    ReRender AI
    17 Posts 5 Posters 2.0k Views 5 Watching
    • pixelcruncherP
      Good stuff, I guess: https://rerenderai.com/ ? How much control did you have over the end result, and how much did it cost to create an end image?
      • Gus RG
        Gus R
        Mike, Pixelcruncher,
        It is ReRenderAI.com
        It's $45/month. I think I can use it for work projects and make money off it.
        Of course it's the usual AI so it sometimes does random things like when you think you've finally nailed it down and it totally changes the scene perspective and adds objects. It might be my text input? I don't think it is.
        I try and save my text input as a text file if I have to start over.
        I should probably round up some architectural samples to post here. I have other stuff I've been experimenting with.
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
        • Gus RG
          Gus R
          This was the original for that house above. It's an old NPR SU model I did probably 15 years ago.
          • Gus RG
            Gus R
            • Gus RG
              Gus R
              Another before and after using "enhance" with the text prompt "Put this train in an enclosed weathered train repair shop on a lift with a lot of dirty train locomotive repair men around it.."
              • Gus RG
                Gus R
                • L
                  Amazing images Gus. when I comment on AI assisted images the left and right hemispheres of my tiny little go into an argument. However I have no argument the those images are very compelling
                    Definitely great images.
                    • Gus RG
                      Gus R
                      Thanks guys. They do remain my models so I can always feel that AI is just another tool. I know I have my own personal disgruntled opinions about AI overall but with ReRender AI I've discovered an AI tool that relatively easy to use and gets pretty good results. I already did some quick AI renderings on a house I'm working on and the client now wants me to do one of my own renderings for him.
                      It's not perfect and has a mind of its own sometimes and it's almost impossible to get the same results all the time. It's usually a one shot deal "per rendering." Then you have to go back and work with the text prompts to get similar results. Overall though I can either have fun with it like with my train renderings or I can use it for work to get quick interior and exterior renderings in minutes which can lead to more work.
                      I've been using Sketchup to generate 3D models for rendering which I can also use to generate 2D cad exports to using in elevations for my plan sets. It's a 25 year old Autocad (ADT 3.3) which still works and is like my old favorite pencil.
                      Here's another ReRenderAI example. The first is just an original sketch with no material that's generated in D5 from a Sketchup model.
                      • Gus RG
                        Gus R
                        Bzzt...
                        Reply Quote 2
                          You cook great images, chef.
                          • jo-keJ
                            jo-ke
                            very impressive!
                            http://www.zz7.de
                            • Gus RG
                              Gus R
                              Here's another before and after for a kitchen remodel I'm working on.
                              Reply Quote 2
                              • L
                                The results can not be argued with Gus the are greatπŸ‘ πŸ‘ πŸ‘ πŸ‘
                                  ^ in spades, a keen eye and great mind leads to better results every time.
