the link to a great guide for those who are just getting started.
                          CapCut User Guide
                          Hope you find it an interesting guide. It has a lot of information about the toolbars in the application.
                          • ntxdaveN Offline
                            ntxdave
                            Hope someone can help me. I am trying to learn more about some of the "effects" in CapCut. I have added an image to my trial project and have been able to animate it. I have it moving across the screen, rotating and scaling. Now I want to get it to fade in. I have watched some videos of how to do it, but it does not seem to be working. I have set 3 keyframes. The first one sets the fade to 0, the second one to 45% and the third one to 100% so I should be seeing it start at not showing and fade it as it moves across the screen. However, I am seeing it all through the video.
                            Can someone give me some advice?
                              I've zero knowledge of CapCut but are Effects only exposed to paid versions?
                              • ntxdaveN Offline
                                ntxdave
                                OK, I think I learned how to do some more things.
                                Here is a short video that demonstrates how to:
                                • Animate an object that moves across the screen
                                • Fades in as it moves across the screen
                                • Scales as it moves near the right side
                                • Rotates as it moves near the right side
                                CapCut sample test video
                                On the right of the screen, you will see a bunch of videos that are not mine. I need to learn how to manage that now.
                                • HornOxxH Offline
                                  HornOxx @Rich O Brien
                                  ...as is the case with many free software versions, CapCut Free comes with a limited range of effects (transitions, text effects, etc.). The features that are only available in the Pro version are clearly marked as such.
                                  Regardless, CapCut Free can rightly be called a full-featured app because everything you need is included.
                                  Personally, I love this because it avoids that unbearable “PowerPoint” urge—so common among many users—to make everything fly, scroll, or dissolve in some silly way! —Here, too, the rule applies: Less is usually more!
                                  • ntxdaveN Offline
                                    ntxdave
                                    Continuing to learn how to, and using, CapCut to create videos. Here is another one where I am presenting an animation I created with SketchUp Jesus Plaque Animation
                                    • ntxdaveN Offline
                                      ntxdave
                                      @hornoxx I have to let you know that I just did a little more learning about CapCut. I found out that some of the things I did in the two videos (in particular the Jesus Plaque Animation) I had used an external tool that I did not need to use. In particular if you looked at the videos, you saw some places where I placed text over a rectangular object (with rounded corners) that I could have done in CapCut. The more I learn the better I like the tool. I want to thank you for suggesting it.
                                      Now I am going to try to learn how to create some animations with Blender and the include them in some videos created with CapCut.
                                      • 2 / 2
