    WIP - Kitchen
    22 Posts 4 Posters 2.4k Views 4 Watching
    • Gus RG Offline
      Gus R
      Meanwhile on the reverse side.
      Spinning my wheels with all this professionally. All spent with Upwork which hasn't gone anywhere. Over 30 "proposals" and not a single job from Upwork and you have to pay for those proposals.
      Making a few bucks off some work from Facebook. People don't even want to spend what I used to charge in the late 2000's. I have a couple of regular clients in the real world.
      Oh well. At least I can still make pretty pictures.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      L 1 Reply Last reply Reply Quote 2
        Just a thought here, for consideration. When you make and texture these models, you COULD set them up as card and paper models and sell them. This is not a get rich scheme b ut might make a few extra bucks and if you are building the model it may as well have a second life.........
        Flattery or equivalent.
        • Gus RG Offline
          Gus R
          • Gus RG Offline
            Gus R
            More stuff.
            I need to do a bedroom.
              Please excuse me while I pick my jaw, off the floor.
                L i am @Gus R
                • Gus RG Offline
                  Gus R
                  Thanks guys!
                  Bedroom. Needs more work but I did start this morning.
                  Dresser looks too red. 😊
                  • Gus RG Offline
                    Gus R
                    Thanks guys!
                    Bedroom. Dresser looks too red. Started this morning.
                    • Gus RG Offline
                      Gus R
                      A little warmer with some curtains and other details.
                        Better and more inviting, thanks for the inspiration it is always helpful.
                          • Gus RG Offline
                            Gus R
                            Thanks Mike.
                            Other side of the bedroom.
                            • Gus RG Offline
                              Gus R
                              Side view of the bedroom using D5's section.
                                The only area I can see to alter is the fire in the 'place. It is obviously a 2d graphic. If it is painted into a component, try adding several at different angle and see if a certain degree of 'normal' or bump can be added. I will see if it can be done with what I have. Twilight used to manage OK.
                                Otherwise, you still rock.
                                • Gus RG Offline
                                  Gus R @Mike Amos
                                  @Mike-Amos
                                  It's a 3d D5 Render "particle" that's animated.
                                  Gus Robatto Bedroom WIP 05.mp4
                                  I replaced it with a smaller one.
                                  Added some more bells and whistles.
                                    Mike Amos @Gus R
                                    @Gus-R
                                    Thanks for the explanation, looks great.
