    AI generated subdivison plugin
    2 Posts 2 Posters 32 Views 2 Watching
      sashapepperspray
      In the past view weeks, I worked with ai to make a subdivision and mesh reduction plugin. I started off with this old plugin (https://github.com/NB70/sketchup-loop-subdivision), and got the ai to improve it, and then I got it to make a dynamic subdivision plugin, and a mesh reduction plugin. I don't really know ruby coding, so I can't say it will work, but it works for me. I will attach it here, hopefully someone finds it useful. I also am attaching a manual, generated by ai (obviously) from the code.
      mesh tool manual.pdf
      Mesh Tools.rbz
        Impressive result.
        Tons of Ruby Console errors
        #<TypeError: reference to deleted Face>
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:190:in `edges'
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:190:in `block in dyn_loop_getvertices'
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:188:in `each'
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:188:in `dyn_loop_getvertices'
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:345:in `block in dyn_loop_subdivide'
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:343:in `times'
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:343:in `dyn_loop_subdivide'
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:555:in `loop_dynamic_build_result'
        C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/mesh_tools/Dynamic_Subdivide.rb:581:in `block in loop_dynamic_schedule_rebuild'
