    Small Engines and Stuff
    27 Posts 6 Posters 3.8k Views 6 Watching
      I agree with t'others, really good to see these.
      Dave RD 1 Reply Last reply
        Dave R @Mike Amos
        @Mike-Amos
        Thank you!
          Another machinist's model. A 2 cylinder engine for a paddle steamer with reversing qear. The paddles are articulated so their angle changes as the wheels rotate. Still need to time the valves and properly align the eccentric straps with the eccentrics and of course add screws and nuts.
          Rendering straight out SU2026 with a wee bit of simple post processfor the soft shadows and background color.
          • tuna1957T
            tuna1957
            Fantastic. Iโ€™m assuming this is a scale model of what was in a full size steamboat. If thatโ€™s the case just how big would this wonderful machine have been in full size ?
              Thank you!
              Yes. My model is based on a small desktop machinist's model. I believe it was based on a real one but I have no idea how large it would have been.
                Another little engine. These are addictive.
                For reference, the flywheels are 100mm diameter.
                1 Reply Last reply ๐Ÿ’ฅ
                  Are you gonna shoot the 3I/Atlas as it passes?
                    LOL! It does look a little like a cannon.
                      Here's a cutaway view.
                      1 Reply Last reply ๐Ÿ‘
                      Reply Quote 4
                        Amazing little Gems. No doubt.
                        1 Reply Last reply ๐Ÿ‘
                        • Bryan KB
                          Top notch work as always. Model, style and choice of subjects. Top notch.
                            Thank you all.
                              Here's a little boxer engine intended to run on compressed air. For reference, the large gear is about 50mm dia.
                              Like usual I haven't added screws
                                Pretty sharp, does it have a scavenge system for exhaust into a lower pressure reservoir, a la steam engines?
                                  Thanks. No scavenger system for the exhaust. It's just dumped out into the room. On the other hand it's only compressed air going in.
                                    Got it, if you can scavenge the exhaust air it can make the process more efficient, hence the three cycle steam engines. At least if I understood Fred anyway.
                                      A compound steam engine directs the exhaust steam from the first cylinder (smallest one) into the next cylinder which is larger. In the case of a triple expansion engine, a third cylinder (largest of the three) gets the steam from the second cylinder. This works because the steam still has energy to expand after the first and second cylinders. It does require the cylinders get progressively larger.
                                        Thanks, thought I had messed the system up somewhere.
                                          Here's a flyball governor. Modeled and rendered in SU2026.
                                          Reply Quote 2
