    changing radius on a radius
    11 Posts 3 Posters 551 Views 3 Watching
      Leggy
      evening all, I'm trying to put a radius around the tube on the outside and inside of the main body, any one got ideas?
      the radius needs to go the extremes of the main body , so nothing at the top, 29 at the bottom and 8 to the side (model is scaled up)
      its for a vacuum port , this is only a prototype, so its a bit rough
      thanks Dean
        Leggy
        bosch dust collector 6.dwg bosch dust collector 6.dxf
        hope these help
          This is more suited to a NURBS environment rather than SketchUp because you are lookiing to create variable fillets.
          ToolOnSurface Offset tool will help you out to a degree to get some type profiles you could loft. But there's no magic bullet.
              It is possible to model fillets with changing radii in SketchUp. I do it fairly often using tools like TIG's Extrusion Tools or Fredo's Curviloft but Rich's suggestion and example is probably more straightforward.
                @Dave-R
                In the example file it's not as a clean and pre-planned as your good example.
                I think that it is doable but not on the file shared. Where the tube is intersecting the flat top face is a bit of a mess. The tube geometry has a few probably unintentional edges.
                You can do this but you need to pre-plan the profiles to get the nice results Dave does in his sleep.
                  Leggy
                  thanks for your time guys, instead of a radius I went with a chamfer, pulled the tube through then scaled the end up. This would be fine, all be it a lot neater , but the profile would work
                  bosch dust collector 7.dwg
                    Leggy
                    I tweaked it a bit more, its not 100% , but I think it could work
                    bosch dust collector 8.skp
                      Well, it makes a solid component so it should be printable. How tall is the final thing supposed to be?
                        Leggy
                        its for a Bosch mitre saw for dust extraction , about 80mm
                          Leggy
                          its the dark blue part wrapped around the blade with the flexible tube coming off it
