    [Plugin][$] FredoSpline - v2.6a - 01 Apr 24
    149 Posts 40 Posters 195.5k Views 40 Watching
    • fredo6F
      fredo6 @rv1974
      @rv1974
      For rounded corner, the radius is limited to half the length of the shortest connecting edge at the corner. This allows to only round long edges when you do it globally.
      Deletion of faces happens when you change the number of vertices. It is somehow difficult to maintain the face.
      It seems to me that if you created the curve with a specified plane, the edition of vertices will be along the plane.
      R 1 Reply Last reply
        rv1974 @fredo6
        This post is deleted!
          rv1974
          @fredo6
          For rounded corner, the radius is limited to half the length of the shortest connecting edge at the corner..
          OK, but it should not break scrolling.
          In many situations a banal vertex moving deletes face as well .
          Unfortunately - no , it can easily run away from the plane. Also, if there are objects not laying on this plane - SU easily snaps to them.
          is it possible to implement scrolling\nudging based on exact user defined values ?
          currently there are no exact values on radius\tension changing. This feature would be extremely useful in other plugins where scrolling\nudging being used - PaintThru, Axiz etc.
          Thank you for attention
            rv1974
              rv1974
              @fredo6 Any chance to make inference work while moving vertices please?
              P.S. >>>For rounded corner, the radius is limited to half the length of the shortest connecting edge at the corner..
              Why such a strong limitation exists? Say I have L shape 200/100cm.. why the plugin can't create 99 cm fillet?
                dascaualex
                Hello,
                I have problem with this plugin and with Fredo plugins in general recently. The licenses appear to be invalid. I bought the license for this plugin today and I it is not working even tho when i activate it everything seems to be ok, validity is there, but once i close the window and try to use the plugin it says that the trial has expired and I get a small notification from skp saying that license is invalid. I have this problem with all fredo plugins both on older skp and 2024.
                  Rich O Brien Moderator @dascaualex
                  @dascaualex said in [Plugin][$] FredoSpline - v2.6a - 01 Apr 24:
                  Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                  D 1 Reply Last reply
                    dascaualex @Rich O Brien
                    @Rich-O-Brien
                    Fredo6 Plugins Information on 2024-11-15 09:18:09 +0200
                    • Sketchup: 24.0.484
                    • LibFredo6: v14.6a
                    • LibFredo6 Binary loaded
                    • Sketchucation ExtensionStore: 4.4.1
                    • SCFLicense: v6.4a - 74
                    • Fredo6 Plugins
                      Curviloft v2.0a
                      FredoSpline v2.6a
                      JointPushPull v4.8a
                      Signature File: 2022-09-14 17:22:45 +0300
                      ClothWorks: 2022-09-14 18:13:22 +0300
                      RoundCorner: 2022-12-06 15:51:28 +0200
                      @dascaualex Please update Libfredo
                        rv1974
                        @fredo6 Fredo please implement selecting (by crossing window) and changing radius to multiple points simultaneously when editing polycorner arc curves. Currently selecting\editing vertices on-by-one is extremely limiting. Also please make plane lock sticky.
                          rv1974
                          @fredo6 could "smooth curve" from the attached video be implemented?
                          https://youtu.be/iqz2EwF16-w?si=x4gxUOCjS2uR9VOg&t=151
                          "project to scene" script at 1:59 is also fabulous
                            rv1974
                            it'd be awesome if aux windows across all Fredo's plugins would focus on input field out of the box
                            fredo6F 1 Reply Last reply
                            • fredo6F
                              fredo6 @rv1974
                              This is an issue in SU2026. In previous versions of Sketchup, the focus was on the field right away.
                              Nothing I can do, unless Trimble fixes it.
                              • 8 / 8
