    [Plugin] TrueTangents v3.0
    95 Posts 34 Posters 120.3k Views 34 Watching
      I believe that make that πŸ˜„
      http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=4c456a620293175a29e2553cc76a28b2&filename=TanTanObjectSnap.gif
        dedmin
        Hi TIG. I installed TrueTangents via latest SketchUcation Plugin Store. It works, but why are the tool-tips displayed in the Ruby console and not in the status bar?
        Latest SU Pro, Win 7 64 bit latest.
        Thanks.
          Thanks.
          [attachment=0:ahmfglq7]<!-- ia0 -->Capture-2.jpg<!-- ia0 -->[/attachment:ahmfglq7]
          This toolset was originally designed to run from the Ruby Console, or from within other methods - so the tools' guidance/errors go into the Ruby Console, rather than the status-bar or an error message-box...
          It's the same in all SketchUp versions - it's not v2014 specific.
          πŸ€“
            dedmin
            Thanks.
            [attachment=0:2c4kpk1c]<!-- ia0 -->Capture-2.jpg<!-- ia0 -->[/attachment:2c4kpk1c]
            πŸ€“
            I see. πŸ€“
            • B
              bobsammer
              Does the True Tangent plugin work in SU2017?
              Bob
                Bob
                • T
                  tecnozati
                  Is it possible to draw an arc tangent to two others?
                  Thank you very much
                    Do you mean a common-tangent to three arcs ?
                    It will be possible in some 'special' cases, but then you can contrive three arcs which can never all share a common-tangent...
                    Please give a clear example...
                    Or explain your question more clearly...
                    • T
                      tecnozati
                      I mean to draw an arc tangent to two circles.
                      Like in the image.
                      Aplicacion-de-las-tangencias-Enlazar-dos-circunferencias-mediante-un-arco-de-radio-conocido.png
                      • T
                        tecnozati
                        In the previous drawing the circles O1 and O2 are known
                        • T
                          tecnozati
                          Sorry, very grateful for your attention!
                          • T
                            tecnozati
                            It would also be interesting if it allows solving situations like this:
                            https://dibujotecni.com/wp-content/uploads/2012/12/Aplicacion-tangencias-enlazar-dos-circunferencias-punto-tangencia-inversion2.png
                            • G
                              Gili
                              can this be updated to Sketchup 2025 or higher please?
                              Dave RD 1 Reply Last reply
                                This works in all newer versions of SketchUp.
                                  Dave R @Gili
                                  @Gili It works perfectly in SketchUp 2025 and 2026. I've been using it a great deal. I used it repeatedly the other day to set up the linkages on this paddle wheel.
                                  • 5 / 5
