[Plugin] TrueTangents v3.0
Is it possible to draw an arc tangent to two others?
Thank you very much -
Do you mean a common-tangent to three arcs ?
It will be possible in some 'special' cases, but then you can contrive three arcs which can never all share a common-tangent...
Please give a clear example...
Or explain your question more clearly... -
I mean to draw an arc tangent to two circles.
Like in the image.
In the previous drawing the circles O1 and O2 are known
Sorry, very grateful for your attention!
It would also be interesting if it allows solving situations like this:
can this be updated to Sketchup 2025 or higher please?
This works in all newer versions of SketchUp.
@Gili It works perfectly in SketchUp 2025 and 2026. I've been using it a great deal. I used it repeatedly the other day to set up the linkages on this paddle wheel.
