    [Plugin] TrueTangents v3.0
    95 Posts 34 Posters 118.9k Views 34 Watching
      dedmin
      @tig said:
      @dedmin said:
      Hi TIG. I installed TrueTangents via latest SketchUcation Plugin Store. It works, but why are the tool-tips displayed in the Ruby console and not in the status bar?
      Latest SU Pro, Win 7 64 bit latest.
      Thanks.
      [attachment=0:2c4kpk1c]<!-- ia0 -->Capture-2.jpg<!-- ia0 -->[/attachment:2c4kpk1c]
      This toolset was originally designed to run from the Ruby Console, or from within other methods - so the tools' guidance/errors go into the Ruby Console, rather than the status-bar or an error message-box...
      It's the same in all SketchUp versions - it's not v2014 specific.
      πŸ€“
      I see. πŸ€“
        bobsammer
        Does the True Tangent plugin work in SU2017?
        Bob
          Bob
            tecnozati
            Is it possible to draw an arc tangent to two others?
            Thank you very much
              Do you mean a common-tangent to three arcs ?
              It will be possible in some 'special' cases, but then you can contrive three arcs which can never all share a common-tangent...
              Please give a clear example...
              Or explain your question more clearly...
                tecnozati
                I mean to draw an arc tangent to two circles.
                Like in the image.
                Aplicacion-de-las-tangencias-Enlazar-dos-circunferencias-mediante-un-arco-de-radio-conocido.png
                  tecnozati
                  In the previous drawing the circles O1 and O2 are known
                    tecnozati
                    Sorry, very grateful for your attention!
                      tecnozati
                      It would also be interesting if it allows solving situations like this:
                      https://dibujotecni.com/wp-content/uploads/2012/12/Aplicacion-tangencias-enlazar-dos-circunferencias-punto-tangencia-inversion2.png
                        Gili
                        can this be updated to Sketchup 2025 or higher please?
                          This works in all newer versions of SketchUp.
                            Dave R @Gili
                            @Gili It works perfectly in SketchUp 2025 and 2026. I've been using it a great deal. I used it repeatedly the other day to set up the linkages on this paddle wheel.
                            • 5 / 5
