    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Version 4.2.0 - 12.22.2025
      • Updated the opening and closing algorithm for all (panel) garage doors.
      Not a customer request, just an interesting kinematic challenge that I felt like addressing at some point. I found the previous garage door opening animation largely unsatisfactory for panel doors like these. Hopefully you can indulge me with a little gold plating... now back to the real stuff.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        I have posted a FAQ for licensing questions on my website with the most common questions that I am asked, hopefully this is helpful:
        Medeek Design Inc. - Medeek Extensions - Licensing
        Medeek Design Inc. - Medeek Licensing
        (design.medeek.com)
        design.medeek.com
        • medeekM
          medeek
          Version 4.2.1 - 01.09.2026
          • Enabled the CUSTOM E casing for rectangular windows.
          • Enabled the CUSTOM H casing for rectangular windows.
          • Added a STYLE H casing option for rectangular windows.
          design.medeek.com
          • medeekM
            medeek
            Version 4.2.2 - 01.11.2026
            • Enabled the CUSTOM casing for trapezoid windows.
            • Enabled the CUSTOM H casing for trapezoid windows.
            • Enabled the CUSTOM casing for arched windows.
            design.medeek.com
            • medeekM
              medeek
              I just received a very long and detailed email from one of my power users and I was thoroughly impressed with many of the suggestions and usability notes provided to me.
              A long standing issue has been wall cladding as it relates to exterior trim of windows and doors. Up until now if you place your trim on the sheathing (not on cladding) then the trim interferes with the cladding. This usually isn't too big of a problem (visually) provided your cladding is not thicker than your trim. However, in the real world you generally install your trim first and then butt your cladding up to it, so there is no interference. When your cladding is thicker than your trim or you are using one of the 3D cladding options (ie. board and batten) this does become a bit of an issue and for me personally has been an annoying lack of realism now for a few years.
              To fix this I needed to enable an option where one can toggle the trimming of the cladding by the exterior trim and then add some logic and geometry into the current algorithms so that the end result is as follows:
              I won't bore you with the details of the rather complicated logic under the hood that accomplishes this but suffice it to say it is not trivial. It will take about 4-5 days to complete this update.
              The window algorithms are now updated but I will need to update the door and garage door methods as well now.
              In the global settings one will be able to independently toggle this on and off for windows, doors and garage doors. I will also probably put out another tutorial video on this feature specifically so that everyone is clear on how it works.
              design.medeek.com
              • medeekM
                medeek
                Version 4.2.3 - 01.18.2026
                • Added an option (global settings) to remove cladding with the exterior trim of doors, windows and garage doors.
                design.medeek.com
                • medeekM
                  medeek
                  Tutorial 80 - Removing Cladding (5:43 min.)
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 4.2.4 - 01.19.2026
                    • Added bypass (2 panel - solid) doors to the door module.
                    This door type added per customer request.
                    At some point I should probably add in the "barn door" type, these seem to be quite popular these days.
                    design.medeek.com
                      MtnArch
                      Popular now, but give it another 5 years and there will be a new "it" feature to work with.
                      Highest Regards,
                      Alan T. Hendry, RA
                      Architect
                      medeekM 1 Reply Last reply
                      • medeekM
                        medeek
                        Version 4.2.5 - 01.20.2026
                        • Added an option (global settings) to miter trim for rectangular doors and windows.
                        • Fixed a minor bug with the remove cladding feature introduced in Version 4.2.3.
                        This update per customer request.
                        design.medeek.com
                        • medeekM
                          medeek @MtnArch
                          @MtnArch
                          My last house had three of them and I found them quite clunky to use. They look nice but functionality is marginal.
                          design.medeek.com
                            MtnArch
                            And privacy next to non-existent. I can see in a primary bedroom for the ensuite, but I see them being used for powder baths now, too. Yikes!
                            Highest Regards,
                            Alan T. Hendry, RA
                            Architect
                            • gullfoG
                              gullfo
                              anyone seeing my naked through my windows is all the punishment they need... 🙂 Mindwash® is very expensive... LOL
                              Glenn
                              http://www.runnel.com
                              • medeekM
                                medeek
                                Version 4.2.6 - 01.24.2026
                                • Added a one and two panel option for rectangular half glass and 3/4 glass doors.
                                • Added a one and two panel option for rectangular double half glass and double 3/4 glass doors.
                                • Added a one and two panel option for arched half glass and 3/4 glass doors.
                                • Added a one and two panel option for arched double half glass and double 3/4 glass doors.
                                  wall_su1054_800.jpg wall_su1055_800.jpg wall_su1056_800.jpg wall_su1057_800.jpg
                                There are many other door configurations I could add but these were obvious low hanging fruit so I jumped on it and knocked it out fairly quickly. I will take another look at pocket doors and bypass doors and see if I can add some panel options to those as well.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  I was also wondering if anyone had any thoughts on kick plates for doors. Is this something anyone is interested in?
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 4.2.7 - 01.26.2026
                                    • Added a kick plate option for all swing doors (rectangular and arched).
                                    Yet another update following up on a customer request. Probably not the highest priority on my list but a welcome addition for those that need this feature.
                                    The kick plate(s) can be positioned on the exterior, interior or both sides of the door. The height and thickness is configurable. For now the margin at the edge is hard coded in at 0.75 inches (width is auto calculated based on door size). The material (ie. brass, nickel etc...) is configurable the same way the door hardware is.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Tutorial 81 - Door Kick Plates (4:29 min.)
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 4.2.8 - 01.27.2026
                                        • Added the following steel column types to the column module: Round (HSS), Pipe (NPS).
                                        Update per customer request.
                                        You can now add round steel in-wall columns into your Medeek walls. These aren't actually lally columns since that specific product is typically installed with an adjustable screw assembly. However for most design purposes I think showing the round column like the image above will suffice.
                                        Lally Columns
                                        Custom Sizes & Wholesale
                                        Budding Co (buddingco.com)
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 4.2.9 - 01.30.2026
                                          • Added a base plate (top and bottom) option to the post module.
                                          • Fixed a bug in the post module related to hardware caps and bases.
                                          • Updated the bypass door opening algorithm so one can open both sides of the door.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 4.3.0 - 02.01.2026
                                            • Added a base plate (top and bottom) option to the in-wall column module.
                                            • Added "Opening Outline" options to the General tab of the Global Settings for windows, door and garage doors.
                                            The option to set the opening outlines as regular edges or dashed (construction lines) was requested by a user. This option only changes the outline created at the top of the wall, it does not change or remove the door swing symbol or the garage door extent outline (dashed construction line).
                                            I’m trying to not add more parameters and options but users always contact me with something new they need. Everyone has their own workflow or the way they want things to appear in Layout. Flexibility and a smorgasbord of options is critical but at the same time it does balloon the number of parameters and increases complexity which tends to scare away some potential users.
                                            I always tell new users to not be frightened of all the options, if you don’t know what it does then just leave it as default, that is generally your safe bet.
                                            design.medeek.com
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 80
                                            • 81
                                            • 75 / 81
