    Bending plug in
    13 Posts 5 Posters 926 Views 5 Watching
      The rod is tapered like a fishing rod, in fact I am sure it is a fishing rod blank
      BoxB 1 Reply Last reply Reply Quote 1
        Use the cardinal point to create the tapered cylinder...
        Use Quadface Tools to add some loops...
        Use Smoove to bend
        Or TrueBend for precision
        https://sketchucation.com/pluginstore?pln=tt_truebend
          That is awesome Rich thanks youπŸ‘ πŸ‘ πŸ‘
            Do all these methods need to be quad faces to work including smoove?
              No, TrueBend will generate the internal loops it needs to do the bending. So that's probably the most efficient method.
              I only used QFT to help me cut loops so Smoove would work.
              • BoxB Offline
                Box @L i am
                @L-i-am
                Without plugins.
                The only things off screen are, Weld Edges and Soften edges.
                Note I use a polygon to get the hard edges, which when welded allow the taper.
                1 Reply Last reply Reply Quote 5
                • Gus RG Offline
                  Gus R
                  Use a regular arc and Taper Maker plugin.
                  I exaggerated the diameter difference for clarity.
                  Taper Maker | SketchUcation
                  Draw a tapered extrusion in SketchUp using Taper Maker. Any SketchUp line drawing tool can be used to create a path.
                  (sketchucation.com)
                  www.instagram.com/gusrobatto/
                  www.facebook.com/gusrobatto
                    @Gus-R Now you're just showing off with the McTwist
                    • Gus RG Offline
                      Gus R @Rich O Brien
                      @Rich-O-Brien said in Bending plug in:
                      McTwist
                      McTwist again like we did last summer!
                        Thanks to you all, I am mainly interested In non organic architecture and don't do much organic modelling but I learnt a lot from this thread, thanks again πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                        • panixiaP Offline
                          panixia
                          Another free one you could look into is the "radial bend" feature from Fredoscale. The plugin also includes other really useful features such as tapering, stretching, twisting and so on..
