    Copies of Cut Opening Component, Not Cutting the Opening
    13 Posts 3 Posters 1.9k Views 2 Watching
    • gullfoG Online
      gullfo
      so, after how many years of this functionality seeming to not be working, it seems like it's still not working.
      a simple component with a pair of cut opening components (back to back). the first set of the copies - works as expected. second (and other copies) nada, zip. the components are there but the cutting is missing...
      so, are cut opening components not support in dynamic components?
      i've seen people recommend a paid-for tool (VisuHole) but that doesn't seem to be workable in a dynamic component.
      attached is the component. routed absorber frame.skp
      Glenn
      http://www.runnel.com
      • gullfoG Online
        gullfo
        as an fyi - i make make a component, then my cutting component, manual add it to the face on the primary component, it cuts. then a copy (m + ctrl to copy) that one also cuts. so something is wrong with the dynamic component use because the same copied set of attributes (whichever one says this one cuts) should be carried to the next copy(s) as well..
        acomponent.skp
        something to do with depth... with the flat version - cuts on a flat component - ok. one depth versions, first one cuts, second does not.
        non-dynamic - copies cut as expected...
        acomponent-nodyn.skp
        Glenn
          If you flip the host part to be flat on Z and jiggle the cutters they'll sort themselves out...
          Or use SuperGlue by Thomthom
          It reminds SketchUp the 'Cutter' and face relationship for when it messes up.
            pcmoor
            For DC, embed in second cutter (parent is a cutter as well)
            acomponent.skp
            gullfoG 1 Reply Last reply Reply Quote 1
              pcmoor
              This post is deleted!
              • gullfoG Online
                gullfo @pcmoor
                @pcmoor said in Copies of Cut Opening Component, Not Cutting the Opening:
                turns out cutting things which subsequently need to be rotated is not reliable... 😞 so back to using individual components to create it...
                i was hoping the cutting components in an array would do it, but then it's getting confused on rotations and trying (or seeming to) glue itself. changing to "any" didn't do it either, and left weird disconnected geometry on angles vs the 90Β° i was trying to set. anyways, this is what it looks like after i created with with sub-components to build the board...
                Glenn
                  pcmoor @gullfo
                  @gullfo
                  for DC holes
                  build on same axis, xy plane with z up
                  this suits opencutlist
                  top cutter copies should be contained in top cut cutter
                  bottom cutter copies should be contained in a bottom cut cutter
                  if you have to use different axis in a cuboid, there should an extra level or child to isolate the rotation. But much easier to keep all in same orientation
                  checkout my DC warehouse pages
                  https://3dwarehouse.sketchup.com/model/25c4463957ad36c2635f69bba8c8ac7/dynamic-hole-builder
                  • gullfoG Online
                    gullfo
                    yeah, i do the paired front and back. then added those as an array (per your guidance), but yet another level of indirection to try to prevent weird results when doing simple rotations? lol. i keep trying to use the cut opening, but it's really only sufficient for the simpliest stuff. using them in something like structures where i use copies of framing members (for example) it's been painful and not reliable. esp when the cut opening only works on a face and not (at least) a group, so the odds that the face and associated geometry will properly scale (and reset) etc is a crap shoot really.
                    thanks i'll check out your component
                    Glenn
                    • gullfoG Online
                      gullfo
                      so, with the array approach, it's holding steady on simple (no edge) geometry rotated, but the face shrinkage continues to exist. anyways in case anyone is interested in the DC - cut openings phenomena...
                      example of why we cant have nice things.skp
                      Glenn
                        pcmoor
                        as said before, rotations should be isolated with an extra level
                        this has always been the issue with DCs
                        example-of-why-we-cant-have-nice-things.skp
                        • gullfoG Online
                          gullfo
                          ok, so adding a parent component which controls the copy and rotate, i just need to add the parameter selections in the parent and pass them to the (what was) the original component (now the child) and it seems to be working. appreciate the assist. this is an annoying feature... πŸ™‚
                          Glenn
                          P 1 Reply Last reply Reply Quote 1
                            pcmoor @gullfo
                            @gullfo
                            I agree, yet the alternative, Live Components, at this stage is still not practical. It's taking far too long to compete, image if 1% of that money was afforded to DCs!
                            • gullfoG Online
                              gullfo
                              yeah, not a fan of live components. as a "component factory" it has value, but for many of us doing complex work where dynamic components can be rapidly adjusted, scaled, etc. the DC need a lot of love which it's not getting. what would also be nice - letting non-pro users use DC but no option to peek inside or adjust anything other than exposed parameters. but i'm thinking somewhere someone got the idea of the potential for charging people to generate a "live component" and download it - voila! instant money maker... eeerrghh.
                              Glenn
