    SketchUp 2026 Released
    8 Posts 5 Posters 1.8k Views 4 Watching
      Release Notes : https://help.sketchup.com/en/release-notes/sketchup-desktop-20260
      The shorter version below:
      SketchUp
      • Share SketchUp models via private invite or public link. Leave comments and see updates in real-time
      • Distance Multiplier and color controls for Ambient Occlusion
      • Performance boost both memory and working efficiency
      • Live Components
      • Improvements across scaling, rotating, scenes, and inferencing.
      • Reset all activations and authorize your current device
      LayOut
      • Updated icons, tray and panels
      • New tools: Trim, Extend, Fillet, and Chamfer
      • Scrapbook Improvements
      • Importing and Exporting Improvements
        Glenn at home
        Giving it a go, let's see how it does πŸ˜‰
          @Glenn-at-home I found it more performant. With large amounts of arrayed components in previous versions I would get that wire bounding box.
          Similar tests with this release and I'm not getting it so far. Reminds me when we got the speed boost between v6 and v7. Not as dramatic as that but definitely noticeable.
          G 1 Reply Last reply Reply Quote 2
            Glenn at home @Rich O Brien
            @Rich-O-Brien So far it does seem a bit "faster" or more responsive. I like the included plugin migration. So far all but 1 3rd party plugin seems to be working, Ambient Occlusion but that's to be expected.
              Dave R @Glenn at home
              @Glenn-at-home said in SketchUp 2026 Released:
              Do you still need the Ambient Occlusion extension since SketchUp has it natively?
              Did you use the Sketchucation ExtensionStore to install your bundle of Sketchucation extensions?
                Glenn at home
                I've already paid for it, years ago, and I actually prefer it.
                No, I do not use the Sketchucation Extension. No offense but I don't want a 3rd party handling my extensions. I played around with a recent design and so far all good on this end! πŸ™‚
                • Gus RG Offline
                  Gus R
                  I'm still using Sketchup Pro 2022. I have 2025 loaded and it's running fine. Short of the really bad icons.
                  www.instagram.com/gusrobatto/
                  www.facebook.com/gusrobatto
                  • gullfoG Offline
                    gullfo
                    any timeline to fix the preferences -> file locations? regardless of the setting, it simply shows the default install folders. then i have to remove those and replace with junctions to get them to point to the locations i want (versus whatever the program wants) so materials ,components, and styles are still not responding to the settings in preferences.
                    Glenn
                    http://www.runnel.com
