    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 710.2k Views 121 Watching
      PS: Also make sure that you have installed the latest version of the extension, LibFredo6 and the SketchUcation toolset [for the licensing], and have restarted SketchUp...
        mstumpo
        Tools On Surface not displayingOK, I got past this and all appears good. However, the toolbar for Tools On Surface is blank on my screen. In fact, any plugin that uses on-screen options shows as blank. Nvidia driver issue? see attached.
        • fredo6F Offline
          NEW RELEASE: FredoTools v4.5a - 02 Apr 24
          Requirement:
          • LibFredo6 v14.3b or above
          FredoTools 4.5a is a maintenance release for:
          • Future compatibility
          See FredoTools plugin home page for Download.
          See also main post of this thread for User Discussion.
          yanrothwellY 1 Reply Last reply Reply Quote 0
          • yanrothwellY Offline
            yanrothwell @fredo6
            @fredo6 Hi I have used Fredo6's tools for manyt years and they are always super useful.
            At present, since SU2024 I have had issues with SUClock, which I stopped using whilst it was updated.
            I've since started using SUClock since the update and its been working fine.
            Today I started up SU2024 with an existing project (double clicking on the skp file itself, incase that is ever relevant how I 'opened up' the file) and I got the following error.
            This error hasn't gone away and did not start working up next restart of SU2034, so I wonder if you can help - Screenshot 2024-06-04 104337.png
            I see the icon of SUClock but it does nothing when clicked on.
            Multiple restarts have not fixed anything. There are similar errors with ThruPaint and Toposhaperm unforrtunately. Can anyone help? plugin information as follows:
            Fredo6 Plugins Information on 2024-06-04 12:00:59 +0100
            • Sketchup: 24.0.484
            • LibFredo6: v14.5b
            • LibFredo6 Binary loaded
            • Sketchucation ExtensionStore: 4.4.0
            • SCFLicense: v6.4a - 74
            • Fredo6 Plugins
              LordOfTheToolbars v2.7b
              Curviloft v2.0a - licensed FULL
              Curvizard v2.5a
              FredoCorner v2.7a - licensed FULL
              FredoScale v3.6a - licensed FULL
              FredoTools v4.5a
              JointPushPull v4.8a - licensed FULL
              SUClock v3.1a
              ToolsOnSurface v2.6a - licensed FULL
              TopoShaper v2.7a - licensed FULL
              Signature File: 2022-03-30 14:03:14 +0100
              ClothWorks: 2022-10-27 15:42:55 +0100
              Curviloft: 2022-09-03 15:21:17 +0100
              FredoCorner: 2024-03-04 13:57:21 +0000
              FredoScale: 2022-04-25 11:42:35 +0100
              FredoSpline: 2022-11-21 16:26:56 +0000
              JointPushPull: 2022-05-08 14:44:25 +0100
              ToolsOnSurface: 2022-04-25 13:46:45 +0100
              TopoShaper: 2022-09-02 16:10:20 +0100
            MrHide_1.8a
            AutoInstall Finished.
            Using Main Plugins Folder.
            C:/Users/<user>/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins
            http://www.ianrothwell.co.uk
            fredo6F 1 Reply Last reply Reply Quote 0
            • fredo6F Offline
              fredo6 @yanrothwell
              @yanrothwell
              Did you install SU2024 with 'Run as dministrator'?
                yanrothwell @fredo6
                @fredo6 yes
                • fredo6F Offline
                  fredo6 @yanrothwell
                  @yanrothwell
                  Could you open the Ruby console and copy paste the following command, and then type Enter:
                  UI.openURL F6_SUClock::Project.get_tmpdir
                  This will open the temp directory, in which you have files with extension .txt and a form like XXX__YYY.txt.
                  Just erase them. It seems that one of them is corrupted.
                  Erasing them should not impact your SUClock data.
                  Then restart Sketchup.
                  yanrothwellY 1 Reply Last reply Reply Quote 1
                    yanrothwell @fredo6
                    @fredo6 Many thanks - after doing just that and restarting, it worked. no errors upon startup.
                    Cheers \o/
                    • fredo6F Offline
                      NEW RELEASE: FredoTools v4.5c - 24 Jun 24
                      Requirement:
                      FredoTools 4.5c is a maintenance release for:
                      • Fix for the caluclation of volumes in SolidVolume
                        rv1974
                        a true Doh! moment - Angle Inspector has Slope meter in %% ! Many many thanks, Fredo.
                        P.S. Maybe one day it would become interactive - showing live the slope altering.
                        • 16
                        • 17
                        • 18
                        • 19
                        • 20
                        • 23
                        • 24
                        • 18 / 24
