    [Plugin] 3D Text Editor
    204 Posts 51 Posters 231.0k Views 50 Watching
    • P
      pierrearchi26
      hello ThomThom,
      I'm trying to use the plugin to import Sketchup dimensions lines into Sketchfab which is a well known big problem (if you don't use a picture for it)... I use the plugin to create the 2d dimension line value ... but i need the line ... maybe a possible improvement of the 3d text editor plugin ?
      Thank you.
      Sketchfab discussion : https://forum.sketchfab.com/t/dimensions-on-a-3d-model/5480
        What version of SketchUp are you using? Please complete your profile as that information helps us help you.
        If you are going to the trouble of adding dimensions as 3D text, why not make a dimension line component that you can insert?
        Personally if I'm going to download a 3D model to use as a plan, I wouldn't want all the dimensions as 3D geometry. That would just bloat the file without providing much benefit.
        • E
          Einstein
          I noticed that SketchUp creates 3D text with very low precision. I mean, letters' curvature are made up with very low number of segments, and they look quite jaggy when you zoom in.
          I guess Editable 3D Text uses the same methods for text generation so it also looks jagged but I thought: maybe it would be possible to generate text with more precision?
          • onidarbeO
            onidarbe
            For some reason it only shows a red cross where you click until selecting an other tool.
            So the pop-up to enter or edit the 3D text doesn't show up anymore in Sketchup 2019 😞
              Works fine for me up to the latest SketchUp version...
              What's the version of its RBZ - 1.3.0 is the newest...
              If you have the Ruby Console open when you start the tool are there any error messages ?
              Have you got the latest TT Lib installed ?
              Have you cleared the Internet Explorer cache ?? It might be corrupted and affecting the dialog...
              • C
                critz1184
                I am experiencing the same issue in Sketchup 2021. Even uninstalled/reinstalled it and TTlib2. It used to work but no longer does, no 3d text window appears, just some "align to face" dialogue that does nothing after clicking. After that I just get a red X on the screen.
                https://i.imgur.com/LveeLeq.png
                  This is what I see in SketchUp 2021.
                  Click on the picture
                  Make sure you installed SketchUp correctly which involves right clicking on the downloaded installer and choosing Run as administrator from the context menu.
                  By the way, perhaps you could update your profile. Currently it says you are using SketchUp 2019 Free/Make which would be impossible anyway.
                  • atelierpaarA
                    atelierpaar
                    Hello and good morning,
                    after installing SU 2025 3D its not possible to edit 3 D text - any clue how to fix this ??
                    Tanks for your help/advice
                    Uli
                    TIGT Dave RD 2 Replies Last reply
                      TIG Moderator @atelierpaar
                      @atelierpaar
                      Basic 3dText is not 'editable', you need an extension like this -
                      https://sketchucation.com/pluginstore?pln=tt_texteditor
                        Dave R @atelierpaar
                        @atelierpaar it works fine in SketchUp 2025 for me. As TIG implies, the 3D text needs to have been created with this extension in order to be editable. Also make sure you have the current version of TT_Lib2 installed. It is required by this extension.
                        This is done in SketchUp 2025.
                        Editable Text.mp4
                          I suspect you need to reinstall this extension [and perhaps some others?]
                          Extensions don't automatically 'port' over from an earlier version of SketchUp when you install a newer one -
                          although v2025 does have a new extension to let you do that -
                          but it's not 100% foolproof, and reinstalling them manually does let you do some tidying up and housekeeping, to keep your extensions 'lean-and-mean'...
                            jjtakestheworld
                            Hi, Can i add custom fonts to the list? I use a lot of specific brands fonts which are installed on my machine but i cannot see them in the drop down list?
                            TIGT 1 Reply Last reply
                              TIG Moderator @jjtakestheworld
                              @jjtakestheworld
                              If the font is installed it should be listed.
                              However, I think that only ttf fonts show
                              otf fonts don't...
                              J 1 Reply Last reply
                                jjtakestheworld @TIG
                                @TIG Ah legend. I've just converted a OTF to TTF and it's found it. Thanks
                                • P
                                  puttea
                                  I work with two monitors, SketchUp runs on the right screen. The editor always opens in the left screen. Is it possible to let it open on the right screen or let it remember the location where it was used the last time?
                                  Dave RD 1 Reply Last reply
                                    Dave R @puttea
                                    @puttea what version of SketchUp? What operating system?
                                    • P
                                      puttea
                                      @Dave R SketchUp 2025 Pro on Windows 11
                                        Close Sketchup. Go to user/AppData/Local/SketchUp/SketchUp 2025/SketchUp and open PrivatePreferences.json. Look for "ThreeDTextDlg". What are the "x" and "y" values? Edit those to move the dialog onto the correct screen. This is what it looks like on my computer.
                                        And here's the dialog relative to the top left corner.
                                        Note that the user/AppData folder is normally hidden so you'll need to make hidden folders visible in File Explorer.
                                        Did you install SketchUp 2025 correctly? That requires right clicking on the downloaded installer and selecting Run as administrator. If you didn't do that it's possible that Windows is preventing SketchUp from making suitable updates to PrivatePreferences.json. To ensure SketchUp is installed correctly, close SketchUp, find the installer in your Downloads folder, right click on it, choose Run as administrator, and when prompted, click Repair. No matter what, it won't hurt to do it.
                                        P 1 Reply Last reply
                                        • P
                                          puttea @Dave R
                                          @Dave-R Thanks!
                                          • X
                                            xannanov
                                            1 Месяц назад перестал работать плагин. Кнопка плагина активна. После нажатия - ничего не происходит и не появляется окно редактирования и создания текста. Пробовал это: переустанавливал плагины и библиотеки разных версий. Во всех случаях - одинаковое поведение. Кто смог решить эту проблему?
                                            The plugin stopped working a month ago. The plugin button is active, but nothing happens when I click it—the text editing/creation window does not appear. I have tried reinstalling plugins and libraries of various versions, but the behavior remains the same in every case. Has anyone managed to solve this problem?
                                            • 11
                                            • 10 / 11
