    ReRender AI
    17 Posts 5 Posters 1.2k Views 5 Watching
    • Gus RG Offline
      Gus R
      I finally found an AI enhancer I can use for renderings that's easy to use and fun at the same time. There's the usual random nature of consistency in the end results. A lot back and forth with text prompts. Sometimes having to start over. Anyway here's one before and after example. I may post some more depending on interest.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
        That is a fairly decent result, how long winded was it?
        Which ai enhancer are you using?
          Good stuff, I guess: https://rerenderai.com/ ? How much control did you have over the end result, and how much did it cost to create an end image?
          • Gus RG Offline
            Gus R
            Mike, Pixelcruncher,
            It is ReRenderAI.com
            It's $45/month. I think I can use it for work projects and make money off it.
            Of course it's the usual AI so it sometimes does random things like when you think you've finally nailed it down and it totally changes the scene perspective and adds objects. It might be my text input? I don't think it is.
            I try and save my text input as a text file if I have to start over.
            I should probably round up some architectural samples to post here. I have other stuff I've been experimenting with.
            • Gus RG Offline
              Gus R
              This was the original for that house above. It's an old NPR SU model I did probably 15 years ago.
              • Gus RG Offline
                Gus R
                • Gus RG Offline
                  Gus R
                  Another before and after using "enhance" with the text prompt "Put this train in an enclosed weathered train repair shop on a lift with a lot of dirty train locomotive repair men around it.."
                  • Gus RG Offline
                    Gus R
                      Amazing images Gus. when I comment on AI assisted images the left and right hemispheres of my tiny little go into an argument. However I have no argument the those images are very compelling
                        Definitely great images.
                        • Gus RG Offline
                          Gus R
                          Thanks guys. They do remain my models so I can always feel that AI is just another tool. I know I have my own personal disgruntled opinions about AI overall but with ReRender AI I've discovered an AI tool that relatively easy to use and gets pretty good results. I already did some quick AI renderings on a house I'm working on and the client now wants me to do one of my own renderings for him.
                          It's not perfect and has a mind of its own sometimes and it's almost impossible to get the same results all the time. It's usually a one shot deal "per rendering." Then you have to go back and work with the text prompts to get similar results. Overall though I can either have fun with it like with my train renderings or I can use it for work to get quick interior and exterior renderings in minutes which can lead to more work.
                          I've been using Sketchup to generate 3D models for rendering which I can also use to generate 2D cad exports to using in elevations for my plan sets. It's a 25 year old Autocad (ADT 3.3) which still works and is like my old favorite pencil.
                          Here's another ReRenderAI example. The first is just an original sketch with no material that's generated in D5 from a Sketchup model.
                          • Gus RG Offline
                            Gus R
                            Bzzt...
                              You cook great images, chef.
                              • jo-keJ Offline
                                jo-ke
                                very impressive!
                                http://www.zz7.de
                                • Gus RG Offline
                                  Gus R
                                  Here's another before and after for a kitchen remodel I'm working on.
                                    The results can not be argued with Gus the are greatπŸ‘ πŸ‘ πŸ‘ πŸ‘
                                      ^ in spades, a keen eye and great mind leads to better results every time.
