    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Version 4.4.3 - 03.23.2026
      • Enabled the following methods within the Medeek Wall API: wall_win_get_attribute, wall_win_set_attribute
      • Enabled the following methods within the Medeek Wall API: wall_door_get_attribute, wall_door_set_attribute
      • Enabled the following methods within the Medeek Wall API: wall_garage_get_attribute, wall_garage_set_attribute
      • Enabled the following methods within the Medeek Wall API: wall_column_get_attribute, wall_column_set_attribute
      This completes most of the required methods for the Medeek Wall API.
      There are other assembly types that I can possibly add in API calls for but I may wait and see what is requested by the userbase before spending too much more time on this. The other assembly types are:
      • stairs
      • beams
      • free standing posts
      • moldings (crown, baseboard, chair rail)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Similar to the Wall Draw Perimeter tool Larry Belk requested that I add this method to the API:
        • wall_draw_perim
        This new method accepts either a face or an array of points:
        design.medeek.com
        • medeekM
          medeek
          I've finally started to tackle the manual for the Wall plugin. There is so much content that needs to be added to these pages that this one will probably take me a few months to complete even if I were to work at it full time. The current organization of this page is probably only temporary as additional items are added it will continue to evolve and probably branch into many separate pages/documents:
          Medeek Wall Manual
          (design.medeek.com)
          design.medeek.com
          • gullfoG
            gullfo
            one future evolution - create a separate plugin for doors and windows, etc so your plugins are focused - wall does walls, floor does floors, trusses do trusses, etc -- then doors and windows CRUD doors and windows in walls or ceilings etc, stairs probably should get their own as well given the complexities. same way you broke out electrical, hvac, plumbing... that would simplify both the wall plugin and not require as many updates, whereas doors and windows would likely get more frequent ones as you add models and options for them.
            Glenn
            http://www.runnel.com
            1 Reply Last reply πŸ‘
            • medeekM
              medeek
              Here is what I prompted ChatGPT with:
              Okay, now that you have helped me actually program most of the Medeek APIs (wall, truss, foundation and floor). I would like for you to attempt to use the API to generate some ruby code I can dump into the console in order to create a simple garage (four exterior walls) with a simple fink truss roof.
              I also forgot to add that this should have a slab on grade foundation that measures 24' x 36'. The walls align with the edges of the foundation (outside of framing) and the truss roof will also be 24' x 36'. On the one gable end will be a 16' garage door 84" in height (default, so don't worry about the height. On one of the long walls there should be a regular 36" x 80" door, centered 6' from the corner. On the other long wall a 36" x 48" window (centered on wall) and on the other short wall opposite the garage door wall should also be a 36" x 48" window (centered on the wall). The fink truss roof should be a 6:12 pitch, leave everything else as default.
              After one mistake (it put the roof assembly on the ground initially, not sure why it missed that but it did), it produced this piece of code, which I then copied and pasted into the console and hit enter:
              model = Sketchup.active_model
              ents  = model.active_entities
              wall_mod  = Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods
              truss_mod = Medeek_Engineering_Inc_Extensions::MedeekTrussPlugin::MedeekMethods
              sog_mod   = Medeek_Engineering_Inc_Extensions::MedeekFoundationPlugin::Sog::MedeekMethods
              # --- helper: run an API call and return the new top-level group it created ---
              def capture_new_group(ents)
                before = ents.grep(Sketchup::Group)
                yield
                after  = ents.grep(Sketchup::Group)
                new_groups = after - before
                return new_groups.first
              model.start_operation('Create Medeek Garage', true)
              begin
                # GEOMETRY
                # 24' x 36' slab/wall/truss footprint
                # Coordinates in inches
                # Layout:
                #   SW = (0,0,0)
                #   SE = (432,0,0)
                #   NE = (432,288,0)
                #   NW = (0,288,0)
                # Walls are drawn counterclockwise around the exterior perimeter so the
                # outside of framing aligns with the slab perimeter.
                p0 = [0.0,   0.0,   0.0]   # SW
                p1 = [432.0, 0.0,   0.0]   # SE
                p2 = [432.0, 288.0, 0.0]   # NE
                p3 = [0.0,   288.0, 0.0]   # NW
                footprint = [p0, p1, p2, p3]
                # 1. Slab-on-grade foundation
                sog_group = capture_new_group(ents) do
                  sog_mod.sog_draw(footprint)
                # 2. Exterior walls
                #    South wall: p0 -> p1  (36')
                #    East wall:  p1 -> p2  (24')
                #    North wall: p2 -> p3  (36')
                #    West wall:  p3 -> p0  (24')  <-- garage door wall
                south_wall = capture_new_group(ents) do
                  wall_mod.wall_draw(p0, p1, 'Rectangular', 'Int-Ext')
                east_wall = capture_new_group(ents) do
                  wall_mod.wall_draw(p1, p2, 'Rectangular', 'Int-Ext')
                north_wall = capture_new_group(ents) do
                  wall_mod.wall_draw(p2, p3, 'Rectangular', 'Int-Ext')
                west_wall = capture_new_group(ents) do
                  wall_mod.wall_draw(p3, p0, 'Rectangular', 'Int-Ext')
                # 3. Openings
                # WEST gable wall (24' wall): centered 16' garage door
                # wall length = 288", centered opening location = 144"
                # SOUTH long wall (36' wall): 36" x 80" door
                # center placed 72" from SW corner
                # NORTH long wall (36' wall): centered 36" x 48" window
                # wall length = 432", centered opening location = 216"
                # EAST short wall (24' wall): centered 36" x 48" window
                # 16' garage door on west wall, centered
                wall_mod.wall_garage_draw(144.0, 192.0, 84.0, 'Rectangle', west_wall)
                # 3' x 6'-8" man door on south wall, center 6' from SW corner
                wall_mod.wall_door_draw(72.0, 36.0, 80.0, 'Rectangle', south_wall)
                # Centered window on north wall
                wall_mod.wall_win_draw(216.0, 36.0, 48.0, 'Rectangle', north_wall)
                # Centered window on east wall
                wall_mod.wall_win_draw(144.0, 36.0, 48.0, 'Rectangle', east_wall)
                # 4. Fink truss roof over same 24' x 36' footprint, 6:12 pitch
                #    FIX 1: raise roof to top of walls
                #    FIX 2: reorder points so gable orientation is rotated 90 degrees
                wall_height = 97.125
                tp0 = [0.0,   0.0,   wall_height]   # SW
                tp1 = [0.0,   288.0, wall_height]   # NW
                tp2 = [432.0, 288.0, wall_height]   # NE
                tp3 = [432.0, 0.0,   wall_height]   # SE
                truss_footprint = [tp0, tp1, tp2, tp3]
                truss_group = capture_new_group(ents) do
                  truss_mod.common_truss_draw(6.0, 'Fink', truss_footprint)
                model.commit_operation
                puts 'Medeek garage created successfully.'
                puts "SOG group:   #{sog_group ? sog_group.name : 'not captured'}"
                puts "South wall:  #{south_wall ? south_wall.name : 'not captured'}"
                puts "East wall:   #{east_wall ? east_wall.name : 'not captured'}"
                puts "North wall:  #{north_wall ? north_wall.name : 'not captured'}"
                puts "West wall:   #{west_wall ? west_wall.name : 'not captured'}"
                puts "Truss group: #{truss_group ? truss_group.name : 'not captured'}"
              rescue => e
                model.abort_operation
                puts "ERROR: #{e.class} - #{e.message}"
                puts e.backtrace.join("\n")
              The result was this:
              ChatGPT just built (in SketchUp) my new detached garage in under five minutes. It was even offering to modify the windows to sliders and other modifications if I needed to stray from the defaults that I had used.
              These AI engines will continue to improve and eventually they may be able to do much more than design a simple four wall structure like this. Things are going to get really interesting in the next couple of years.
              design.medeek.com
              • gullfoG
                gullfo
                nice! how did it know to use your API?
                Glenn
                medeekM 1 Reply Last reply
                • medeekM
                  medeek @gullfo
                  @gullfo I gave it the links to the API web pages and told it to study them and from that it was able to use the API fully.
                  Here are the links I provided ChatGPT:
                  Medeek Wall API Documentation
                  (design.medeek.com)
                  Medeek Truss API Documentation
                  (design.medeek.com)
                  Medeek Foundation API Documentation
                  (design.medeek.com)
                  design.medeek.com
                  • gullfoG
                    gullfo
                    very cool! thanks!
                    Glenn
                    • medeekM
                      medeek
                      Just so everyone is aware, they should update to this latest release: SU 2026.1.2 because of specific bug fix for the SpaceMouse issue as documented here:
                      • (Windows) Fixed a crash related to DX12 rendering triggered by orbiting or zooming while using a 3Dconnexion SpaceMouse, notably after using extensions such as Medeek Wall.
                      (help.sketchup.com)
                      design.medeek.com
                      • gullfoG
                        gullfo
                        i find SU 2026 unusable do the folder setting restrictions which make my component and material collections virtually unreadable from all the duplication and then consider that if i do modify the folders, the installer simply reverts. so i'm on 2025 until they can fix it. thankfully i don't use a SpaceMouse...
                        Glenn
                        • medeekM
                          medeek
                          Version 4.4.4 - 04.02.2026
                          • Enabled the following methods within the Medeek Wall API: wall_draw_perim
                          • Enabled "profile cutting" of balusters for vertical and OTP handrails.
                          I'm not sure why I didn't realize I could do this before but I woke up yesterday and I realized that a simple profile could be revolved into the cutting solid (like putting a piece of square stock on a lathe) and then boolean subtracted from the square baluster as shown to give a typical "turned" baluster.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 4.4.5 - 04.05.2026
                            • Fixed a bug with the profile cutting of balusters.
                            • Enabled a new boolean subtraction algorithm for profile cutting of balusters.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 4.4.5b - 04.08.2026
                              • Added a tooltip for the Corner Treatment option into the Global Settings, Draw and Edit Wall Menus.
                              I didn't realize that the term "California Corner" was not well known in the industry. To that end I've added a tooltip for "Corner Treatment" which shows a typical (2x6) California Corner and a U-Corner. Hopefully this further clarifies this parameter for some users who are not familiar with this term. The other corner treatments seem fairly self explanatory.
                              design.medeek.com
                              • medeekM
                                medeek
                                I've been meaning to add in a "Style 6" door hardware option for quite some time. Basically something for your entrance door, and I haven't had a good option for this until now. This low poly entrance hardware and deadbolt (handleset) is loosely modeled after the Camelot series by Schlage. I will include this in the next roll out:
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 4.4.6 - 04.11.2026
                                  • Added a "Style 6" (Schlage - Camelot) to the built-in door hardware options.
                                  • Configured the "Ctrl" hot key within the draw door tool with additional justification options (x-dir).
                                  Tutorial 84 - Positioning Doors (7:19 min.)
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 4.4.6b - 04.12.2026
                                    • Added custom door positioning offsets into the Door tab of the Global Settings.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 4.4.7 - 04.16.2026
                                      • Fixed a bug with custom door positioning for metric templates.
                                      • Enabled "profile cutting" of posts for vertical handrails.
                                      • Fixed a bug with the bottom trimming algorithm for balusters
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 4.4.8 - 04.18.2026
                                        • Enabled custom components as posts for vertical handrails
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Tutorial 85 - Profile Cut Newel Posts (9:04 min.)
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 4.4.8b - 04.18.2026
                                            • Enabled custom components as balusters for vertical and OTP handrails.
                                            Th sub-folder structure is the same as for newel posts, so Tutorial #85 is applicable to balusters as well.
                                            design.medeek.com
                                            • 75
                                            • 76
                                            • 77
                                            • 78
                                            • 79
                                            • 80
                                            • 81
                                            • 77 / 81
