Plugin to quickly open nested Component or Group?
I'm currently working on a rather detailed model which has a lot of nested Components and Groups.
To speed up editing these Components and Groups, that are often nested tens of layers deep, I was wondering whether there was a Plugin out there that would instantly drill down through all the parent Components and Groups to the Component or Group that I've just clicked on with the mouse cursor?
It would effectively be like clicking directly on the particular instance of a Component and Group (boy am I sick of typing that!) in the Outliner, without having had to expand the parent tree.
Use the Outliner.
You can then expanded the 'tree' and select the nested Container, and double-click it in the Outliner to edit it that way. -
@TIG The issue I'm trying to avoid with using the Outliner, is the amount of visual searching, scrolling, and clicking that is required. I have to know and look for the name of not just the Group or Component I want to edit but also it's top level parent, and any child Group(s) or Component(s) it's part of. Which is something that's not always easy even when everything is logically named and arranged, both in the model itself and in the Outliner, let alone when I've been lazy and have a bunch of Groups all named "Group" or numerous variations of "Component#123".
I do want to stress though, that the issue I'm trying to avoid is not solved by naming everything properly... I still have the issue when working on my models that are meticulously organised.
Ideally, I'd like to be able to hold down a keyboard key, such as Alt, and then click on what I want to open for editing. Some of the Plugins I've found so far, require the use of the context menu and one or more submenus. Or they have you use one of the dropdown menus on the title bar area. Again, that's something I'd like to avoid if possible.
maybe vbo jump to levels-https://extensions.sketchup.com/extension/584dba2f-6938-4f03-a1de-df61213cc672/vbo-jump2levels
@sashapepperspray said in Plugin to quickly open nested Component or Group?:
Seems really useful, didn't know about that. I'll try it.
Many thanks for introducing me to this extension which allows me to edit materials on faces deeply buried in groups or components.
Is VBO Jump to level stable on your machine? I had a first crash with SU 2024, but it's very good, otherwise
Also Curic 2 Level, much better than VBO
I'll try Curic 2 level, thanks !
It's fixed, sorry... a tag was hidden, a remnant of the DWG file
@Krass VBO has a newer and better version, but there is no way to download it; i wrote to them but nobody answered...
The version of VBO Jump to Levels I installed is unstable on 2024. But perhaps you're referring to the pipe plugin? Jump to Level can be replaced by Curic 2 Level, which is more stable.
@Krass No, i was referring to VBO Jump to Level - a version presented by them in a video, but unavailable to download.
it as become a paid extension with the 1.0.5 update https://www.kcdallc.com/product-page/vbo-jump-2-levels
It's cheap, but if it also crashes on SU 2024...
no, I was wrong: you can get it for free entering a coupon code "vbofree"
erratum : No, in fact, you get version 1.0.1 by downloading it from their website in free mode... it's all very unclear.
Anyway, Curic 2 Level + Curic Copies (or S4U PickUp) does the same thing as this one. I use S4U PickUp cause is better than Curic Copies.
And Curic Select++ does the same thing as Curic To Level, but still i find Curic To Level better. -
R Rich O Brien has marked this topic as solved on
