<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MARIOCHA Format 3D: SketchCuisine via SketchUcation  plugin is not functioning correctly.]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have recently purchased a full license for SketchCuisine via SketchUcation, and the license appears to be successfully validated (status shows "validate_success").</p>
<p dir="auto">However, the plugin is not functioning correctly.</p>
<p dir="auto">Issue description:</p>
<p dir="auto">The plugin appears in the Extensions menu and toolbar<br />
License is active and validated<br />
When clicking on any SketchCuisine tool (icons or menu commands), nothing happens (no dialog, no action)<br />
Only the info/settings window can be opened<br />
What I have already tried:</p>
<p dir="auto">Assigned the license seat correctly (1/3 seats active)<br />
Restarted SketchUp multiple times<br />
Reset workspace<br />
Disabled other extensions (including V-Ray and Sketch-Int)<br />
Completely uninstalled and reinstalled the plugin (including manual removal from Plugins folder)<br />
Logged in to SketchUcation and confirmed license activation<br />
Tested in SketchUp 2022<br />
Despite all of the above, the tools remain unresponsive.</p>
<p dir="auto">Could you please advise on how to resolve this issue, or confirm if there are known compatibility problems with current systems?</p>
<p dir="auto">Thank you in advance for your support.</p>
]]></description><link>https://community.sketchucation.com/topic/164820/mariocha-format-3d-sketchcuisine-via-sketchucation-plugin-is-not-functioning-correctly.</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Apr 2026 18:08:28 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/164820.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 16 Apr 2026 10:34:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MARIOCHA Format 3D: SketchCuisine via SketchUcation  plugin is not functioning correctly. on Thu, 16 Apr 2026 14:19:35 GMT]]></title><description><![CDATA[<p dir="auto">Did you open the Ruby Console to see if there are errors?</p>
]]></description><link>https://community.sketchucation.com/post/1620281</link><guid isPermaLink="true">https://community.sketchucation.com/post/1620281</guid><dc:creator><![CDATA[Rich O Brien]]></dc:creator><pubDate>Thu, 16 Apr 2026 14:19:35 GMT</pubDate></item></channel></rss>
