    [Plugin][$] FredoSpline - v2.6a - 01 Apr 24
    149 Posts 40 Posters 201.1k Views 40 Watching
      rv1974
      This post is deleted!
        rv1974
        @fredo6 Any chance to make inference work while moving vertices please?
        P.S. >>>For rounded corner, the radius is limited to half the length of the shortest connecting edge at the corner..
        Why such a strong limitation exists? Say I have L shape 200/100cm.. why the plugin can't create 99 cm fillet?
          dascaualex
          Hello,
          I have problem with this plugin and with Fredo plugins in general recently. The licenses appear to be invalid. I bought the license for this plugin today and I it is not working even tho when i activate it everything seems to be ok, validity is there, but once i close the window and try to use the plugin it says that the trial has expired and I get a small notification from skp saying that license is invalid. I have this problem with all fredo plugins both on older skp and 2024.
            Rich O Brien Moderator @dascaualex
            @dascaualex said in [Plugin][$] FredoSpline - v2.6a - 01 Apr 24:
            Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
            D 1 Reply Last reply
              dascaualex @Rich O Brien
              @Rich-O-Brien
              Fredo6 Plugins Information on 2024-11-15 09:18:09 +0200
              • Sketchup: 24.0.484
              • LibFredo6: v14.6a
              • LibFredo6 Binary loaded
              • Sketchucation ExtensionStore: 4.4.1
              • SCFLicense: v6.4a - 74
              • Fredo6 Plugins
                Curviloft v2.0a
                FredoSpline v2.6a
                JointPushPull v4.8a
                Signature File: 2022-09-14 17:22:45 +0300
                ClothWorks: 2022-09-14 18:13:22 +0300
                RoundCorner: 2022-12-06 15:51:28 +0200
                @dascaualex Please update Libfredo
                  rv1974
                  @fredo6 Fredo please implement selecting (by crossing window) and changing radius to multiple points simultaneously when editing polycorner arc curves. Currently selecting\editing vertices on-by-one is extremely limiting. Also please make plane lock sticky.
                    rv1974
                    @fredo6 could "smooth curve" from the attached video be implemented?
                    https://youtu.be/iqz2EwF16-w?si=x4gxUOCjS2uR9VOg&t=151
                    "project to scene" script at 1:59 is also fabulous
                      rv1974
                      it'd be awesome if aux windows across all Fredo's plugins would focus on input field out of the box
                      fredo6F 1 Reply Last reply
                      • fredo6F
                        fredo6 @rv1974
                        This is an issue in SU2026. In previous versions of Sketchup, the focus was on the field right away.
                        Nothing I can do, unless Trimble fixes it.
                        • 8 / 8
