    Transparent SU Logo
    Scheduled Pinned Locked Moved SketchUp Forums
    17 Posts 3 Posters 2.4k Views 3 Watching
    • ntxdaveN
      ntxdave
      Here is what I am seeing:
      Press F1...thank me later
        Share just the image you are using along with the .skp file with it.
        • ntxdaveN
          ntxdave
          Here they are..........😁
          Transparent SU Logo.skp
            Where did you get that image. It wasn't supplied with a truly transparen't background. It's a simple matter to select that background and remove it in an image editor, though.
            • ntxdaveN
              ntxdave
              What software do you use for something like that?
              The only editor I have is Xara Photoand Graphic designer and I do not see that option. I thought I exported it as a transparent ping file but it must not have worked. I guess I could try again or could you help me? πŸ˜ƒ
                I use PaintDotNet. It's a freeware image editor that is quite powerful. I used the Magic Wand tool to select the background and then pressed Delete. Xara probably has something similar but I don't have any experience with it.
                ntxdaveN 1 Reply Last reply
                • ntxdaveN
                  ntxdave @Dave R
                  @Dave-R I tried to get it but it wanted me to create and account and wanted info that I did not want to supply (like credit card info). Maybe I downloaded the wrong thing. 😞
                  panixiaP 1 Reply Last reply
                    Really? I just click where indicated here:
                    And then here.
                    Maybe just do a little investigation in Xara and see what the process is for making transparent backgrounds.
                    • ntxdaveN
                      ntxdave
                      Here is the screen I cannot get rid of.
                        Looks like you clicked on the wrong thing. If it won't go away power your computer off and restart it. Then try again.
                        • ntxdaveN
                          ntxdave @Dave R
                          @Dave-R Thank you sir. I talked to some people online and that issue is now resolved.
                          Dave RD 1 Reply Last reply
                            Dave R @ntxdave
                            @ntxdave said in Transparent SU Logo:
                            Which issue?
                            • ntxdaveN
                              ntxdave @Dave R
                              @Dave-R said in Transparent SU Logo:
                              Which issue?
                              The one that kept wanting me to create an account (the image I attached).
                              • panixiaP
                                panixia @ntxdave
                                @ntxdave if you don't need the full pro Photoshop experience, but you want a free clone (which allows you to follow along most basic Photoshop tutorials) you can also give a try to https://www.photopea.com/
                                It will work in your browser (kinda like SketchUp free does) and doesn't need an account.
                                You can also install it locally if you prefer.
