    AI generated subdivison plugin
    7 Posts 3 Posters 420 Views 3 Watching
      sashapepperspray
      In the past view weeks, I worked with ai to make a subdivision and mesh reduction plugin. I started off with this old plugin (https://github.com/NB70/sketchup-loop-subdivision), and got the ai to improve it, and then I got it to make a dynamic subdivision plugin, and a mesh reduction plugin. I don't really know ruby coding, so I can't say it will work, but it works for me. I will attach it here, hopefully someone finds it useful. I also am attaching a manual, generated by ai (obviously) from the code.
      mesh tool manual.pdf
      Mesh Tools.rbz
        Impressive result.
        Tons of Ruby Console errors
        #<TypeError: reference to deleted Face>
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:190:in `edges'
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:190:in `block in dyn_loop_getvertices'
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:188:in `each'
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:188:in `dyn_loop_getvertices'
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:345:in `block in dyn_loop_subdivide'
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:343:in `times'
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:343:in `dyn_loop_subdivide'
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:555:in `loop_dynamic_build_result'
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:581:in `block in loop_dynamic_schedule_rebuild'
          Works well.
          But I have a few observations from a non-AI view-point...
          The Dynamic_Subdivide.rb file uses several $xxx... global variables - these are frowned upon because they can pollute all other Ruby files [and are not acceptable in extensions submitted for review in the EWH].
          It's a simple fix - replace them all with @xxx... variables that then work across methods in the same modules, but not 'globally' in unconnected scripts.
          That Dynamic_Subdivide.rb file also has potential trip-hazards as Rich pointed out -
          e.g. in line#190 it's possible for it to reference an edge of a face that is no longer valid, as specified in an earlier line, so it falls over.
          This not valid issue occurs when your operation does something to geometry that affects a previously made collection of things -
          e.g. adding a new face [or edge] overwrites an existing face [or edge] so a reference to it is no longer valid.
          Again it's a simple fix - add a 'skip' trap near the start of the block -
          e.g. like this
          faces.each do |face| next unless face.valid? ... end
          which skips any invalid faces and so the errors are sidestepped.
          You can do a 'find' in the code to add in similar traps like this for any non-valid face, edge, vertex etc.
          Also note that the various blocks have an inconsistent format, swapping between
          xxx.each { |e| ...xxx... }
          to
          xxx.each do |e| ...xxx... end
          But editing either of them is possible with a little care.
          Both forms are acceptable, but choosing to use just one for consistency is recommended...
          S 1 Reply Last reply Reply Quote 1
            sashapepperspray @TIG
            @TIG thank you very much for your tips, I will hopefully fix them soon.
              sashapepperspray
              here is the new version, hopefully it is fixed (I gave the feedback to ai, and asked it to fix it 😊.
              mesh_tools_1.0.1.rbz
                I think you've trapped almost everything.
                However in the self.loop_dynamic_purge_ghost_material method you look at ent and then manipulate its material if it's a face or a group or a component-instance.
                But if those are no longer valid for some reason [I do suspect that could be an incredibly rare chance?] then it could throw an error and fall over.
                A simple check at the start of the method's do-block that is searching through the model.entities e.g.
                next unless ent.valid?
                skips any invalid ent
                Incidentally, without analyzing the whole code-set, firstly why not use model.active_entities which potentially reduces the list length, and secondly what about any faces within nested groups etc not inspected by this method that might still have that material ?
                  One further issue you should address before publishing this more widely - e.g. getting it 'signed' and in the EWH.
                  Its file naming does not follow the proper conventions.
                  An RBZ must contain just one .RB file that registers the extension and a folder of the exact same name.
                  Also the convention is to prepend the users 'name' at the start and even a sub-level if the modules do this.
                  So in your case there should be MendelAI_mesh_tools subfolder and a .RB file named MendelAI_mesh_tools.rb
                  You then edit the RB to load MendelAI_mesh_tools/loader
                  Because previous users might also now have the older badly named file/folder installer and loading you need to do some tidying up.
                  Add some code to the start of the RB to check for the existence of mesh_tools_loader.rb and mesh_tools subfolder in the Plugins folder -
                  use File.exist?(str) or better still similar methods in the fileutilities [which you need to 'require'] which will make deleting the subfolder and its contents much easier. So if these files exist you should also add a UI.message_box() to ask the user to restart to sync everything - next time the rogue file/folder won't be found and the code is redundant, but is still needed in any future updates in case a user has skipped this change in 1.0.2... A manual restart is preferable to a forced quit etc as the user might not have saved some work before updating etc.
