    MARIOCHA Format 3D: SketchCuisine via SketchUcation plugin is not functioning correctly.
    4 Posts 2 Posters 283 Views 2 Watching
      Azra Salkanovic Newcomers
      Hello,
      I have recently purchased a full license for SketchCuisine via SketchUcation, and the license appears to be successfully validated (status shows "validate_success").
      However, the plugin is not functioning correctly.
      Issue description:
      The plugin appears in the Extensions menu and toolbar
      License is active and validated
      When clicking on any SketchCuisine tool (icons or menu commands), nothing happens (no dialog, no action)
      Only the info/settings window can be opened
      What I have already tried:
      Assigned the license seat correctly (1/3 seats active)
      Restarted SketchUp multiple times
      Reset workspace
      Disabled other extensions (including V-Ray and Sketch-Int)
      Completely uninstalled and reinstalled the plugin (including manual removal from Plugins folder)
      Logged in to SketchUcation and confirmed license activation
      Tested in SketchUp 2022
      Despite all of the above, the tools remain unresponsive.
      Could you please advise on how to resolve this issue, or confirm if there are known compatibility problems with current systems?
      Thank you in advance for your support.
        Did you open the Ruby Console to see if there are errors?
        A 1 Reply Last reply
          Azra Salkanovic Newcomers @Rich O Brien
          @Rich-O-Brien Tnx for the hint. The issue was that the plugin expected html_En-us, but only html_En was installed, so it couldn’t detect the files
            So it’s working now? I’ll send the dev an email about your findings
