    MUZWalls v2.0 — parametric walls, openings, and one-click takeoff (built by an architect)
    7 Posts 5 Posters 135 Views 5 Watching
      Muzwalls Newcomers
      G'day all,
      Long-time SketchUp user (20+ years on the tools as a practicing architect),
      first-time plugin author posting here. I wanted to share what I've been
      building, get your hands on it, and hear what's broken.
      THE ITCH I WAS SCRATCHING
      SketchUp is the fastest tool I know for thinking through a building. But
      the moment a project moves past concept, three things start eating my day:
      • Walls that don't behave like walls, every opening is a manual hole
        through every layer
      • Importing a client's PDF floor plan and tracing it from scratch
      • Counting materials at the end of the job, by hand, group by group
      I tried Medeek, PlusSpec, and a few others. Heavy, opinionated, framing-
      focused. I wanted something lighter, the SketchUp ethos, but with walls
      that actually know they're walls.
      WHAT MUZWALLS DOES
      1. Parametric walls — single skin or cavity (brick veneer + studs +
      plasterboard, etc). Edit the type, every instance updates.
      2. Mitered wall chains — corners stay clean when you change widths
      3. Curved walls — true arc-segmented geometry, not faceted boxes
      4. Self-healing openings — drop a window, the wall heals. Move it,
      it heals again. Delete it, ditto. Through every layer of a cavity.
      5. Linear profiles — sills, capping, skirting, handrails. Sweep
      along any edge.
      6. PDF floor plan import — drop a PDF, scale it to a known dimension,
      trace it. (Demo GIF below.)
      7. One-click quantity takeoff — every wall, opening, profile, and
      material exported to CSV/Excel. By type, by storey, by room.
      WHAT IT DELIBERATELY DOESN'T DO
      • No cloud account. No telemetry. Works fully offline after activation.
      • No central library server — libraries live inside the .skp file,
      so they travel with the project.
      • No framing engine. (Medeek owns that space and does it well.)
      • Not trying to be Revit. If you need full BIM, this isn't it.
      • No macOS yet — Windows only for v2.0. On the roadmap, no ETA I'm
      willing to commit to publicly. If you're on Mac and the rest of
      the pitch resonates, reply here and I'll bump you up the waitlist.
      PRICING
      US$19/month or $190/year. 3-day free trial, no card required.
      SketchUp Pro 2022+, Windows only (macOS on the roadmap).
      → Free trial: https://muzwalls.com
      FOR SKETCHUCATION MEMBERS
      Reply in this thread for a 14-day extended trial (instead of 3) — I'll
      DM you the licence. I'd rather you have time to actually put it through
      a real project than rush to a verdict in 72 hours. If it works for you,
      leave an honest review on the plugin store. If it doesn't, tell me here
      why and I'll fix it.
      WHAT I'D LOVE FEEDBACK ON
      1. Is the cavity-wall workflow obvious or does it need a tutorial?
      2. Anyone in the UK/AU using imperial+metric mixed? I want to make
      sure unit handling doesn't bite anyone.
      3. What's missing that would make this a one-click decision for you?
      Cheers,
      Morteza
      MUZWalls
      M 1 Reply Last reply 👍 Reply Quote 1
        Appreciate the extended trial. Why does your site say $14.99/m or $119/yr and here its $19/m or $190/yr?
          MtnArch
          What version(s) of SketchUP will this work with?
          Highest Regards,
          Alan T. Hendry, RA
          Architect
          M 1 Reply Last reply 👍 Reply Quote 0
            Muzwalls Newcomers @Muzwalls
            Hi Rich O Brien,
            we have changed our pricing, the pricing on the website is correct.
            Best Regards
              Mortezakhadem Newcomers @MtnArch
              @MtnArch Supports SketchUp 2024 and later versions
              • medeekM Offline
                medeek
                You do realize that the Medeek Wall plugin can operate in "No Framing" mode, all of the internal framing in a wall is replaced with a simple solid group. I think I put out a video explaining this about a year ago.
                I am curious though to see how your extension works with interacting walls (ie. corners and tee intersections).
                Nathaniel P. Wilkerson PE
                Medeek Engineering Inc
                design.medeek.com
                  Muzwalls Newcomers @medeek
                  @medeek
                  Hey Nathan,
                  Thanks for pointing that out.
                  While Medeek Wall is excellent for framing, our primary focus with MuzWalls is specifically on masonry and solid wall construction.
                  We are developing the extension to handle the nuances of these workflows in depth.
                  Regarding wall interactions: MuzWalls utilizes a logic-based system for corners.
                  It features an auto-miter capability that detects when two walls meet and automatically calculates the connection based on their respective angles. This allows the walls to join seamlessly as a continuous structure rather than remaining as overlapping or separate groups.
                  We are continuously refining this system to ensure that masonry wall interactions inside SketchUp feel clean, intelligent, and highly automated.
                  We'd genuinely love to get your feedback on this — and the wider community's too. Draw a couple of walls, drop a window, drag an endpoint around and see how the corners hold up. 3-day trial, no card required: https://muzwalls.com
                  Best Regards
                  Muzwalls - Morteza
