Movie Software Suggestion/Recommendation
DaVinci Resolve has a free version that is on par with Adobe After Effects. Its probably overkill for your needs.
Try OpenShot: https://www.openshot.org/
Thanks for the feedback, Rich. I think thee Davinci Resolve is a bit of an overkill, but I am going to take a look at OpenShot. I might wind up just using Animator though.
Again, thanks for the feedback.
I have been having some problems trying to download and install OpenShot. Any suggestions?
I'm making fast and simple progress with CapCut—it's very simple and straightforward (and there are a lot of help-tuts on Youtube)
It has all the needed features, such as transitions, text, sound, etc., and even keyframe animation...
https://www.capcut.com
@HornOxx I have downloaded it and am trying to learn. Looks like it has a lot of the features I want but I still have a lot of things to learn. In particular, I want to be able to animate some text (like make it slide on to the screen).
Is there a charge for the desktop version? I will keep you posted as I learn.
Prima! (I can´t translate "Is there a charge for the desktop version? into something that makes sense in German"
) Aren't you running the program on a computer? Or does that mean “does it cost anything”? Hmmm—my version didn't cost anything.
Animated text: There are various pre-animated text templates available (I never like those things), or you can use a simple standard text, place it, and set a keyframe, then reposition it, even in size or rotation, and set another keyframe. You can do the same with an alpha-channel PNG, for example, an arrow or a red circle...
(before you waste too much time, check YouTube for “CapCut keyframes” or “keyframe animation”).
I look forward to hearing how you're getting along
) Aren't you running the program on a computer? Or does that mean “does it cost anything”? Hmmm—my version didn't cost anything.Yes, I meant does it cost anything.
️Thanks, I will need to learn more about how to use keyframes properly.
As of right now, I am making some interesting progress. As soon as I can, which might be a while, I will share the progress I am making. As of now, this seems to have the features I want/need for the project I want to do.
I am still trying to learn how to use the CapCut software. So far, I am not doing as good as I would like but the software looks very powerful.
For my first video, I would like to video, I wanted to start with multiple images and text. I want to animate some of the text. That all seemed very easy to do but I have one issue I have not been able to resolve. Since page is a mixture of multiple images and some animated text I need to be able to set the background for the page. I would kind of like for it to be a single color. I have not been able to figure out how to set the background color though. Later I plan on adding more pages with more images and eventually an animation that I have created with the Animator plugin in SketchUp.
I have now watched several videos but have not found out how to set the background for my "presentation" though. If you, or others, have any suggestions, I would really like to hear from you.
For others who have looked at this thread (or do look at it) I think CapCut looks like a really cool piece of software.
Hi again
even though I don't exactly understand what kind of result you're aiming for, maybe these tips will help you:
To create my own custom background, I edit my own HD JPG (1920 x 1080 px). In my example, a simple green JPG created using any image editor. This way, I set my preferred video format for a later export, for example, for a monitor or TV screen. This JPG can be a custom background color or even the family photo from last Christmas. And this background image spans over the entire duration of the video and is located on the lowest video track!
In the video tracks above it, you can play around with your content: You can make text or other image files fly across the screen, or simply fade them in or out at your desired speed, or animate them, or or or... (In my experience, less fiddling around is often better than too much
Your slideshow in the track editor will probably end up looking something like a staircase that rises diagonally upward to the right
Once you figure out how to create a nice transition or a keyframe animation, capCut is actually pretty simple and straightforward...
I used one of their favorites as a background and it worked, however when I started adding more items or changing the timeline of some items I had already included, I could no increase the background to match the other changes so it does not now appear behind all items. So far, I have not been able to find a solution.
Is there a support site or forum you would recommend?
BTW: from an earlier post, are you from Germany? I was stationed there in the US Army from late 1966 to late 1968.
...so I can understand better—you could send me a screenshot similar to mine, even if it doesn't work exactly as you want it to yet. Maybe also a mock-up screenshot of how it should look later in the video.
If you want to add images (JPGs or similar), they’ll be added by default in full-screen mode, so to speak, and would thus cover your background, which obviously needs to remain visible (?). So you’ll need to scale down your image sequence, similar to the “Cute Robot” in my screenshot...
But before I offer any further blabla
I’ll better wait for your screenshots.Yes, that’s right—I live in the Frankfurt area
Where were you stationed back then?
