    Transparent SU Logo
    Scheduled Pinned Locked Moved SketchUp Forums
    17 Posts 3 Posters 1.6k Views 3 Watching
    • ntxdaveN Offline
      ntxdave
      I need a truly transparent SketchUp logo in a png format. I have tried a couple of ones I found online but they wind up with a background that is the little gray squares. I want to use it in a SketchUp file that has a background.
      Press F1...thank me later
        In image editors the little gray squares indicate transparency. Share the image you have so we can see exactly what you've got.
        @ntxdave said in Transparent SU Logo:
        Do you mean as a watermark?
        I pried this one out of SketchUp 2026. It has the gray squares in the image editor but those pixels are transparent.
          Or are you trying to make a 3D object to put on your background like a sign? Something like this?
          • ntxdaveN Offline
            ntxdave
            Here is what I am seeing:
              Share just the image you are using along with the .skp file with it.
              • ntxdaveN Offline
                ntxdave
                Here they are..........😁
                Transparent SU Logo.skp
                  Where did you get that image. It wasn't supplied with a truly transparen't background. It's a simple matter to select that background and remove it in an image editor, though.
                  • ntxdaveN Offline
                    ntxdave
                    What software do you use for something like that?
                    The only editor I have is Xara Photoand Graphic designer and I do not see that option. I thought I exported it as a transparent ping file but it must not have worked. I guess I could try again or could you help me? πŸ˜ƒ
                      I use PaintDotNet. It's a freeware image editor that is quite powerful. I used the Magic Wand tool to select the background and then pressed Delete. Xara probably has something similar but I don't have any experience with it.
                      • ntxdaveN Offline
                        ntxdave @Dave R
                        @Dave-R I tried to get it but it wanted me to create and account and wanted info that I did not want to supply (like credit card info). Maybe I downloaded the wrong thing. 😞
                        panixiaP 1 Reply Last reply Reply Quote 0
                          Really? I just click where indicated here:
                          And then here.
                          Maybe just do a little investigation in Xara and see what the process is for making transparent backgrounds.
                          • ntxdaveN Offline
                            ntxdave
                            Here is the screen I cannot get rid of.
                              Looks like you clicked on the wrong thing. If it won't go away power your computer off and restart it. Then try again.
                              • ntxdaveN Offline
                                ntxdave @Dave R
                                @Dave-R Thank you sir. I talked to some people online and that issue is now resolved.
                                  Dave R @ntxdave
                                  Which issue?
                                  • ntxdaveN Offline
                                    ntxdave @Dave R
                                    @Dave-R said in Transparent SU Logo:
                                    Which issue?
                                    The one that kept wanting me to create an account (the image I attached).
                                    • panixiaP Offline
                                      panixia @ntxdave
                                      @ntxdave if you don't need the full pro Photoshop experience, but you want a free clone (which allows you to follow along most basic Photoshop tutorials) you can also give a try to https://www.photopea.com/
                                      It will work in your browser (kinda like SketchUp free does) and doesn't need an account.
                                      You can also install it locally if you prefer.
