    [Plugin] 3D Text Editor
    204 Posts 51 Posters 231.0k Views 50 Watching
      Did you look in the Draw menu? Make sure you have installed the most recent version and also the latest TT_Lib2 installed.
      • atelierpaarA
        atelierpaar
        ok that was it !!
        the draw menue ist the thing to look for,
        thanks for your advice
        Uli
          @atelierpaar said:
          ok that was it !!
          Uli
          Happy that took care of it. πŸ‘
          • P
            pierrearchi26
            hello ThomThom,
            I'm trying to use the plugin to import Sketchup dimensions lines into Sketchfab which is a well known big problem (if you don't use a picture for it)... I use the plugin to create the 2d dimension line value ... but i need the line ... maybe a possible improvement of the 3d text editor plugin ?
            Thank you.
            Sketchfab discussion : https://forum.sketchfab.com/t/dimensions-on-a-3d-model/5480
              What version of SketchUp are you using? Please complete your profile as that information helps us help you.
              If you are going to the trouble of adding dimensions as 3D text, why not make a dimension line component that you can insert?
              Personally if I'm going to download a 3D model to use as a plan, I wouldn't want all the dimensions as 3D geometry. That would just bloat the file without providing much benefit.
              • E
                Einstein
                I noticed that SketchUp creates 3D text with very low precision. I mean, letters' curvature are made up with very low number of segments, and they look quite jaggy when you zoom in.
                I guess Editable 3D Text uses the same methods for text generation so it also looks jagged but I thought: maybe it would be possible to generate text with more precision?
                • onidarbeO
                  onidarbe
                  For some reason it only shows a red cross where you click until selecting an other tool.
                  So the pop-up to enter or edit the 3D text doesn't show up anymore in Sketchup 2019 😞
                    Works fine for me up to the latest SketchUp version...
                    What's the version of its RBZ - 1.3.0 is the newest...
                    If you have the Ruby Console open when you start the tool are there any error messages ?
                    Have you got the latest TT Lib installed ?
                    Have you cleared the Internet Explorer cache ?? It might be corrupted and affecting the dialog...
                    • C
                      critz1184
                      I am experiencing the same issue in Sketchup 2021. Even uninstalled/reinstalled it and TTlib2. It used to work but no longer does, no 3d text window appears, just some "align to face" dialogue that does nothing after clicking. After that I just get a red X on the screen.
                      https://i.imgur.com/LveeLeq.png
                        This is what I see in SketchUp 2021.
                        Click on the picture
                        Make sure you installed SketchUp correctly which involves right clicking on the downloaded installer and choosing Run as administrator from the context menu.
                        By the way, perhaps you could update your profile. Currently it says you are using SketchUp 2019 Free/Make which would be impossible anyway.
                        • atelierpaarA
                          atelierpaar
                          Hello and good morning,
                          after installing SU 2025 3D its not possible to edit 3 D text - any clue how to fix this ??
                          Tanks for your help/advice
                          Uli
                          TIGT Dave RD 2 Replies Last reply
                            TIG Moderator @atelierpaar
                            @atelierpaar
                            Basic 3dText is not 'editable', you need an extension like this -
                            https://sketchucation.com/pluginstore?pln=tt_texteditor
                              Dave R @atelierpaar
                              @atelierpaar it works fine in SketchUp 2025 for me. As TIG implies, the 3D text needs to have been created with this extension in order to be editable. Also make sure you have the current version of TT_Lib2 installed. It is required by this extension.
                              This is done in SketchUp 2025.
                              Editable Text.mp4
                                I suspect you need to reinstall this extension [and perhaps some others?]
                                Extensions don't automatically 'port' over from an earlier version of SketchUp when you install a newer one -
                                although v2025 does have a new extension to let you do that -
                                but it's not 100% foolproof, and reinstalling them manually does let you do some tidying up and housekeeping, to keep your extensions 'lean-and-mean'...
                                  jjtakestheworld
                                  Hi, Can i add custom fonts to the list? I use a lot of specific brands fonts which are installed on my machine but i cannot see them in the drop down list?
                                  TIGT 1 Reply Last reply
                                    TIG Moderator @jjtakestheworld
                                    @jjtakestheworld
                                    If the font is installed it should be listed.
                                    However, I think that only ttf fonts show
                                    otf fonts don't...
                                    J 1 Reply Last reply
                                      jjtakestheworld @TIG
                                      @TIG Ah legend. I've just converted a OTF to TTF and it's found it. Thanks
                                      • P
                                        puttea
                                        I work with two monitors, SketchUp runs on the right screen. The editor always opens in the left screen. Is it possible to let it open on the right screen or let it remember the location where it was used the last time?
                                        Dave RD 1 Reply Last reply
                                          Dave R @puttea
                                          @puttea what version of SketchUp? What operating system?
                                          • P
                                            puttea
                                            @Dave R SketchUp 2025 Pro on Windows 11
                                            • 11
                                            • 10 / 11
