    [REQ] PDF Importer
    20 Posts 11 Posters 2.8k Views 11 Watching
    • pbacotP
      Personally I already use dxf anyway. It would only be better for me if it improved the resulting geometry.
        d12dozr
        You guys...Adam is scanning hand drawings...he can't use a PDF to DXF converter.
        we generally scan all of our hand drawings into a plotter and it creates a .pdf.
        Adam, I bet there is a setting on the scanner to make a JPG rather than a PDF. What kind of scanner/plotter is it?
        http://goo.gl/f7ooYh
          Good point...
          Hand drawn scans will never be vector PDFs...
          My scanner offers PDF/JPG/PNG options.
          You still need to insert the Image, group it scale it inside the group with the Tapemeasure tool to a known dimension etc; and then overdraw the edges but it misses out a PDF-to-anything conversion step......
          • U
            unearthed
            to convert images to dxf in the past I've successfully a trial of wintopo http://wintopo.com/pricing.htm (US$340)
            and more recently have had better mileage using http://vectormagic.com/home which allows two free conversions and has a monthly US$8.00 fee - I use it mainly when %^&*ing house designers refuse to send me a .dwg file or when councils refuse to release the data from their GIS and I have to get it from a screen shot.
            the results usually need cleaning up a bit but is a lot faster than hand tracing - and if i remember rightly wintopo will split out coloured lines into diff layers even with the free version (http://wintopo.com/wintopo-free.htm).
            Growplan - People ∩ Plants ∩ Place
            windows 7 64b, 4GB RAM, SU 8.0.16846
            Gimp, QGIS, Vectorworks 12, Bricscad 11
            • EarthMoverE
              EarthMover
              Good point. I'll have to check on that. Technically I guess it's not a plotter, just a 36" printer / scanner made by Ricoh.
              I know the scans are raster pdf's and don't expect to glean vector lines from them. I have Vector Magic as well, but for what we do, it's faster to trace.
              I work with .pdf files generated in CAD though as well.
              I guess the whole thread was an attempt to not let Mac users feel special. 😄
              Content Creator at Skapeup
                Acrobat reader doesn't even convert a .pdf to an image
                If you select the Snapshot tool and press CTRL+A and then CTRL+C then in PhotoShop
                File > New > From Clipboard > CTRL+V
                This works for other Image Editors also.
                • EarthMoverE
                  EarthMover
                  Good tip Rich. Thanks!
                  • rodrigonotorR
                    rodrigonotor
                    Maybeis to late, but, perhaps still work for you http://www.imsidesign.com/Products/CADCompanionProducts/pdf2cad/tabid/1722/Default.aspx?cid=422390
                    • Sketchando.net • www.arqcad.net •
                    • F
                      FlorinAp
                      This one is no longer available on their website, so I thought that the information should not be lost; it works only up until SU2023 (inclusive).
                      It imports raster and vector.pdf2skp_23 Softtech_EinsteinConcept.zip
                      I apologize if i made a mistake by uploading an executable in this forum.
                        SketchUp 2026 on Winodws imports PDF files natively. No need for an extension.
                        F 1 Reply Last reply
                        • F
                          FlorinAp @Dave R
                          @Dave-R SU 2026 imports only raster, no vector.!
                          Dave RD 1 Reply Last reply
                            Dave R @FlorinAp
                            @FlorinAp that's exactly the same as it's been on Mac forever. The developers have indicated that vector import is on their roadmap.
